How to wire 55w fog lights/ use stock switch? - Nissan Titan Forum
Old 04-21-2009, 01:07 PM   #1 (permalink)
iTrader Score: 0 reviews
I have a set of ProComp Explorer 5" 55w fog lights that did not come with wiring kit. I want to use them in stead of the stock fog lights so that the column switch activates my new ProComps. I picked up a basic aux wiring kit at Autozone and a 4 pin 30 amp relay. How should I wire this up? From searching it looks like members have done something similar but I haven't found a diagram or info on how to tap into that switch.
O4 KC LE 4X4- 111K
Radflo 2.5/Bilsteins/Cortex/K&N/Magnaflo/ Undercover Tonneau/
Wrangler ATS/20x9.5 Konig CC
TTN4x4 is offline   Reply With Quote
Advertisement
Old 04-21-2009, 01:37 PM   #2 (permalink)
christo's Avatar
Re: How to wire 55w fog lights/ use stock switch?
so I understand correctly, you want to remove your current stock fog lights and wire the new procomp ones in?
If that's what you want to do, then I would just remove current fogs, cut the bulb harness off (so you can use later if you want to put them back on) and then run your wires from there to your new lights.
There might be a better way, but this is what i would probably do.
If you want to keep the stock fogs to work in conjunction with your new procomp lights. then you will need to run a relay (as you know already) and tap into one of the stock fog light power wires as your switch source, then just ground each light, ground the relay, and run a power wire to the relay from the battery with an inline fuse and you should be all set. This way all four of your lights would come on with the stock switch.
See the attached pic for the second mention install. pin 30 on the relay is 12v from the battery, pin 87 is the 12v to the lights (split this wire to both lights), pin 86 is your switched source, and pin 85 is a ground.
How to wire 55w fog lights/ use stock switch?-image-20fog-20install.jpg
07 XE CC....and well a few other things too ;-)
christo is offline   Reply With Quote
Old 04-21-2009, 01:42 PM   #3 (permalink)
DezertRunner823's Avatar
iTrader Score: 2 reviews
dang chris, didn't know you was a wiring genius! wanna hook up my 9" HIDs when i get em? off course i will compensate you for your time.
DezertRunner823 is offline   Reply With Quote
Old 04-21-2009, 01:47 PM   #4 (permalink)
Carbeaux's Avatar
iTrader Score: 6 reviews
I wouldn't suggest using the factory harness to run 55w bulbs. The stock bulbs are only a 37.5w bulb, so it might not be safe to run more through it.
If you don't have factory fogs and aren't going to have them (it doesn't sound like you do/are) then use what would be the output to the factory fogs as the trigger (pin number 86 in the diagram) on the relay. This will allow you to use the factory stalk switch for the fogs you're putting on.
Hook 'Em Horns!
"Life is a tragedy to those who feel but a comedy to those who think"
-Horace Walpole
Old 04-21-2009, 02:00 PM   #5 (permalink)
christo's Avatar
for hooking me up with the sticker, you name the place and time and I'll wire up anything you want! I wired in my stock fogs and you wouldn't even be able to tell that the factory didn't put them in. I've done lot's wiring jobs, hell i just put leds in my sons pinewood derby car (and he won best in show!). I'm also working on wiring in floor lights and puddle lights into my t.
Carbeaux has a point regarding the wattage, but the headlights have the same gauge wire as the fogs as best I can tell, so it should be ok - but it's your ride your choice.
check out this link and the bottom table as a reference for wire gauge size vs wattage vs length. http://www.rbeelectronics.com/wtable.htm
Old 04-21-2009, 02:50 PM   #6 (permalink)
daptech's Avatar
Originally Posted by Carbeaux View Post
I wouldn't suggest using the factory harness to run 55w bulbs. The stock bulbs are only a 37.5w bulb, so it might not be safe to run more through it. ......................
I used 885 50 watt bulbs for over two years with no problems.
2004 4x2 SE CC BT
daptech is offline   Reply With Quote
Old 04-21-2009, 03:56 PM   #7 (permalink)
TitanBlue's Avatar
iTrader Score: 3 reviews
2 55 Watters are still just a hair below 10 Amps Draw. Many have done the upgrade as daptech.
1 Disadvantage of using the OEM circuit, is that the Off Road Lights will only come on with Low Beams. The Fog Lights cut out when you switch on High Beams. On my previous vehicle, I used a Relay and tied into the High Beam to Activate them, for maximum brightness when needed.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG End Links, Street Traction Bars & Shackles, UpRev Osiris Tuner 93 Performance Tuned, 18" SE Rims, Functional Hood Scoop ...
MD Chapter Director
Old 04-21-2009, 07:37 PM   #8 (permalink)
Send a message via Yahoo to sportbiker929
i've wired in 2 55w hellas that use the fog switch and 3 55w hellas that come on with high beams.
its like daylight.
sportbiker929 is offline   Reply With Quote
Old 04-21-2009, 09:16 PM   #9 (permalink)
loufish's Avatar
iTrader Score: 11 reviews
I never had fog lights but installed the fog light stalk and used a (actually 2) relays to run my three 100 watt LaPaz lights.
I wouldn't use the factory fog light harness to run 55 watt lights either, I play it safe and use a relay.
People are correct when stating that the fog lights are turned off while using the high beam with the factory stalk, but I like it that way because it's a real quick way to shut down my off road lights. It may leave on my hi beams, but that's a big step down from my O/R lights for sure...
PRG Performance Kit w/SAW's
Rear Bumpy-Bumps
35" General Red Letter Grabbers on Pro Comp 1028 Wana-be Bead lock wheels
Born 9/2004
2002 Honda XR650R
Old 04-22-2009, 06:09 AM   #10 (permalink)
Thats right, I am using the procomps only in place of the stock fog lights in a KenMtn Bumper.
Thanks for all the help. I think I will use christo's diagram but use the white wire (output stock fogs) to pin 86 as carbeaux mentioned. The other wire that went to the stock fogs looks black so I am assuming that is the ground. Can I just attach the ground from my new procomps to the old ground for the stock fogs? I am trying to keep it clean and neat.
O4 KC LE 4X4- 111K
Old 04-22-2009, 06:13 AM   #11 (permalink)
Carbeaux's Avatar
I don't see any reason you can't ground them there. Good a place as any. Do the lights you're going to use actually have a ground wire? Many lights just ground through the base where they're attached.
Hook 'Em Horns!
-Horace Walpole
Old 04-22-2009, 07:11 AM   #12 (permalink)
The procomps have a red wire and a black wire. The black wire is just stripped, no type of connector on it. But the bumper has a bed liner coating on it, even if i scraped it away where the fog lights attach I don't think that would be sufficient ground. Would it?
O4 KC LE 4X4- 111K
Old 04-22-2009, 07:25 AM   #13 (permalink)
Carbeaux's Avatar
Since the lights come with a hot and a ground, no, it wouldn't do you any good to scrape stuff off the bumper. Use the black wire as your ground. You can take it to the harness or to anywhere that you can find a bare bolt that's grounded. The ground is usually easy to find a spot for that's convenient and unobtrusive.
Hook 'Em Horns!
-Horace Walpole
Advertisement
How To Wire 3-100W Off-Road Lights on Same Switch?? WillieFlo Titan Parts & Accessories 18 08-09-2010 05:28 PM
55W 8K HID Head and Fog Lights 22InchesStrong Titan Parts & Accessories 13 02-02-2009 09:57 PM
FS: fog lights no Switch thelatinpimp Buy/Sell 10 07-01-2008 04:02 PM
How To Wire 3-100W Off-Road Lights on Same Switch?? WillieFlo Titan General Discussion 4 02-18-2008 11:35 AM
Anyone figure out how to wire fog lights to parking lights? newenglandtitan Titan Interior Discussion 9 04-19-2004 07:06 PM
SEO by vBSEO 3.3.2
