Go Back   Nissan Titan Forums > Titan Discussion > Titan Parts & Accessories
User Name
Password
Improving Gas Milage?? - being discussed at Nissan Titan Forums in the Titan Parts & Accessories section.
Old 05-05-2008, 01:13 PM   #16
charliet
Re: Improving Gas Milage??
Always make sure your tires are at the right pressure, drive with tailgate down, A/C off and you can even tuck your mirrors in on the highway. These are inexpensive ways of getting a couple more MPG's!!!
I have even heard of people puttiin vinyl over the grill and adding an under flow below the bumber??? CRAZY
charliet is offline   Reply With Quote
Old 05-05-2008, 02:37 PM   #17
Pops
Pops's Avatar
I've seen reports that claim that the tailgate down actually hurts MPG's in the newer trucks because of something along the lines of it disrupts the bubble affect created by the cab.
2005 Armada LE 4x4 - 2* Timing Advance - AirBox Mod - PRG Mini-Lift - Nitto TerraGrapplers 325/60-18
_____________
. Check out my Gallery! .
Old 05-05-2008, 03:03 PM   #18
md2420
md2420's Avatar
Mythbusters had a episode on tailgate down vs up....guess what....BUSTED.
'06 Smoke 4X4 SE KC OR BT
Airaid CAI, TBS and Banks
2* Advance
md2420 is offline   Reply With Quote
Old 05-05-2008, 11:07 PM   #19
ToyotaKiller
I'm no grease monkey however a CAI should increase MPG due to the enhanced performance of the engine. A CAI pushes "colder" air into the engine with contains more oxygen, this allows for greater compression. You aren't going to be injecting more fuel just more oxygen (not more air in general) because we all know that hot air rises thus with colder air you'll get greater compression of fuel to air. Don't look for any miracles, only slight improvements because as you increase the performance of the engine, you are increasing the HP which means the engine doesn't have to work as hard to accomplish the same effect.
ToyotaKiller is offline   Reply With Quote
Old 05-06-2008, 07:15 AM   #20
DarkS1de
its a big 5.6 v8 engine
any gas savings will be marginal at best
i mean it eats gas just standing on idle
06 Galaxy Black KC SE 4x4 Off Road
DunderDan Denali Grill / GoRhino Dominator II Steps / Line of Fire Lightbar / Extang Trifecta Cover
ScangaugeII / Blacked-out Tails / ActiveTuning Grounding Kit
...more mods coming soon...
DarkS1de is offline   Reply With Quote
Old 05-06-2008, 09:19 AM   #21
bmbroker
I have a K&N CAI and yes it helped by 1-1.5 mpg. My problem is keeping the filter clean in west texas. Also, I think I lost about .5 after having the 2 degree advance.
That said, when I tie on to a trailer it sure does handle it well.
bmbroker is offline   Reply With Quote
Old 05-06-2008, 12:41 PM   #22
mrchrishall
I think that as others have said "in theory". exhaust, CAI etc SHOULD improve gas mileage, unfortunately when you gotta put the foot down all theories go down the drain. If you want a sure fire way to get better MPG, do the "gas pedal mod" it involves finding a nice short piece of 2 x 4 and placing it under the pedal on the right side of the truck, for even better imporvement, change 2 x 4 to 4 x 4. Works wonders!
mrchrishall is offline   Reply With Quote
Old 05-07-2008, 01:43 AM   #23
CursedRacing
CursedRacing's Avatar
I don't think that you buy a full sized truck for the gas mileage anyway. But mods to increase horses power do improve gas mileage for the simple reason that your engine is becoming more efficient then it was from the factory. I think you're best bet and gain in MPG would be to get a programmer and tune it, most manufacturers set their fuel maps to run the engine rich, to reduce the chance of knock, and to keep the engine running at a cooler temperature. They can not achieve a perfect tune for every single engine they produce because of the variances during production of the engine components themselves. You can however achieve a good fuel saving tune with the help of a performance shop on your truck.
Christopher
CursedRacing is offline   Reply With Quote
Old 05-09-2008, 10:06 PM   #24
ToyotaKiller
I have a lot of respect for the guy Cursed Racing, I've seen his truck and what he's done to it. I can't tell you exactly what but I'm sure he'll post. It's sweet except for the fact that it's a Toyota.
Old 05-09-2008, 10:37 PM   #25
Gonpostal
Gonpostal's Avatar
i have a solution, buy a civic as a daily driver, and titan for weekend warrior. Its a big heavy truck they all suck in gas. go honda!
Gonpostal is online now   Reply With Quote
Old 05-10-2008, 10:43 AM   #26
TYTAIN
TYTAIN's Avatar
Get better gas mileage the simple and easy way like truck drivers are having too. No unnessary engine idleing, slow down on the interstate, keep tire pressures to suggested PSI. Notice on the interstate most trucking companies have cut there trucks speed down(at a savings of up to two MPG), and they now have auxillary power units that runs the a/c and powers the truck so the engine dosen't have to run all night. Allot of time we now carry the Altima instead of the truck, simple way to use less fuel and they are free. If your looking to bolt things on for gas saving try proven thing like the tornado, the maganet that goes on the fuel line, slick 50.......
2004 Titan LE CC 4X4 Offroad Blizzard
Amsoil 5W30,Amsoil 75W140 Severe Gear
PRG Performance kit and BFG 315/70/17 All Terrain TA KO's"
PRG Rear Shackles (ordered)
2004 Nissan Altima 2.5SL
2004 Polaris Sportsman 500 Camo W/Winch
TYTAIN is offline   Reply With Quote
Old 05-10-2008, 12:15 PM   #27
pahinui31
pahinui31's Avatar
i second that,can't tell you guys how many ppl come up and ask if the truck eats gas .i just smile tellum not as bad as old school v8s then i tellum you want gas mileage buy a HONDA not a v8.
pahinui31 is offline   Reply With Quote
Old 05-10-2008, 08:37 PM   #28
Pops
Pops's Avatar
Originally Posted by TYTAIN
....... If your looking to bolt things on for gas saving try proven thing like the tornado, the maganet that goes on the fuel line, slick 50.......
The Tornado and fuel line magnets are not truly proven and many, many people have said they do not work. There are also many who've said they do and I'm certainly not saying that anyone who believes they work is wrong but the theories behind them just don't make any sense at all if you really look into the technology behind them.
Old 05-11-2008, 07:38 AM   #29
CursedRacing
I have to agree with Pops, things like the "Tornado" and the Magnet for the fuel lines have always been comparable to "Snake Oil."
Christopher
User Name
Password
improving 2wd traction offroad Just-in Titan General Discussion 12 02-01-2007 05:27 PM
better gas milage import2nr Titan General Discussion 14 10-25-2006 07:43 PM
Improving Turning Radius red_rider_elsinore Titan Suspension 1 10-16-2006 09:08 AM
Testing Improving Gas Mileage Myths gchu Titan General Discussion 15 09-16-2005 03:28 PM
Gas milage tsopps Titan General Discussion 47 03-24-2004 01:19 PM
Search this Thread:
Advanced Search
vB code is On
