Old 08-17-2006, 01:35 PM   #1 (permalink)
Want to lift!!
I really want to lift my titan but there is just so many options. Here is what I want a descent size lift 6" or more I want to be able to tuck 37's but idk if I want to do such a big tire. So my question is what do I need I was thinkin the pro comp 6" lift but what else to give it that extra lift?
Galaxy Black CC
Kenwood KVT-815DVD,Polk Audio Speakers,
MTX 6004 4 channel
Big Tow, Off Road
Mr Grille Billet Grille
Custom Flame Paint job
GalaxyCC is offline   Reply With Quote
Old 08-17-2006, 01:42 PM   #2 (permalink)
Supporting Vendor
P's Titan's Avatar
Re: Want to lift!!
get in touch with PRG and he will give you all the info you need
my mods list
www.adamspolishes.com
CrankyWhore™
Blah Blah Blah Whore™
TequilaWhore™
Old 08-17-2006, 02:01 PM   #3 (permalink)
rod_b's Avatar
Re: Want to lift!!
Probably need some adjustable coilovers and/or a body lift to fit 37s.
8.04 K11 CC LE 4X OR BT PRG'd
rod_b is offline   Reply With Quote
Old 08-17-2006, 02:37 PM   #4 (permalink)
kartman's Avatar
Re: Want to lift!!
If you want to "tuck" 37s you will need fiberglass front and rear.
You will likley need more than a 6 inch as well.
Rebar Wrangler
Old 08-17-2006, 02:42 PM   #5 (permalink)
beached_titan's Avatar
Re: Want to lift!!
ive got the cst 8" lift with fox coilovers and i can barely clear 35's.. to clear 37's you will need the 8" lift and a 2" body to clear them safely.
or do the 8" lift and get fiberglass.
beached_titan is offline   Reply With Quote
Old 08-17-2006, 04:41 PM   #6 (permalink)
Titan-Power's Avatar
Re: Want to lift!!
37's are allot of tire. With 35's and the right wheel offset a 6" kit will work just fine.
I brew the beer i drink!
Titan-Power is offline   Reply With Quote
Old 08-17-2006, 06:00 PM   #7 (permalink)
Re: Want to lift!!
Ok I was thinkin that 37's would be too much I just want it to have a good heighth. if I went with the pro comp lift what else would I need to get a little higher?
Galaxy Black CC
MTX 6004 4 channel
Big Tow, Off Road
Old 08-18-2006, 01:34 AM   #8 (permalink)
Re: Want to lift!!
Ok so I was looking through some posts and I want my truck to pretty much look like kevdizzles. He has the CST lift and some TC arms and DR coilovers. Can I do this to my 4wd truck and if so can you show me what I would need to buy. Thnx in advance.
Galaxy Black CC
MTX 6004 4 channel
Big Tow, Off Road
Old 08-18-2006, 01:38 AM   #9 (permalink)
SOCALTITANKC4X4LE's Avatar
Re: Want to lift!!
Check this out:
http://www.prgproducts.com/
If you don't find what you need here, then it's not worth buying.
Banks, K&N CAI, Stillen Big Brakes, Stillen Transmission valve body mod. Detroit Trutrac, PRG TRACTION BARS, ODYSEY BATTERY BLUE LED DASH LIGHTS MOD[COLOR="Green"]1997 PATHFINDER w/ original engine and and diff. (Tranny died at 473,000 Rebuilt by Aamco )
Odometer reads 480,000 miles and I'm hoping to get 500,000.[/color]
SOCALTITANKC4X4LE is offline   Reply With Quote
Old 08-18-2006, 07:38 AM   #10 (permalink)
TIsTAN's Avatar
Re: Want to lift!!
on another titan site, someone was able to fit 37s on the pc 6" with the use of radflo coilovers and tc uca. didn't say how it performed if offroaded nor if it rubbed under any conditions (though wheel specs play more of a role here). my goal is to go higher too without a body lift plus my shocks and tires are nearing the end. definitely ask prg greg and find out your best options.
TIsTAN is offline   Reply With Quote
Need help with lift? tcf_dk Titan General Discussion 4 04-19-2006 09:58 AM
Just compared side by side PRGs mini lift Vs. Rancho 4" lift... K-MU Titan Suspension 19 01-12-2006 08:25 AM
lift kit bbplayajs Titan General Discussion 5 11-03-2005 07:58 AM
cst 6" lift kit vs. rancho 4" lift kit. doitbby Titan Suspension 7 08-24-2005 02:09 PM
2.5" lift Rough Country Lift for sale GETSOMZ28 Buy/Sell 0 10-26-2004 11:57 AM
