Has anyone replaced their manual rear slider with a remote? #1 Where did you get the slider (manuf.)? #2 How did you implement the switch (location and wiring, etc.)?
I have a KC and want to replace my manual slider with a remote slider. Any aftermarket out there yet?
And to answer the original question. It'd be an expensive project. Not only do you need the new glass and all the mechanical BS that goes with it, but the plastic trim and carpet pieces are different too.
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government. - Thomas Jefferson
08 King Cab SE 2wd. 2* timing advance, S&B intake, TB bypass, 18" Magnaflow, TBS. Color matched and debadged. DR coilovers and custom upper control arms up front. Deaver mini pack and DR shocks out back. 305/ 65R18 BFG A/T's on stock wheels.
Thanks guys. I knew it would be a "project" for the reasons that have been stated. I dont think I will attempt this myself, but was looking for a place that would do the work, if it is even half way reasonable.
I didnt know if there were places to do this kind of work or not. I know for a long time, finding companies to do aftermarket moon/sunroof's was a needle in a hay stack. It appears the auto sliders are that way still.
you need to check yourself as i did answer part of his question.
How many people actually open the rear sliding glass and why...
PRG Performance Kit w/SAW's
Born 9/2004
