Hub Centric Rings Size
I just put a new set of 22 inch demoda rims on my titan with a 108mm outside bore and looking to find inside hub size on the titan side,Ive been told 78.03 is the most common ring on the market and it will work for me,But found out the size of hub on titans are 77.1.can someone give me some help if youve come acrossed this issue.Im looking at a set of 4 outside 108mm (aftermarket rim bore) and inside 78.03mm will this hub centric ring set work for me.
