Im looking to make the back a bit darker and to tint the front the same, what percent should i go with to make the back darker? will they peel off the original and place new sheet or will they just overlay im guessing its somewhere between 30 35 right now?
2008 Nissan Titan Pro-4X
Crew Cab Long Bed
Stock For Now
The tint in the rear glass is actually in the glass itself and cannot be taken off. Since it's already "tinted" probably a real light percentage will make it darker. As to match the front, you'll really need to get the rear tint first than they can match. Check your local laws before making it too dark.
__________________ Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
I had all of windows done with 5%! The back windows are very dark! Since the rears are factory tinted, it will be hard to get an exact match on the front and rears! They will get close, be probably won't be an exact match!
ZlacherWhore™
Why is there never enough time to do it right the first time,
But always enough time to do it again?
49 20 77 68 6f 72 65 2c 20 74 68 65 72 65 66 6f 72 65 20 49 20 61 6d 2e
Eh down here in Cape Coral, Florida there pretty much is no law for tinting anything will fly, My dads H2 has 5 percent tints and never had a problem with it being too dark, but its impossible to see out of at night, Thanks for the help so they will just put a lighter layer over the original to see how it works and then well match the front, ive seen some people with 50% front window do you think that will make a difference
Crew Cab Long Bed
Stock For Now
Yea our other h2 we tried to get the back and front matched but it didnt work out you can hardly tell the difference but its there
Crew Cab Long Bed
Stock For Now
Anything on the front window will make a difference! Depending on the tint, they can get close, but definately not an exact match!
ZlacherWhore™
15% is the factory rear, had my fronts tinted to match....
it's gets too hard to see at night with really dark tint... i just like to have the windows match and found that driving with tinted fronts keeps my one arm from getting darker, and is really great for sun glare. i like it at night too, you don't have that annoying headlight glare coming in.. unless they have silver star bulbs.
I had my fronts done with 20% it almost matches the factory rears.
In certain lights you can tell that the front is aftermarket. from the inside if you stare hard enough the front looks darker.
the oem tinting is around 15-18%. add 35 to it and it will be close to 8%. i put a 4% strip and 45% on the windshield and it made my factory tint look more like 10%. may add more cause its hot as hell in florida.
2008 Titan XE KC Exterior:
DeBadged
6000k HID
Pro Comp Light bar w/9" Lights Performance:
K&N CAI
Gibson CatBack Exhaust Audio/Navigation:
Garmin Nuvi 205
Alpine IDA-X001
JL 300/4 Powering - 4 Polk Audio 6.5"
JL 500/1 Powering - 1 JL 10W3v3 Suspension/Wheels:
Total Chaos Upper Control Arms
4" CST Spindle Lift w/4" Rear Block
Sway-A-Way Coilover's (1" preload)
Sway-A-Way 2.25" Rear's (FOR SALE)
18" Black/Red Ballistic Offroad Jesters wrapped in 325/65 Terra Grapplers.
Yea thats where im at, crazy heat in Florida, I will probably go with what you did
Crew Cab Long Bed
Stock For Now
