Go Back   Nissan Titan Forums > Titan Discussion > Titan Parts & Accessories
User Name
Password
Volant LED Taillights Fix - being discussed at Nissan Titan Forums in the Titan Parts & Accessories section.
Old 04-26-2008, 04:41 PM   #1
RicRat
This is for those that have the Volant LED tailights.
I had a intermittent problem with 3 LED's going out, passenger side top left. If I thumped it on the side they would come back on, for a while anyway.
I figured it was a solder that had come loose, but didn't think I would be able to get inside to fix.
Well, I removed the taillight to have a look and see what it would take to get inside. It looked like the plastic cap was melted on and I would have to drill out the holes to break it loose. On inspection I found there where screws under rubber RTV. I scraped out the rubber, removed the screws and the cap came right off. I took the circuit board off the left side and wiggled the LED's and found the top one was loose.
Easy fix, just heat the solder up and done.
Lights work perfect now. So you can change individual LED's if needed.
Hope this helps someone with the same or simular problem.
Rat
RicRat is offline   Reply With Quote
Old 04-26-2008, 05:50 PM   #2
TitanBlue
TitanBlue's Avatar
Re: Volant LED Taillights Fix
Good post, great title! This should help a few, (since Volant is supposed to be so reliable, just a few!) Nice writeup.
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
Old 04-26-2008, 07:58 PM   #3
HRTKD
HRTKD's Avatar
I have the same problem. One row of LED lights won't work. Thanks for the tip! I'll give it a go instead of sending them back.
«ClearBra, Leer 100XQ, MM SI9500 Winch, Airaid TBS, Volant PowerCore, AMSoil in everything but the transmission»
«SAW Coilovers and rear shocks, PRG upper control arms»
Jim
Old 05-26-2008, 07:08 PM   #4
luvbelly
luvbelly's Avatar
I wonder if this would work for us poor folks who can't afford Volant tails and went Ebay. I have a set that currently has two rows out on the passenger side. I have already received a new set so I have nothing to loose in trying this. Thanks for the post. Great heads up.
2007 Titan KC SE 4x4 Majestic blue with popular package and utility bed option. Westin grill/brush gaurd, Westin nerf bars, Lund sunvisor II W/light kit, extang toneau cover, KC off road lights, vent visors,bug deflector, remote start, PRG leveling kit, Stillen SS dual rear exit cat back, AR Fuel 8 rims with 285-65-18 BFG AT KO's, K2 LED tail lights. Scottsbro23 custom engine cover
luvbelly is offline   Reply With Quote
Old 05-26-2008, 07:32 PM   #5
HRTKD
HRTKD's Avatar
Originally Posted by Carl
Dumb question mabe but what is RTV?
I believe that RTV stands for Room Temperature Vulcanizing. I use the Permatex Black RTV on the drain plugs of my differentials and transfer case.
User Name
Password
FS: Volant Vulite LED Taillights- MINT condition TypeR Buy/Sell 9 04-07-2008 07:51 PM
FS OEM taillights from '05 eat111 Buy/Sell 3 02-05-2008 12:47 PM
Volant TAILLIGHTS??? EVILKID Titan Parts & Accessories 8 08-13-2007 09:07 AM
New Help with LED taillights uinvme Titan Parts & Accessories 6 06-02-2007 06:46 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
