I'm going to throw another question out there...if you don't care about the power folding option, can you just use the existing switch and "plug and play"?
I have an 08 CC LE with Big Tow (power mirrors with heat and memory) and desperately want the 06/07 (or 08) "regular" LE mirrors with the signals, heat, memory and puddle light.
__________________ 2008 LE Crew Cab 4x4 Majestic Blue Bridgestone Dueler A/T Revo 275/60TR20; Nissan OEM Bug Deflector; Magnaflow 18" muffler (12258); Wade In Channel Vent Visors; Retrax Tonneau Cover...recently replaced by an A.R.E. LSII tonneau cover; Factory Sirius Satellite Radio (XM to Sirius swap); Autopage Remote Starter; Bosch ICON Wiper Blades; Whelen Dual-Talon Blue/Blue LED Emergency Light mounted on windshield; Signal Vehicle Products DL15-6W-1K Blue/Blue LED Emergency Lights mounted in rear window; 2 Galls Single Head Blue/Blue LED Emergency Lights mounted in the upper corners of the bumper opening
2004 LE Crew Cab 4X4; Red Brawn...TRADED on 7/11/07
I wanted to update my personal changing of the BT mirrors on my 07 CC to the typical LE mirrors...
Finally got to doing it this weekend, after they have been sitting in the box for about a month on the garage floor! Anyway, here's some info...
1) Yes, they do fit, swap for swap, as long as it is the same trim style, as has been said before. Mine was LE to LE.
2) Pay attention to the door panel removal, dig up as much info as you can. That was the longest part of the deal...removing the first door panel I tried.
3) Use a wire tied to the OLD mirror's wire jack... that way you can just pull it through as you are removing the old mirror... then re-tie it to the NEW wire jack and pull it back through from the inside of the door... easily done!
4) If you don't use the wire or string deal... you may slide the new mirror's wire jack around the side of the steel trim inside the door incorrectly. This will lead to NOT being able to raise your window... (I know, I did it..)
5) The biggest point I have to make that has not been mentioned... the three 2" long bolts that come off of the 3 prong plate on the inside of the door arch are TOO LONG for mounting to the normal LE mirrors (w/puddle lights, heat, and turn signals). They appear to be longer for the length of the BT mirror plate. I simply matched them up to make sure they were the same thread, etc... then I cut off about 7/8" of an inch of thread and they were fine to go... worked like a charm. Otherwise, I would have run out and bought an 8mm bolt the proper length... but it was Sunday eve and most stores are closed... oh well.
6) The other thing that goes along with the above point... the new mirrors that Nissan ordered for me (LE version) came with 4 screw thread points... you have to remove 3 of these as they are not needed, because they are the same holes that are needed for what I mentioned in #5 above. They are tight to remove... but patience works. They came out nicely and are the same thread size as the bolts.
Otherwise, all works fine. Plug and play. The longest part was getting that first door off...and figuring out the bolt issue. Otherwise, the actual install time is pretty minimal.
Check the classifieds, I have a brand new set of BT mirrors that I need to sell !!
man the BT mirrors are one of my favorite things about this truck I can't believe you want to ditch them
I know...Tough mirrors for a tough truck
2007, 4x4,SE, Radiant Silver, BigTow, Bed Liner, Utilitrack, Utilitrack Bed Divider, Truxedo roll up, N-Fab Step bars,
6 disc changer/MP3, Capt Chairs. Michelin Cross Terrain, Born on Nov 06FOB tailgate mod, Fog lights, Tailgate open light Mod, hard wire Garmin 7200, Hard wire back up camera Monitor, Wet Okole seat covers
2007 Forest River salem Travel Trailor 27RBLE
