Old 07-09-2006, 01:05 PM   #1 (permalink)
Angry Leveling Kit Help???
I bought a Top Gunz leveling kit from a member on here and was attempting to install it today, I got as far as trying to release the ball joint from the spindle with no luck, on the instuctions from Greg it says lightly tap the spindle and the ball joint should release, however I had no luck with this, can anyone lend a helping hand on what I should try and do to get this to release?
2004 SE, CC, Big Tow package, Westin chrome nerf bars, undercover bed cover, OEM fog lights, rain guards, Flowmaster dual exhuast, 2" leveling Kit.
jbiscoe is offline   Reply With Quote
Old 07-09-2006, 01:40 PM   #2 (permalink)
Vegas04's Avatar
Re: Leveling Kit Help???
hit it harder!! LOL. Make sure that you have the lower control arm supported by a second set of jackstands and make sure that you leave the ball-joint nut threaded on the end. when it the tapered part of the ball joint comes free from the spindle you don't wan't everything to go nuts. then use a 3-8 lb mini-sledge or dead-blow. Take horizontal-whacks at the top of the spindle striking at each side including the backside if you can. The shock of the hammer-blows will free it up. Just avoid a pickle fork or you will most definitely destroy the grease boot on the balljoint.
Galaxy Black 2004 Titan XE CC 4x4 w/ Off-Road Package, Preferred Package.
Mods: PRG Spacers, 17x9" Eagle 187s (+2mm offset) w/ 315 70-17 BFG All-Terrain KO tires, Stillen Diff Cover, Alpine Type-R components in the front, coax. in the rear w/ 50 x 4 Rockford Fosgate Amp, XM, Debadged, and Homemade RCA pre-outs on in-dash changer.
Vegas04 is offline   Reply With Quote
leveling kit ErikArrow Titan Performance Modifications 39 11-14-2006 02:19 PM
Any One Experince Procomp Leveling Kit? ---how Hard Is It To Install A Leveling Kit? d0va Titan Suspension 2 03-23-2006 08:16 PM
Leveling Kit nnakicksas* Titan Parts & Accessories 7 02-10-2006 05:29 PM
Leveling kit brandong22 Titan Parts & Accessories 37 10-15-2005 11:39 PM
I Get A Leveling Kit !!!!!!!!!!!!!! Flat Black Titan General Discussion 10 03-04-2005 05:19 PM
