Originally Posted by Lurchdubious
really like the bakflip~flippin the rails wasn't so bad, and it actually didn't cover the 12-volt. check out the pics if ya want:
How did you get the bolts out. I bought the torx head yesterday and applied some pressure with a screwdriver yesterday to a couple and they didn't budge.
Are you all using a drill to get these out? Someone mentioned using heat but I am concerned about damage to the spray in liner?
Home depot had a tool by husky that you strike with a hammer that is supposed to supply up to 200lbs of torque, I can't remember what it was called?
If I can get the rails flipped I might go with the bakflip, but I'm not ordering one until I've done that, otherwise I'll go with the Advance. Any hints appreciated.
I have to flip all 4 (2 per side) right?
Thanks,
