Old 04-17-2008, 03:54 PM   #1 (permalink)
Power window motor
Hi, my driver power window motor will not come back up. Is there any aftermarket companys reblding these??? or is window motor on any other nissan vehicles. Thanks any info will help!
mkelee is offline   Reply With Quote
Old 04-17-2008, 04:28 PM   #2 (permalink)
JLG
JLG's Avatar
Re: Power window motor
Try banging on the motor before replacing.
JLG is online now   Reply With Quote
Old 04-17-2008, 05:10 PM   #3 (permalink)
Nissan Mike's Avatar
Probably just a broken regulator.Pull the door panel and take a look
Old 04-17-2008, 05:52 PM   #4 (permalink)
I pulled the door panel. The wiring is ok, nothing looks broken. over the last two days. it would go all the way up and back down partially.
Now it went all the way down I pulled the switch it appears ok the pass switch portion works.???
I can see where the motor is bolted on. I have no clue how to get it out.
Power Window Motor Removal and Install Buzzie8 Titan Interior Discussion 2 04-16-2008 10:10 AM
titan rear power sliding window new in box cab window morafamily@cox.net Buy/Sell 8 09-01-2007 06:35 AM
Replacing window motor Guiseppe Titan FAQ & Howto Area 2 08-22-2007 10:42 AM
window motor vs. window regulator? Pugsly Titan Problems & Dealer Service 2 05-03-2007 08:31 AM
3 Panel Power Slider Solar Glass(Power Rear Window) raskm Titan General Discussion 6 11-21-2004 09:26 AM
