Old 02-27-2007, 03:21 PM   #1 (permalink)
cp.16's Avatar
tow battery upgrade
I have a 2006 4x4 kc XE and it has a stock battery, I was thinking of upgrading to the larger tow package size battery. I do have a trailer with electric braking. Is this just a simple swap?
cp.16 is offline   Reply With Quote
Old 02-27-2007, 04:08 PM   #2 (permalink)
MuskyHunter's Avatar
Re: tow battery upgrade
So are you asking if swapping a 650 cca battery for something like a 750 cca battery is easy? It would be no different that simply replacing your battery, provided that the new battery is the same group size.
2007 Titan King Cab LE 4x4 : Big Tow: Arctic White : Graphite Leather : Painted Armada Air Dam : Truxedo LowPro Tonneau : Utilitrack Bed Divider : Underseat Storage : BFG Long Trail TA Tour Tires: Bilstein 5100 and Icon Shocks
www.secretlake.net
Old 02-27-2007, 05:09 PM   #3 (permalink)
TitanBlue's Avatar
Go aftermarket, don't get the battery from Nissan. Much better quality available, even in conventioanl lead acid batteries. Many like the Odyssey and Optima batteries. Search for info on batteries on this site. Make sure the post are oriented the same way.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG Street Traction Bars and Mini Lift Kit, UpRev Osiris Tuner 93 Performance Tuned, MB Razor Rims, Functional Hood Scoop, Custom Graphics ...
Old 02-27-2007, 06:01 PM   #4 (permalink)
dav8or's Avatar
Stock battery was A 24F size and the BT upgrade is a 27F. Advance Auto had them in stock when I got mine.
dav8or is offline   Reply With Quote
Old 02-27-2007, 06:34 PM   #5 (permalink)
Do not buy a crappy OEM battery. TitanBlue is wise.
Old 02-28-2007, 05:41 PM   #6 (permalink)
cp.16's Avatar
Thanks I just wanted to make sure there would not be any issues if I were to go with the large size avaliable with the big tow. My standard battery is already shot and it is not even a year old.
Old 02-28-2007, 06:05 PM   #7 (permalink)
RobKar's Avatar
I just got the Odyssey battery for mine "1700" Expensive but worth it.
AKA TrollopInTraining™ AKA chinawhore™
2005 CC LE
My wife thinks I spend to much on my truck!!
My Train Horn <-- Listen
RobKar is offline   Reply With Quote
Old 02-28-2007, 06:12 PM   #8 (permalink)
cp.16's Avatar
Would a battery be covered under the warranty. It is not even a year old?
Old 02-28-2007, 06:23 PM   #9 (permalink)
TitanBlue's Avatar
I "think" it is, but you'll get another OEM battery which does not have a reputation for longevity by the members on this site. I'd invest in a good battery as RobKar did and appreciate the reliability and personal safety it therefor provides. Check the member type warehouse stores (i.e. Sam's Club) for good pricing, about 30 dollars less than normal retail.
Old 02-28-2007, 07:48 PM   #10 (permalink)
royr's Avatar
The Interstate Industrial truck battery number C27F-XHD is a perfect fit replacment for the Titan's Big Tow battery for about $85. Excellent cold weather battery - it delivers as much CCA at 0 degrees as many of the competitors offer at 32 degrees. With the weather I have been experiencing (sub zero here folks) it has been the perfect low cost high quality solution. Link is to the interstate web site - check it out - mine has performed flawlessly.
http://www.interstatebatteries.com/w...T3E0UCWBE&js=1
Mods - BullyDog Powerpup-DR's-TruTrack-Billstiens-K&N Stage II FPK Banks Catback +Zoomers Tip
royr is offline   Reply With Quote
Tow Battery? ccgobama Titan Towing & Hauling 12 01-05-2008 09:20 AM
Battery help WazzuCoug Titan General Discussion 18 03-08-2006 12:51 PM
A second battery? Keven Titan FAQ & Howto Area 2 09-25-2005 07:36 AM
Battery Issues cmclovis Titan Problems & Dealer Service 2 05-23-2005 03:09 PM
