Old 07-08-2008, 10:05 AM   #1 (permalink)
Angry Left 12v Power Socket
I'm having some issues trying to find out what happend to my 12V Power Socket on the Drivers side. My friend plugged in a power inverter on my left 12V power socket and for some reason the right one will not work anymore. All the fuses look good is there one under the hood i can check or is the Plug just bad.
strubedo is offline   Reply With Quote
Old 07-08-2008, 10:44 AM   #2 (permalink)
vipzach's Avatar
Re: Left 12v Power Socket
That seems odd! I am not sure if they are even supplied power through the same circuit. You realize that the passenger side socket is switched with the key...........right?
ZlacherWhore™
Why is there never enough time to do it right the first time,
But always enough time to do it again?
vipzach is offline   Reply With Quote
Old 07-08-2008, 02:56 PM   #3 (permalink)
baseballfanz's Avatar
The fuse for that outlet is #18, a 15 amp. It is the 7th from the bottom in the right column, in the fuse block at the right side of the dash.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 07-08-2008, 03:02 PM   #4 (permalink)
Quartz's Avatar
Baseball you never cease to amaze me. That is about as short, concise, accurate, and to the point as an answer could possibly be
Trailer Left Turn Signal/left brake light not working bclmread Titan Towing & Hauling 60 04-06-2008 05:43 AM
Front Left Noise upon turning left ? ? ? thedeer2 Titan Problems & Dealer Service 4 01-21-2008 02:13 PM
Bed Power Socket kit1612 Titan General Discussion 2 01-15-2008 11:20 AM
Does anyone know how to "relocate" the left power port elsewhere? decypher44 Titan General Discussion 6 03-08-2006 12:49 PM
Console power socket sndmn2 Titan General Discussion 9 06-01-2005 11:13 PM
