Well I pick up my titan tuesday and i'm already thinking about my lift kit! I want a 6inch but im thinking its going to be to much money! Plus I will have to buy 35's to make it look normal which will result in more gas gussled! So my question is can somebody please tell me the full cost on a 4inch lift and a 6 inch lift! I always search it on the web but its says you need this and that! I'm not going to lie im confussed! Thanks in advance....Oh and if I go 4 inch lift will 33's look fine?
4"(Rancho-4wd only, PRGproducts both) and 6"(Fabtech-4wd only, Procomp-both) cost about the same. As far as worring about tires, go with a 315/70/17 and you will save on gas compared to the 35s and they will look good.
2007 White with Charcoal SE CC 4x4 with off road, tow, SE popular with bench, and utility with bed extender
Mods to date:
6" Procomp Stage II lift, CST Sway bar endlinks, 35x12.5x17 Procomp Mud terrains, 17x8 Moto Metal 954s, Smittybuilt stainless nerf bars, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, T Rex 1pc grille, Custom FlowMaster DeltaFlow 50 series dual in single out muffler, Injen powerflow intake, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Sony Xplod 2x250 amp, Infinity Reference 6 1/2" in rear and 6"x9" in front, Prodigy brake controller, Ventshade door sill protectors
I forgot to ask if you were 2wd or 4wd. If you are 2wd there is a CST 4" lift spindle also. It runs in the 800 range with new rear bilstien shocks. You can add a leveling kit to the mix also and get 6 1/2" for less then 1000 with a stock ride and more ground clearance and less aftermarket parts.
Mods to date:
the CST kit alone goes for around 2100; look around and i'm sure you can find it for around 1600. But keep in mind that you need rear shocks with that kit, and down the road you'll also want to upgrade to front coilovers (if you have a 4x4, i'm assuming you'll be taking it off road). The front shocks will blow out pretty quickly. Call Greg @ PRG, if that kit is too much, he can set you up with a kit that performs well, and get you the best customer service for your money
For lowest cost I would get the 6" procomp lift. Then find a set of Rancho front struts for now to use when you put on the lift. They will 4x better. When you save up some cash get some donahoe racing coilovers and some bilstien shocks for the rear.
Mods to date:
My interest will be 4X4ing it ever so offten! Maybe once every two weeks and nothing hard core! Its going to be winter soon so that means i'll be in 4X4 ALL the time! but i'm sure that doesnt make a diff! Thanks for the info guys now I just need to sell one of my bikes to buy my lift and tires!
Find a local shop and have them look into the procomp kit. The pc and ft kits run around the same price after all the extras but the install on the pc kit "should" be less expensive as its a bit less time consuming to install. Run the factory struts for now as they are new. Eventually you will need to replace them and think about upgrading then. You cannot combine a regualar replacment DR coilover and use it in on a PC kit as the upper arm will hit the coilbucket, you will need to add the TC upper a-arm, and even extra expense. Also, dont mix the Rancho "lift" struts with any other kit, they are way too short to even work properly. Lastly, if you are goning to have the kit installed locally, buy the kit form that shop. It may ave you a few bucks to buy it on e-bay, but your installer will certainly cahrge more because he didnt sell you the kit and if there are nay problems or parts missing, he will hand you the "fix-it" torch and the kit itself wont be his problem, but yours. Kit should run you around $1300-1400 plus 4-500 for install. If you are keeping the factory wheels, you can shoe-horn a 35" tire in there (NOT a procomp, toyo, or nitto though) by ditching the mud flaps and runnigna leveling kit. See pic of yellowmantis' truck.
The local guys I know are going to charge me 2500 plus 100 for alinment! Thats CDN! Thats for a pro comp 6". I was reading about it and it says the lft is 3inches in the back and 6 in the front??
So what all should I have them stick on besides what comes with the lift? Sorry for all the questions this is my first 4X4 and I know nothing about lifts
im having the same problem im new to the titan and ive been talking to a local shop that said they would do a ft 6'' 35s on 20s, m/b my tires inline and install for $4500. Im think the ft will sag in the rear like all the other truck in my area i see w/t ft lifts and I DONT WANT THAT!! that looks like s@!t!! I wanted to know if the procomp will sag in the rear? I just want a good kit that rides good,looks right,durable,and doesnt cost so much. thats why i was looking at the ft but you get what you pay for. ft or pc????? THANKS FOR ANY HELP!!!
My kit is in the mail right now. I should have pics up of mine within a week. Im getting mine from Greg @ PRG. Its 6 1/2" up front and 4 inches in the rear. Im also grabbing a set of 325/65/18 tires on the stock rims here within the next month.
