Hey guys. I just bought a 2005 LE 4wd OR CC (with only 12,600 miles!!) and I have noticed I think the previous owner was a smoker. It's really not bad at all but I can detect a hint of the smell and I went to check the cabin filter last week and to my surprise, there wasn't on in the box. I'm thinking the dealer took it out because it was saturated with the smoke smell and it made it smell worse and they were just too cheap to put a new one in. anyway, I ordered one off ebay yesterday and just wanted to ask if I'll lose a lot of air pressure (not blow as hard ) once I put the filter in. Thanks for the info guys! I've learned a TON already on here!!! GREAT SITE!
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
Honestly, I wouldn't run it without the filters in there. Mine blows just fine. I don't think it needs more, and I don't really think the filters impede airflow significantly. The allergen removal is worth it alone, to me.
Thanks guys. So you both have used the AC with no filter in vs with a filter and had no difference?
I ran mine for awhile without filters, and you are better off with the filters, but again really no difference in the way that the fan blows.
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
Plus, before you put in new filters vacuum out the fan housing.
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
Do these things really make a difference? 45k and I've not replaced mine yet.
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government. - Thomas Jefferson
Dumb question coming......where is the fan housing?
The slot where the filters go, is a good access point.
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
My truck never had the filters in it from the factory. I just bought them recently and put them in and made it a point to specifically check if they would impede air flow. There is hardly any flow difference at all with or without the filters.
let me be the first to say being in the HVAC trade, running any type of AC unit without a filter is a no no.
Automotive and or Home/business use the same basic design, and not having a filter to trap the dirt, hairs, alergens etc., it will just build up on the coil and cause your compressor to over work and or fail.
Buy the filters,change them they are the cheaper item to replace in the HVAC system
And the minor loss of air flow from the filter shouldnt be too bad that the normal person would notice.
2008 Blizzard SE KC
Volant CAI-Magnaflow Catback-2/3 McGaughy's-22" AR 311's w/Kumho 305/45's - 2* T/A
