Old 04-20-2008, 09:11 AM   #1 (permalink)
2WD 6" Lift?
After looking at 4" it doesn't look like much of a difference. Any advice on who to look at for 6" lifts for a 2WD?
bonzai18 is offline   Reply With Quote
Old 04-20-2008, 10:37 AM   #2 (permalink)
hemislayer1's Avatar
Re: 2WD 6" Lift?
go with the prg kit. Friends dont let friends run fabtech.
hemislayer1 is offline   Reply With Quote
Old 04-20-2008, 11:44 AM   #3 (permalink)
Megw3788's Avatar
Send a message via AIM to Megw3788
Re: 2WD 6" Lift?
I recommend either the Spindles and a coilspacer for 6.5", or if you want to go the performance route get the Spindles and a set of C/Os for up to 8" of lift. The coilovers will also improve the ride on the street, as well as yielding a better ride offroad. Not to mention, these setups will look 100 times better than a bracket lift, they will be way easier to install/remove, and if you get the C/Os your truck will ride way better.
Megw3788 is offline   Reply With Quote
Old 04-20-2008, 09:56 PM   #4 (permalink)
loufish's Avatar
Re: 2WD 6" Lift?
2wd...Spindles for sure...You pick up ground clearence also.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 04-20-2008, 10:01 PM   #5 (permalink)
rtc1184's Avatar
Send a message via AIM to rtc1184 Send a message via Yahoo to rtc1184
Re: 2WD 6" Lift?
just me i went witht he fabtech 6" cause they have the tallest spindles of cst or procomp. you can get the 6 inch fabtech then get prgs upper control arms and c/o's and get a 10". get the deaver spring pack in the back with c/o's and it will be big then you can go 3 inch body if you want more height. i am in the process of new upper control arms and c/o's
"PIT CREW" 2007 KC 2wd White
modswanted: UPREV ECU FLASH
BIG BRAKE UPGRADE
STEEL BRAIDED BRAKE LINES
MASTER CYLINDER STIFFNER
REMOTE START
LINE-X
TRU-TRAC
REPLACEMENT BUMPERS
DANA 60
WINCH
LIGHT BAR
POSSIBLY 4-LINK THE REAR END
MODS DONE!
8000k HID CONVERSION LIGHTS, REMOVED ALL THE DECALS,TINT, CAI, STRAIGHT PIPE EXHAUST, AMERICAN RACING VICTOR TEFLON 17X8, 6" BASIC FABTECH LIFT, STACKED LEVELING KIT, 38.5x14.50x17 PRO-COMP XTREME AT'S, 3" BODY LIFT, HITCH, JENSEN IN DASH DVD 7" MP3/WMA/CD/, 1 - 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, TB COOLANT BYPASS, AXLE VENT MOD, 2* TIMING ADVANCE, BLACKED OUT CCFL HALO PROJECTOR LIGHTS, SUPERCHIPS PROGRAMMER, BLUE L.E.D. DOME LIGHT, CUSTOM MADE ROCK SLIDERS,
www.myspace.com/stuntin4alivin
rtc1184 is offline   Reply With Quote
Old 04-22-2008, 11:29 AM   #6 (permalink)
Re: 2WD 6" Lift?
What is the point of putting a 6" lift on a 2wd truck? I don't get it. Could someone explain this to me? Where can you go that you would need a lift but not 4WD?
'06 Galexy Black King Cab SE
jd4life2001 is offline   Reply With Quote
Old 04-22-2008, 11:36 AM   #7 (permalink)
Blackbeauty's Avatar
Re: 2WD 6" Lift?
Oh, don't start that crap again... PLEASE! If some 4x2 drivers want the look gained by lifting, let it be. There's no rule or even sensible reason why a 4x4 NEEDS to be the only thing that ever gets lifted. Broaden your mind, not just your typing skills....
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 04-22-2008, 11:39 AM   #8 (permalink)
Juday's Avatar
Re: 2WD 6" Lift?
You'd be surprised the places some 2wd vehicles can go. It all depends on the setup and terrain. Just look at many of the members who run theirs out in the desert who have 6" lifts.
285/70/17 BFGoodrich All-Terrain T/A KO
AEM Brute Force CAI
TomTom One XL Navigation
2* Timing Advance
PRG Shackles (Still need to install these...)
Old 04-22-2008, 12:37 PM   #9 (permalink)
import2nr's Avatar
Send a message via AIM to import2nr Send a message via Yahoo to import2nr
Re: 2WD 6" Lift?
interesting setup
never seen / heard of that one before
*2004 Galaxy Black SE CC
*Rockford Fosgate Punch 200 a4
*One 10" Kicker Comp down firing
*Omega MAX-E Remote Start/Alarm with pager remote
*ECO Systems Fuel Enhancer
*Volant PowerCore CAI / Ram Air Scoop
*AIRE TBS
*2 Degree Timing advance
*AT3030XL muffler / 3" exhaust piping from the STOCK "Y" back
*Hoppy EasyLift Tailgate Lift Torsion Bar
*Black Alteza style tail lights
*Lund S.S. bug deflector
*NCD 2" Leveling Kit W/ Bump Stops
*Nitto Terra Grapplers LT285/65R18E1
*Chrome Range Rover Fender Vents
import2nr is offline   Reply With Quote
Old 04-22-2008, 10:20 PM   #10 (permalink)
rtc1184's Avatar
Re: 2WD 6" Lift?
Yea From What I Have Talked To Greg At Prg, It Is Going To Be Pretty Nice. 1900 For The Uca's And The C/o's And Deaver Spring Pack
BIG BRAKE UPGRADE
REMOTE START
LINE-X
TRU-TRAC
REPLACEMENT BUMPERS
DANA 60
WINCH
LIGHT BAR
MODS DONE!
Old 04-22-2008, 11:18 PM   #11 (permalink)
loufish's Avatar
Re: 2WD 6" Lift?
I'll field this one...
I can't speak for others but for me it's NOT about lifting the truck. If you do the deserts of Kalifornia, AZ, NV and such it's about good wheel travel...
The lifting adds compression travel and the few good kits (PRG) are Performance orientated increasing total wheel travel while providing smooth damping. The lift spindles for the Titan provide a good base to build a performance suspension system including custom valved coil-over replacement shocks up front, reworked spring paks in the rear along with more custom valved shocks...
My 2wd would suck out Minnesota during the winter, but it does very well in the desert...
BTW...The performance kits ride and handle so much better then the "lift kits"...
Born 9/2004
2002 Honda XR650R
any picture of 6" lift or 2" leveling kit with 35" tires to compare high difference? d0va Titan Suspension 29 02-18-2008 10:02 AM
Difference between a 4" rancho lift and 6" procomp lift HDG Titan Suspension 16 02-06-2008 07:22 PM
6" lift,35" Grapplers,18" Teflons pics/video! jasonmotox Titan Wheels, Tires & Brakes 7 06-19-2007 10:45 AM
4" CST lift pics? or any 4" inch lift TheTanMan Titan Suspension 15 01-30-2007 10:28 AM
6" procomp lift, 18" stock wheels, pc 35" xtreeme tire question bighawaii Titan Suspension 11 12-14-2006 12:13 PM
