Old 07-22-2006, 01:08 PM   #1 (permalink)
d0va's Avatar
Question help installation fog lights behind grilled!!!
I have a pair of 6" offroad foglights I want to installed behind the grilled(sp) but theres a plastic cover thats seems to be there to direct air to radiator. I have attached a picture off were I want to install the lights.
if any one has done this mode or remove their grilled before pls hooked me up with some instructions.. thank you
Pm for a Signature Request
Check out my Photoshop Signature Album
d0va is offline   Reply With Quote
Old 07-22-2006, 01:18 PM   #2 (permalink)
CoachBoone's Avatar
Re: help installation fog lights behind grilled!!!
I think you'll have to dremmel or cut it out. I installed a one piece billett grille, but before I did, the mfr sent me the wrong one, the 3 piece one. We toyed around with maybe installing it cuz it did look sweet, but we found that you'd have to cut out all the honeycomb sections. I'm almost positive it's a one piece grille.
2004 Nissan Titan SE 4X4 Crew Cab
with a bunch of stuff on it.
"Straighten that tie, son."
Old 07-22-2006, 01:37 PM   #3 (permalink)
d0va's Avatar
Question Re: help installation fog lights behind grilled!!!
I want to installed them behind the honeycomb ... not infront
Old 07-23-2006, 08:53 AM   #4 (permalink)
d0va's Avatar
Talking Re: help installation fog lights behind grilled!!!
heres another image of what i want to removem the main question is.
If I remove this two parts would the truck overheat?
How hard is it to remove the front grilled(sp)?
Old 07-24-2006, 05:24 PM   #5 (permalink)
baseballfanz's Avatar
You can cut out two cardboard piece the size and shpe of the 2 side grill, tape it over the grill and drive around, see if that have any effect on the coolant temp. before you cut anything. Goodluck.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 08-01-2006, 02:55 PM   #6 (permalink)
Dova- Im also interested in the same mounting location but have the same overheating questions. Please keep us up to date on your progress- Thanks
MENMYJP is offline   Reply With Quote
Old 08-25-2006, 10:11 AM   #7 (permalink)
d0va's Avatar
i finally go to try doing this mode let tell you that the space behind the grilled is real small ...theres probably less than 3.5 in of space I try to fit my light different ways but the grilled wouldn't closed. the only location behind the grilled my light would fit it was in the middle part but I would have to relocate the horns and I didnt like the way it look. If some one knows a set of fogs 6" preferely but thin let me know cause I really like the way they look back there... SOrry
Old 08-25-2006, 10:34 AM   #8 (permalink)
The Hella 500 is very thin.
Dimensions: 6 3/8"Dia. x 6 7/8" H x 2 5/8"D
Hella website
Old 08-25-2006, 07:39 PM   #9 (permalink)
Kronos1965's Avatar
I tried this already-no affect. I was thinking of doing the same thing.
Shouldn't have any effect-the pullers at the bottom draw the majority of the air into the system.
Kronos1965 is offline   Reply With Quote
Old 08-25-2006, 07:49 PM   #10 (permalink)
Stoobie's Titan's Avatar
What about in lower "mouth" portion in bumpercover??
Stoobie's Titan is offline   Reply With Quote
Old 08-25-2006, 08:43 PM   #11 (permalink)
Carbeaux's Avatar
^^^That's been done. I've seen at least one pic of someone's ride here on the boards who did that. I don't recall who it was, but I thought it looked pretty good. I would personally prefer the lights a little higher, like where Dova is trying to put them. I'm interested in what this will look like if Dova or anyone else gets it done.
Hook 'Em Horns!
"A veteran is someone who, at one point in his life wrote a blank check made payable to "The United States of America" for an amount of "up to and including my life." That is Honor, and there are way too many people in this country who no longer understand it."
Old 08-25-2006, 11:11 PM   #12 (permalink)
Carbeaux's Avatar
And another thought. If you do get them on the two outside smaller grilles, I'll bet you could send a template to DunderDan and get him to custom cut one of his grilles to put around it. He CNC's his stuff I think, so I bet it wouldn't be that hard for him.
Hook 'Em Horns!
Old 08-26-2006, 05:36 AM   #13 (permalink)
d0va's Avatar
that's a good thought but I want them behind the grilled kind like sthealt (sp) love the frond end design would want to make look to busy...
Stoobie's Titan: What about in lower "mouth" portion in bumpercover??
like Carbeaux mention thats been done, now I senn a member that did custom cut out on the lower grille and I thought that looked very cool, dont remember who?
Ill keep you guys updated if I try it again with a different set of lights...
Old 08-26-2006, 06:50 AM   #14 (permalink)
Carbeaux's Avatar
Gotcha. So the photoshop pic you posted was REALLY what you're going after. I see now! You'd lose a little in light output passing it through the grille itself, and the more "downward" you try to aim the light, the more light output you'd lose, but it'd acheive the effect. Keep trying!
Hook 'Em Horns!
Trailer Lights : running lights not working Chance2336 Titan Towing & Hauling 9 09-12-2006 06:33 PM
for the person who has everything ... a virgin mary grilled cheese !!! mikegronholz Off-Topic Discussion 12 11-19-2004 03:27 PM
Gauge lights not lightning up when i turn on lights??? ChadEberly Titan Problems & Dealer Service 4 11-15-2004 12:17 PM
Anyone figure out how to wire fog lights to parking lights? newenglandtitan Titan Interior Discussion 9 04-19-2004 08:06 PM
