Old 07-11-2006, 08:27 AM   #1 (permalink)
thxpro713's Avatar
Question Led Light Bulbs For Tail Lights
I am aware the bulb number is 3157. I recently purchased clear tail lights with a black housing for my titan. After installing them I didnt like the way the red bulbs made them look so I went and got a pair of 3157 LED light bulbs which look alot better. Only problem is I cant get the brake light portion of these bulbs to light. My 3rd brake light works and the 2 led brake lights just dim when I hit the brake . Any help will be greatly appreciated because this is driving me crazy and Im sure Ill get a ticket soon. Thanks,
Danny
thxpro713 is offline   Reply With Quote
Old 07-11-2006, 10:34 AM   #2 (permalink)
Flight Test's Avatar
Re: Led Light Bulbs For Tail Lights
I purchased a pair of 3157's from the site below. LED's are polarity sensitive. All I can suggest is remove both lights and start from scratch. Install one LED at a time, verifying operation before moving to the second. The LED color must match the lens color. Red lens=red LED.
http://www.ledtronics.com
Joe
God Bless the USA!
2005 LE KC 4x2
A15/Steel, W07, N94, L92.
Hellwig Anti-Sway Bar
******* Industries: SS Door Sill Trim, Chrome Tailgate Trim
LED tail/brake lights
OEM Bug Deflector & Step Rails
Armada Front Air Dam
Born 4/2005
Brought home 7/7/2005
2000 Corvette Coupe
Flight Test is offline   Reply With Quote
Old 07-11-2006, 01:23 PM   #3 (permalink)
pi3yeargrad's Avatar
ye, make sure the polarity is right and that they are sitted properly...sometimes those LED bulbs are fatter and when putting in and removing itll bend the lil gold clips inside bend back and wont make a as good connection...check on that as well and have some spare fuses handy
...there u old geezers...now STOP COMPLAINING!
pi3yeargrad is offline   Reply With Quote
Old 07-11-2006, 02:58 PM   #4 (permalink)
thxpro713's Avatar
I got them on but they wont light with the brakes. Had to change the STOP LIGHT fuse to 15amp. But still no luck with getting them to get brighter with the brakes. That website wouldnt display the page for the AUT3157's. Interested in the 3156's too.
Old 07-11-2006, 03:00 PM   #5 (permalink)
thxpro713's Avatar
[quote=Flight Test]I purchased a pair of 3157's from the site below. LED's are polarity sensitive. All I can suggest is remove both lights and start from scratch. Install one LED at a time, verifying operation before moving to the second. The LED color must match the lens color. Red lens=red LED.
My lens are clear. How can I check the polarity?
Old 07-12-2006, 11:11 AM   #6 (permalink)
[quote=thxpro713]
If I remember correctly, the 3157's have dual contacts. A set for tailights and a second for brake lights. They won't light if reversed in the socket. Remove and turn 180 degrees and re-insert. You should not have to go with a bigger fuse. I thought brake lights have to be red.
Joe
God Bless the USA!
2005 LE KC 4x2
Born 4/2005
2000 Corvette Coupe
Old 07-14-2006, 01:20 PM   #7 (permalink)
thxpro713's Avatar
Yeah they do have to be red. The led lights up red and the housing on them is clear. I will try to reverse them and see what happens thanks for the info.
Old 07-15-2006, 03:52 PM   #8 (permalink)
thxpro713's Avatar
Ok, I reversed them several times and got no results. The bulbs keep dimming with the brake. I tried a regular bulb and it does the same thing as the LED bulbs, just dims with the brake. What could be wrong????? I checked out all the fuses and found nothing blown. I am definatly missing something here. Any help?????? Thanks!
Old 07-15-2006, 05:56 PM   #9 (permalink)
top20cc's Avatar
Send a message via Yahoo to top20cc
I am curious. Are you sure the bulb socket you are using is not the brake but the turn signal? There are 2 sockets. Make sure you are replacing the right bulb. Simple test; hit the emergency lights. If they flash then you are replacing the wrong bulbs. Get it? Make sense?
Going to church doesn't make you a Christian any more than standing in a garage makes you a car
top20cc is offline   Reply With Quote
Old 07-16-2006, 03:55 PM   #10 (permalink)
thxpro713's Avatar
Yeah, Im definatly in the brake/running light socket. Ive tried like 4 different bulbs and they only light with the running lights no brightness with the brakes. The only brake light working now is the 3rd light above the bed. What could I be missing?
need help with my led tail lights !! glowinstrat Titan Parts & Accessories 4 03-20-2006 01:42 PM
899 fog light bulbs captain425 Titan Parts & Accessories 20 12-19-2005 11:54 AM
I had noticed that members replaced their fog light bulbs Bmaez Titan General Discussion 19 11-15-2005 10:29 AM
Chrome Tail Gate and Tail light bezels DWBTITAN421 Titan Parts & Accessories 1 08-28-2005 01:06 PM
tail lights SHORTY Titan Interior Discussion 0 03-06-2005 08:33 AM
