Old 02-18-2008, 11:01 AM   #1 (permalink)
WillieFlo's Avatar
How To Wire 3-100W Off-Road Lights on Same Switch??
Does anyone have a wiring diagram showing me how to wire up (1)-7" 100W ProComp driving light and (2)-7" Lightforce 100W(Each) off-road lights together on the same switch?
I have the following items already:
1 - LED rocker switch w/ inline fuse
1 - 40 amp lighting relay
1 - 30 amp lighting relay
8' of 10 gauge power wire
6' of 12 gauge power wire
8' of 12 gauge ground wire
Plenty of splice and male/female connectors of different varieties
Now, all I need is to know what wires to splice together, which relay terminal goes to which wire, etc., etc .......I'm not an electrical engineer......THANKS!!!
2008.5 Titan CC SB Pro-4X in Red Alert
-Rockford Fosgate Pkg.
-ProComp 6" Stage I Lift, ProComp Series 8089 Black Wheels, 35" ProComp Extreme AT's, ProComp Motorsport Series Light Bar, Lightforce Stryker Off-Road Lights, N-Fab Nerf Bars, Tinted Windows,Trailer Hitch, Rhino Sprayliner, Edelbrock SDT Muffler, True Flow Air Filter w/ Airbox Mod, Black HeadLight Mod, Door and Tailgate Chrome Emblems Blacked Out
Mods PLANNED :
2 MTX Amps, MB Quart Spkrs, w/ Bazooka Sub, Red LED's in Footwells, LED Interior Lighting, RattleTrap Sound Deadening
My TITAN website: http://www.cardomain.com/ride/2994384
My RUBICON website: http://www.cardomain.com/ride/654818
My Super Duty website: http://www.cardomain.com/ride/3007623
WillieFlo is offline   Reply With Quote
Old 02-18-2008, 11:52 AM   #2 (permalink)
loufish's Avatar
Re: How To Wire 3-100W Off-Road Lights on Same Switch??
See if this helps....
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 02-18-2008, 01:01 PM   #3 (permalink)
Yellomantis's Avatar
Here's another. Just swap in the correct size fuse for your application.
www.myspace.com/yellomantis
Old 02-18-2008, 01:32 PM   #4 (permalink)
vipzach's Avatar
Did you not like the answers you were givin in the other thread? How To Wire 3-100W Off-Road Lights on Same Switch??
ZlacherWhore™
Why is there never enough time to do it right the first time,
But always enough time to do it again?
vipzach is offline   Reply With Quote
Old 02-18-2008, 03:27 PM   #5 (permalink)
hey,my 2008 titan did'nt come w/foglights was going to buy the foglight kit w/the new headlight switch on column w/foglights.supplier says just plugs in.but what i want to do is tie in a couple of running lights into wiring on foglight kit when i wire it into foglight wiring. will this work? thanks tomcat
tomcat is offline   Reply With Quote
Old 02-18-2008, 03:30 PM   #6 (permalink)
ronmartin27's Avatar
Hey Willie. I met you at the 4Wheels Parts Grand Opening this past Saturday. Your truck looks great! Guess you picked up more goodies while out there with the great deals!
Good luck wiring those lights!
CHECK OUT: http://www.texasbabystore.com
White 2005 4x2 LE Crew Cab, Magnaflow Dual Exhaust, Volant CAI, 2 degree timing advance, 6.5" total suspension lift: CST Spindle Kit with PRG 2.5" Front Spacer, 4" rear blocks, Bilstein Rear Shocks, Hellwig Performance Traction Control Springs, 18x9 Moto Metal 956 Wheels, 35x12.50 ProComp Xtreme ATs, Custom Engine Cover, Black HID Projector Headlamps, HID Fogs.
ronmartin27 is offline   Reply With Quote
Old 02-18-2008, 06:22 PM   #7 (permalink)
WillieFlo's Avatar
Loufish/ YellowMantis,
Thanks guys, that's exactly what I was looking for to get this done!
RonMartin,
It was nice meeting you man! Sweet Black chrome wheels. I like your setup!
They had some great deals there on Saturday. Hope to see you at the Houston meet!
Mods PLANNED :
Old 02-18-2008, 09:25 PM   #8 (permalink)
loufish's Avatar
If you can find the factory fog light wire connectors, then yes you can install the new stalk and run relays off of that...That's exactly how my 3 lights are set up...
Born 9/2004
2002 Honda XR650R
Old 02-19-2008, 12:47 PM   #9 (permalink)
WillieFlo's Avatar
vipzach,
Thanks for the assist and the education on relays. The responses in the other thread were informative, but not what I requested. Loufish provided EXACTLY what I requested.
A 3 light setup is wired a little different and involves more components which is why I asked.
Mods PLANNED :
Old 02-19-2008, 12:58 PM   #10 (permalink)
vipzach's Avatar
Originally Posted by WillieFlo
vipzach,
No problem, I just didn't understand why you had duplicate posts. I think yellow's diagram would be easier. I don't think you need both of the relays, just the 40a should be enough.
ZlacherWhore™
Old 02-19-2008, 06:23 PM   #11 (permalink)
loufish's Avatar
You're correct, the 40 amp relay would be OK for three 100 watt lights...But I also ran two relays(like the drawing) so if I want to switch to 130 bulbs I'd have plenty of relay.
I made a custom mount to hold the fuse block, and then mounted the 2 relays just off to the rt side of the radiator.
how-wire-3-100w-off-road-lights-same-switch-lightbar-3.jpg  how-wire-3-100w-off-road-lights-same-switch-lightbar-4.jpg
Born 9/2004
2002 Honda XR650R
How To Wire 3-100W Off-Road Lights on Same Switch?? WillieFlo Titan General Discussion 4 02-18-2008 11:35 AM
4wd Switch Lights PRJ Titan Interior Discussion 10 01-27-2008 09:07 PM
Navigation VSS Wire Switch Blueshark Titan FAQ & Howto Area 22 12-12-2007 06:03 PM
Lights Switch GemInI Titan General Discussion 7 07-28-2004 05:37 AM
Anyone figure out how to wire fog lights to parking lights? newenglandtitan Titan Interior Discussion 9 04-19-2004 07:06 PM
