Old 12-04-2006, 06:53 PM   #1 (permalink)
DEI 556u help
I see a lot of people have used a DEI 556u interface module. The manual shows three methods for installing it. The standard method uses the loop antenna but the manual requires it to be mounted in front of the factory transponder ring. Since the factory ring is flush with the face of the ignition lock, it would be impossible to mount the DEI antenna loop in front of it. Will it work mounted behind the factory loop? The alternate methods wire the interface directly into the factory transponder ring, and are a much cleaner install, but the manual is a little vague on whether it will work on which vehicles. Anybody have some experience to pass on?
Thanks,
MT
akmike is offline   Reply With Quote
Old 12-04-2006, 07:51 PM   #2 (permalink)
rcantu's Avatar
Re: DEI 556u help
i think i put mine on behind. it just needs to be as close as possible.
pics of the Titan
Old 12-04-2006, 09:29 PM   #3 (permalink)
TIsTAN's Avatar
Re: DEI 556u help
mine is looped around the grommet and you can barely tell it is no longer flush.
TIsTAN is offline   Reply With Quote
Old 12-04-2006, 11:19 PM   #4 (permalink)
f00dstamps's Avatar
Send a message via AIM to f00dstamps Send a message via MSN to f00dstamps
Re: DEI 556u help
it needs to go on the ignition ring but under the plastic cover and grommet. you can't even tell it's there after everything is tightened down.
2005 CC Titan 4x4 Blizzard White *** SE Popular Package w/ Captain's *** Utility Bed Package w/ Bed Extender *** Offroad Package *** Big Tow Package *** Valentine 1 (hardwired) *** Clifford Matrix RSX 3.5 Alarm + Remote Start *** Amsoil Synthetic motor & gear oil *** 20% Sun-Guard *** Weathertech front floor liners *** Truxedo Lo Pro *** Husky rear floor liner *** HID 4300k Denso/Koito/Philips *** Vulite LED taillights *** Luminarc yellow foglight bulbs *** Scangauge II *** overhead racks w/ kayak attachment *** DR coilovers *** DR rear 4x4 shocks
WANTING TO SELL: bed extender adapter for tonneau covers (i.e. Truxedo)
f00dstamps is offline   Reply With Quote
Old 12-07-2006, 01:08 PM   #5 (permalink)
Re: DEI 556u help
Thanks for the help. I ended up putting it around the grommet, but behind the plastic trim piece that the grommet goes through, kind of holds the grommet into the plastic trim piece. At any rate, it seems to work as it is supposed to.
Thanks,
MT
561T & 556U Installation Advice TankTitan Titan General Discussion 4 10-29-2006 09:17 AM
Remote Start 561t & 556U Help TankTitan Titan FAQ & Howto Area 2 10-21-2006 07:36 PM
