A lot of Titan owners in socal know my Horn, at least the ones that come to the meets.
1. The compressor you have will not handle the pressure (~150psi) for long. I recommend that you put a 115Psi or 120psi pressure switch in. By doing this yes you will drop a couple of db (2-3) but not much, however your pump will last a lot longer.
2. The compressor should remain as dry as you can but will take some wet. keep in mind that it will get HOT and the tiny seal in the back plate will evenly start letting watter in and rust the brush springs. So in about 1 year look for a replacement.
3. The power should come directly from the battery. put a fuse as close to the battery as you can. Then use a relay to switch the power on. Why... Simple at about 90-100psi the pump will require ~ 15amps - 18amps and go up from there.
Relay:
4. The tank is small but will work for what you need. 3-4 blasts. The hose provided is ok but can blow off when watter gets on the inside. (what happens when you compress air). mount the tank anyplace you want.
5. Your Horns. OUCH ... I think you got the wider set. Mounting them under the bed is ok but you really want to mount them in front. From what I see from the horns you have there is no room in front.
This is a set like I have mounted just in front of the drivers side tire and pointed down.
Let me know how I can help but this should be enough to get you past most speed bumps.
Thanks for all the replies. Been sick and haven't been able to log on or make any progress on the installation. Hopefully get back at it tonight after work.
But RobKar, thanks for the detailed info. And yeah, thats what Ill have to do with the compressor is go straight to the battery, I tried the accessory circuit like they said and Im not getting any power to the compressor. And yes, I looked all around for a place to mount these damn horns and the rear was the only place they will fit. I looked in that spot right in front of the wheel, but they are just to BIG!
Pics are coming asap
__________________ 2005 Nissan Titan CC
Current Mods:
4" CST Spindles
NCD Leveling Kit
Bilstein Rear Shocks
HID Headlight Conversion
Front Window Tint
Train Horn
Exhaust Cutout w/ Electronic Switch
Light Bar
35x12.5x18 Nitto Terra Grapplers
After a quick Google search, found out it was a Bosch style relay. Thanks for the link. Im gonna try to find one local tonight and if not, just order it online. And thanks for the offer, but Im in Anaheim Hills... Not very close to SD
Current Mods:
4" CST Spindles
NCD Leveling Kit
Front Window Tint
Train Horn
Light Bar
i have my horns mounted under the bed where the spare tire was, the compressor is under the cab. very loud, hahaha. the place that installed mine just wired it to my factory horn. i can just tap the horn for a low "honk" in traffic and stuff but if you get on it WATCH OUT, hahahahaha
my compressor just went out tho but i have a lifetime warranty from the place locally that i got it so they have another on order for me. the only other issue i had was the clear plastic hose that came with it keps getting holes in it (not sure how) so i had replaced that a few times. i finally got an argon gas hose that is heavy duty rubber so i hopefully wont have hose issues anymore. just my .02
ps, i had the horns mounted under the cab but i could see if from the side and i didnt like that so i moved it to the back under the bed. hidden there. the only bad thing is that i had to remove my spare... oh well thats what roadside asst is for i guess, lol.
(Click Image for BIGGER View)
2007 Galaxy Black Crew Cab
Mods so far: Interior
2x Pioneer 10" Subs, 300 Watt Rockford Fosgate Amp, Pioneer 6x9,
JVC KD-LH910 Headunit, Ipod Interface, Tinted Windows Exterior
8000k H.I.D. Headlights, silver parklinglight bulbs, wireless keyless entry keypad, Armada AirDam, Tow Hooks,
"Line of Fire" LED tailgate lightbar, CHROME AUTOBOTS Emblem for grille & tailgate
152db Train Horn - SO LOUD hahahahaha
Torza Top bedcover, Thanks Krodad
2* Timing Advance
Stock AirBox Mod
murdered out all 3 tail lights
Ok, so first off, where is there an easy spot to go through the firewall? I found somewhere on the drivers side where the hood release cable goes through, but I can't get my hands anywhere near the hole to get a hold of the cable. Did you guys just make your own hole?
Also, I got the relay mounted. I have #85 to ground, #30 to the battery and #86 to the switch... # 87 has to go to the compressor, but there are 3 prongs for the switch. # 1 to ground, #2 to the relay and #3 to the compressor, so do I splice the #87 for the relay and #3 for the switch somewhere along the line? because there is only one wire coming off the compressor (besides the ground wire)
Hope that makes sense
Current Mods:
4" CST Spindles
NCD Leveling Kit
Front Window Tint
Train Horn
Light Bar
Yeah, I just removed the spare tire. I have roadside asst also, but Im just gonna keep the tire locked in the bed for know. If I get a flat, I dont want to wait, haha. And once I get the lift Im looking for, Im going to invest in one of the tiregates, so that should solve my problem
Current Mods:
4" CST Spindles
NCD Leveling Kit
Front Window Tint
Train Horn
Light Bar
I came up with a diagram to how i think it should be done... I want to add a on / off toggle switch to the horn, and to the compressor. I don't know if i need an additional inline fuse for both toggle switches? someone told me i might need a 5 amp inline fuse i dont know for sure tho... so here is the diagram i drew...
