Old 06-17-2008, 03:57 PM   #1 (permalink)
titaninak's Avatar
rear axle seals
I am getting trutrac installed on thursday, I bought some seals from the stealership, part number 43252-7S200< i bought 2 of them. is this the right seal and do I need both of them.
2006 LE, CC, BT, 4x4-Blizzard White
JBA catback, K&N cai, poweraid TBS, grounding kit, 2 degree timing, UpRev tuned, TruTrac
Debadged,4 piece billet grille, 20"Akuza wheels, tech12's w/ Memphis PR1-1000 amp / M-10's, Kenwood 7019 DD,DVD HU, Line of Fire LED light bar, LED third brake light, smoked tails, EFX HID lows and fogs, painted to match MADA air dam / inchannel window visors, Stillen Billet aluminum cap covers, 15% front tint, Non BT mirror swap. Truxedo lo pro tonneau cover
titaninak is offline   Reply With Quote
Old 06-17-2008, 04:00 PM   #2 (permalink)
bbomar's Avatar
Re: rear axle seals
How much did you pay?
And did you check with Dana to see if they have them?
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
bbomar is online now   Reply With Quote
Old 06-17-2008, 05:15 PM   #3 (permalink)
titaninak's Avatar
Re: rear axle seals
I paid 44 bucks apiece!!!!<dam nissan and their overpriced OEM parts. and did not check with Dana.
Old 06-17-2008, 05:21 PM   #4 (permalink)
bbomar's Avatar
Re: rear axle seals
Wow! Then I won't tell you what they go for on the net....
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
Old 06-17-2008, 05:38 PM   #5 (permalink)
titaninak's Avatar
Re: rear axle seals
c'mon bbomar, here in AK we take it in the shorts, i am guessing aroung 1/2 that price anywhere else, BTW these are the right seals.......right?
Old 06-18-2008, 08:23 AM   #6 (permalink)
Re: rear axle seals
I think you need to replace the axle bearings & bearing retainers to replace the seals. IMHO you should also use new carrier bearings.
http://www.trademotion.com/partlocat...=9&catalogid=1
In the picture at that link, I think 8 is the seal, 9 is the bearing, 10 is the bearing retainer and 11 is a snap ring.
I think you need to buy 8,9,10, and 11 for each side to replace the seals as you have to break the retainer 10 and split or press off the bearing to replace the seal.
Old 06-18-2008, 02:08 PM   #7 (permalink)
baseballfanz's Avatar
Re: rear axle seals
Actually when you take it in for the axle seal TSB, all these are replaced
.rear axle spacer (need Left and right) 43070-7S200
.rear axle bearing (need Left and right) 40210-7S210
.rear axle seal (need Left and right) 43252-7S200
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Rear axle seals leaks. Please report. Herbpov Titan Engine, Transmission & Drivetrain 278 11-06-2008 04:24 PM
Help With Replacing Rear Axle Seals george3111987 Titan Engine, Transmission & Drivetrain 24 04-08-2008 04:51 PM
leaking axle seals tnbowhunter Titan General Discussion 2 12-08-2007 12:51 PM
Now Rear Axle Seals KYDeepwater Titan Engine, Transmission & Drivetrain 1 08-20-2007 06:20 AM
'04 w/Leaking rear axle seals FarNorthTitan Titan Engine, Transmission & Drivetrain 5 04-09-2006 04:41 PM
