Go Back   Nissan Titan Forums > Titan Discussion > Titan Parts & Accessories
User Name
Password
Fog Light Mod Question? - being discussed at Nissan Titan Forums in the Titan Parts & Accessories section.
Old 04-14-2008, 05:51 PM   #1
chieflikalotapus
chieflikalotapus's Avatar
I have a 2006 se that is wired up to just plug in a set of fog lights. when you buy a new set of fogs it comes with a new switch for you to control your fogs? my question is do i have to buy the switch as well or can i just use the switch that i have on right now since im going to do the fog light mod and the fogs will come on with the parking lights now. or do i still need the new switch? again my truck is wired for fogs and no auto headlights
chieflikalotapus is offline   Reply With Quote
Old 04-14-2008, 05:56 PM   #2
blavis
blavis's Avatar
Send a message via AIM to blavis
Re: Fog Light Mod Question?
I might be wrong, but I think you will need to have the fog lights hooked up to a switch. The factory (non fog light) stalk/turn signal is not linked to the pre-wired fog light harness'. It is worth a shot though. I am sure there is a way to achieve what you want.
iWhore™
AKA BUDWhore™
IRC VK56 Member "Pit Crew Chief"
blavis is offline   Reply With Quote
Old 04-15-2008, 06:09 AM   #3
tomcat
if you buy the factory kit like from nissan parts or one of the other nissan supliers it will come w/a new headlight stalk to replace the old one.the new stalk will have the foglight switch on it.if you do a search under foglights you should see the suppliers of the factory foglight kit.i think they'll run about 150.00 dollars. tomcat
tomcat is offline   Reply With Quote
Old 04-15-2008, 06:26 AM   #4
grnTitan04
grnTitan04's Avatar
I am not completely sure that I understand your question, but let me swing anyway:
The purpose of the fog light mod is to allow you to either A:turn on the fog lights whenever you want or B:they come on with your parking lights. These are 2 different mods, the former requires more parts (a relay).
If case B is desired, nothing else is required (no extra switches). Just short the fuse and you are good to go.
If case A is desired, you need some kind of switch to pull on a relay, there are at least 2 options.
1: you can add a rocker or toggle someplace (easier to UnDo)
2: you can perform the stock mod, which allows your factory fog light switch on your stalk to turn on the relay (which in turn, brings on the lights)
Obviously, option 2 requires a stalk with the fog light switch already on it.
There are advantages to using the relay setup if you ever plan to add additional non-OEM fogs, you will already have the circuitry to pick up another relay.
Does this Help?
Improvements:
K&N Drop in, Magnaflow muffler, Step Tubes, Reese Hitch, Husky Liners, Nitto Terra Grapplers 285/70/17
Air Box mod, Improved Fog Light Mod, dba 4000 series rotors, Akebono ProACT pads, Extang RT Tonneau, RadFlo Remote Res Rears
Wish List: Bugflector, Air Horn, RadFlo 2.0 Coilovers, AEM Brute Force CAI, TruTrac, Bass boat...
Donations graciously accepted.
grnTitan04 is online now   Reply With Quote
Old 04-15-2008, 01:08 PM   #5
chieflikalotapus
Does this Help?
i am looking to do option B. fog lights on with the parking lights. so as i read i do not need a extra switch my factory turn signal would work just fine. the reason i ask i dont want to spend $150 complete oem set up. when i could spend $90 just for oem lights with out the switch. Is this correct
Old 04-15-2008, 01:30 PM   #6
vipzach
vipzach's Avatar
Yes, you could do it that way. I would still suggest using a relay and possibly a seperate switch. Just in case you ever wanted them off.
ZlacherWhore™
Why is there never enough time to do it right the first time,
But always enough time to do it again?
vipzach is offline   Reply With Quote
Old 04-16-2008, 09:04 AM   #7
grnTitan04
grnTitan04's Avatar
That's right.
And I agree with vipZach.
Check your state's web pages, as some states have laws against running 'adverse condition' lighting when the roads are Ok. Nobody needs a ticket.
Old 04-17-2008, 08:50 AM   #8
baseballfanz
baseballfanz's Avatar
To answer the original question
You DO NOT need to get a new stalk with built in foglight switch IF you're going to do the "jumper" mod.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
User Name
Password
Fog Light Question nightRider Titan Parts & Accessories 11 03-24-2008 10:52 AM
Fog Light HID question... pi3yeargrad Titan Parts & Accessories 46 04-08-2006 11:18 PM
Air bag light question baucus00 Titan General Discussion 2 01-30-2006 09:34 AM
Fog light question Burly Titan General Discussion 3 10-30-2005 02:14 PM
Another Fog Light Question goathead Titan General Discussion 0 07-05-2004 05:01 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
