Old 12-05-2006, 11:11 PM   #1 (permalink)
NismoTitan's Avatar
HID install in HALO projectors
Okey guys I am really having a thought to get HID's installed into those projector headlights with angel eyes=). There are two things that stop me! First, on the healight it sais "No HID". Second one - Did any of ou guys installed HID's in those lights? If yes, does it melt? or you absolutely have no problems with it what so ever?
NISMO TITAN PROJECT
2006 Titan CC SE Radiant Silver 4x4
PERFORMANCE:
- Nismo Cold Air Intake
- Flowmaster 40 dual exhaust
- 2* Advanced Timing
- Nismo Voltage Stabilizer
- Poweraid TBS
BODY:
- Front Billet grill
- Solid Painted LEER Bed Cover with Tail Spoiler
- Silverline Stainless Exhaust Tips
- Nerf Bars
- Drop Shackles
LIGHTS:
- Black Halo LED Projector Headlights
- Alpha Style 5800K HIDs with Phillips Bulbs
- Black Altezza Taillights
- Rockfort Forsgate LE Sound System
- Second set of LED fog lights
- LED accent lights
SOON (NISMO MATCHING):
- Enkei 20" RT6 rims with Nismo Stickers
- g-Force T/A KDW (New Tread) Wheels.
NismoTitan is offline   Reply With Quote
Old 12-05-2006, 11:13 PM   #2 (permalink)
AgTitan06's Avatar
Re: HID install in HALO projectors
There is a guy who did this on Club Armada with no probs. Let me see if I can dig up a link
Old 12-05-2006, 11:18 PM   #3 (permalink)
AgTitan06's Avatar
Here:
http://www.clubarmada.com/forums/sho...?t=4931&page=3
http://www.c l u b t i t an.org/forums/showthread.php?t=22272
Old 12-05-2006, 11:25 PM   #4 (permalink)
titan814's Avatar
ok i really want to install these lights! my only problem is i have already installed a HID set-up in my truck. now my issue is what bulb does the new light take? is it the 9006 like the stock unit? the 10,000 watt HID kit i installed runs much cooler then the OEM lights so i cant see them melting. they probably say "no hid" because they would be really bright.
400hp LS6 CTS-V
titan814 is offline   Reply With Quote
Old 12-06-2006, 06:50 AM   #5 (permalink)
TriKKy's Avatar
... 20,000Volts, 35 Watts, possibly 10,000 Kelvin in color temp.
To answer your question however, it depends on the housings. The housing might be for 9006 bulbs and they might not, you need to check with whoever is selling them if it isn't listed.
As far as working with HID, while it's true they are cooler, there are two problems you might run into:
1. HIDs can be longer than their halogen counterparts so fit MIGHT be an issue, which leads to:
2. The lenses are based on a focal point and I guarantee it will be different between the halogen it was designed for and an HID bulb. You might get away with it, might not. I have frequently read that you might get worse performance out of sticking an HID in front of a lens designed for halogen than if you just put it into the stock reflector (which also gives you worse performance than using a true HID setup). I've also seen people do it and it looked really good and created a fairly nice cutoff.
1.
Old 12-06-2006, 06:56 AM   #6 (permalink)
1BadTitan's Avatar
Ok, I have this done. I have the projector setup with the HID conversion in. The bulb switches to an H1. You can use the same ballast for you HID's, just buy the new bulbs. They fit fine. They are bright. I have the 10,000K kit installed in them and I gotta say, its nice. I want the 6,000k kit just because I want a whiter light now. The 10,000k color is getting old to me now. Check the for sale forum for details on that sale.
1BadTitan
BASICS: Black LE KingCab 4x4-Off Road Pkg-Utility Track Bed-Big Tow Pkg
EXTERIOR: 10,000K HID Headlight Conversion-AVS Bugflector II-Wade In Channel Rain Gaurds-Smoke Headlight Reflectors-Shaved Emblems-Painted Red Calipers-Smoke Taillights-Stainless Nerf Bars-Shorty Billet Antenna-20% Tint-5" Exhaust Tip-DIY Custom 3rd Brake Light-Tailgate Assist-Custom Home Made Hitch Cover
INTERIOR: Shortened Shifter-Nismo Pedals-Dynamat Everywhere-Factory Cointray-Carbon Fiber Accents
ROLLERS: Stock OR 17's With Nitto Terra Grapplers 295/70/17
ENGINE & PERFORMANCE: PRG Lift Kit-Nismo Billet Oil Cap-Platinum Terminals-Fram AirHog Filter-Slotted Cross Drilled Rotors
I.C.E.: Eclipse AVN2454-JL Audio TR650 6 1/2 Coaxials-JL Audio TR650 6 1/2 Components-Hardwired Radar Detecter-Add On Remote Start-MICRO Alarm
Other Rides: 05 Suzuki GSXR-03 Suzuki Quadracer LTZ-400
Old 12-06-2006, 11:12 PM   #7 (permalink)
titan814's Avatar
awesome thank you. any idea where i can get a h1 replacement bulbs?
400hp LS6 CTS-V
Old 12-07-2006, 07:12 AM   #8 (permalink)
NismoTitan's Avatar
Hmm. so it seams like that it is a good idea to replace the lens as well, not only get the HID kit
NISMO TITAN PROJECT
PERFORMANCE:
- Poweraid TBS
BODY:
- Nerf Bars
- Drop Shackles
LIGHTS:
- LED accent lights
Old 12-07-2006, 07:32 AM   #9 (permalink)
jaho1979's Avatar
Also, they will NOT melt the housings. HID's run cooler than halogen bulbs. So, despite the fact that they are brighter, they put off less heat, and draw less power.
2006 Crew Cab 4x4 LE
jaho1979 is offline   Reply With Quote
Old 12-07-2006, 03:21 PM   #10 (permalink)
1BadTitan's Avatar
I have a pair of barley used h1 bulbs for sale. Real HID need to have ballasts for these to work. Not just blue bulbs. $80 shipped 10,000k
1BadTitan
Old 12-08-2006, 09:23 AM   #11 (permalink)
titan814's Avatar
PERFECT! i have the ballast system and all installed with the 9006 bulbs. what do you want for those bulbs? i have those new lights sitting under my X-MAS tree waiting for those bulbs.
400hp LS6 CTS-V
Old 12-08-2006, 07:15 PM   #12 (permalink)
1BadTitan's Avatar
$80 shipped. They were on for 2 days, actually used for one trip to and from work.
1BadTitan
Old 12-08-2006, 08:54 PM   #13 (permalink)
Justintoxicated's Avatar
Those lights look pretty cool but angel eyes would look stupid with HID white and yellow eyes.
Might have to get those Luxeon 2 watt or 3 watt dropin to match (another $100)
From the linked mod they doo appear to perform well with HID's in them, but I know for sure that if I buy another set of headlights it had better not say NO HID on it. If you get pulled over by a cop thats makes it pretty obvious that you have something in there that should not be in there. Needless to say a tow and confiscation of your new lights would not be fun.
I do like the look of the projector lights, and don't really care to make my headlights any brighter than the stock ones with HID's in them. (Thats what my HID Foglights are for LOL) I swear my foglights are brighter than my headlights anyways.
Titan Black Headlights with halo projectors g356gear Titan Parts & Accessories 70 09-21-2007 10:36 PM
Black housing Halo Projectors installed (56k beware) QWIKWHIP Titan Parts & Accessories 105 01-15-2007 01:44 PM
Installed HID's in my halo projectors today supadupaj Titan Parts & Accessories 17 01-09-2007 12:00 PM
Some new mods... bull bar and projectors pi3yeargrad Titan General Discussion 17 09-30-2006 12:17 AM
They said this day would never come..Halo 2 is HERE!! TranMan409 Off-Topic Discussion 9 11-10-2004 05:24 PM
