TitanTalk.com is the premier Nissan Titan Forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 09-12-2009, 07:58 PM   #1 (permalink)
Burgy's Avatar
Send a message via AIM to Burgy
Air tank and compressor install
I bought a Viair 450C to install in the truck. I plan to run a small tank for air tools and eventually a horn and air bags. Originally I had figured there was room to install the compressor and a small 2 gallon tank under the truck. After taking a look, I'm not so sure, so I'm rethinking my options.
Worst case I could install the compressor in the bed storage bin on the drivers side. It would fit nicely and keep it safe. I found a 1/2 gallon tank that SHOULD fit somewhere under the truck, but haven't found a perfect location. Problem with that is I'd have to run power all the way to the back, would rather the compressor be closer to the front.
Anyway, I'm looking for ideas and thoughts.
Thanks!
Burgy
(Kevin)
08.5 Titan CC SE 4x4
Burgy is offline   Reply With Quote
Advertisement
Old 09-12-2009, 08:02 PM   #2 (permalink)
4mula1fan's Avatar
Re: Air tank and compressor install
Mount it where the spare is...It's about the only place!
TrainingWheelsWhore™
08 Pro 4X RED ALERT
Click here for mods
This is COOL!
My Pics
4mula1fan is online now   Reply With Quote
Old 09-12-2009, 09:28 PM   #3 (permalink)
RobKar's Avatar
I mounted mine in the bed of the truck along with a 3 gallon tank. I have a Retrax cover so its better protected. If you mount it under the bed be sure you use the snorkel.
The 1/2 gallon tank is WAY to small.
AKA TrollopInTraining™ AKA chinawhore™
2005 CC LE
100,000 Miles 6/10/2010
My wife thinks I spend to much on my truck!!
My Train Horn <-- Listen
UpRev Tuned!
RobKar is offline   Reply With Quote
Old 09-12-2009, 09:36 PM   #4 (permalink)
salstats's Avatar
Talking Re: Air tank and compressor install
yup that 1/2 gallon is wayyy to small if you run a train horn with that small tank it will sound like a QUIF.....lol
2008 SE 2WD:
PRO COMP Kit, PRG UCA, with Radflows 2.5 Externals sitting upfront at 9.5" and rear 3' with MX6 Rear shocks. Nitto Trail Grapplers 35x-12.5-17 Tires. PRO COMP ALLOYS SERIES 6005 rims. Injen CAI,
salstats is offline   Reply With Quote
Old 09-13-2009, 03:17 AM   #5 (permalink)
06_SMOKE_SE_CC's Avatar
can you post any pics of your setup?? i was looking at buying a tank/compressor setup for when i go offroading....
i'm a one man wolf pack....
MODS DONE:
cst 4" spindles, radflo 2.0 coilovers w/3" preload, deaver c-30 spring pack, sway-a-way piggybacks, aem bruteforce w/dryflow, cherry bomb extreme muffler, t-rex billet upper grille, 35" hankook dynapro mt's, truxport tonneau cover, pioneer avic-n2 nav unit with ipod integration, pacific audio steering wheel control adaptor, smittybilt sure step black side steps, DDM Tuning 55w 6000k HID lows
MODS WANTED:
prg mt kit, giant springunder conversion, atx mojave teflons, frp fenders, trutrac with 4.11's, mag hytec diff cover
06_SMOKE_SE_CC is offline   Reply With Quote
Old 09-13-2009, 08:35 AM   #6 (permalink)
RobKar's Avatar
I need to find the thread I posted years ago ... LOL
let me see if I can find it
2005 CC LE
UpRev Tuned!
The Following User Says Thank You to RobKar For This Useful Post:
06_SMOKE_SE_CC (09-14-2009)
Old 09-13-2009, 08:46 AM   #7 (permalink)
baseballfanz's Avatar
You can see the compressor in the side utility box in this video clip
VShortt's airhorns and air system. on a Nissan Tit - Car Videos on StreetFire
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 09-13-2009, 02:14 PM   #8 (permalink)
Burgy's Avatar
I prefer to keep my spare and I need all my bed space so its a no go for those 2.
If I decide not to go with the horns (OBA and lift bags are a greater need) then I could go 1/2 gallon I think. The complressor is a 100% duty cycle Viair.
Burgy
(Kevin)
Old 09-14-2009, 07:53 PM   #9 (permalink)
Crawl under your truck and have a look back near the spare tire. You'll see quite a lot of room that is available there. Its even high and tucked up enough that it should be shielded from road debris getting tossed up into it.
I found this "well" of space when I was crawling around under there trying to find a place to mount a spare battery.
It would be a good place to mount a fairly good sized tank.
Regards,
John
05 LE CC 4X4 - Red Alert w/every factory option
American Racing Chrome Chambers 17X9 Rims
Offroad/Big Tow
Damello Offroad Custom Rock Sliders
Retrax rolling bed cover
Bed Extender
Rancho 4" lift w/ PRG Traction Bars
Fox Coilovers & Total Chaos Upper A Arms & Deaver Leaf Spring Upgrade Pack
1", Billet block in rear w/Bilstiens
Defender Roof Rack w/6 offroad lights
Mile Marker Winch mount brush guard with Warn 9500 Ti winch
Bushwacker fender flares (black)
John Harden is offline   Reply With Quote
Old 10-06-2009, 10:45 AM   #10 (permalink)
Not sure if you have gotten what you wanted yet, but I have a 2 gallon tank and compressor mounted under the back seat (passengers side). Put both on a piece of diamond plate and added a wiring relay for ease of removal (without cutting wires each time). Here's my disclaimer: the air horn set up I bought was from Siege-Engineering. Less that a year old and the compressor won't fill past 110psi which means it will never shut off unless I turn it off. I'm very frustrated and their phone # isn't in service anymore! So I found they guys at Horn Blasters and ordered a whole new set up. It arrives Thursday. I'll follow up with a yes or no on the fit of the new equip. BTW - my setup is where the tank and compressor are seperate. (That said, mine are mounted next to each other, I bet if you get the combined set up, you can just mount it on it's side).
clvnshobbes is offline   Reply With Quote
Old 10-11-2009, 03:54 PM   #11 (permalink)
Rolex's Avatar
I run a fat 5 gallon air tank, but I know you can get a long slim tank that can fit inside the frame rail. Here's the link to my thread with pics:
on board air system + air horns w/PICS
I've aired up several tires on trucks and ATVs. I added a quick connect so I can run my air tools but haven't actually done it yet. Best of luck on the install.
The above post is my opinion....nothing more.
2008 Pro4X Big Tow, Prodigy brake controller, DVD, Navigation, leather, sunroof, Homelink, Nissan bug shield and sunroof shield, Nissan nerf bars, factory bed liner, utilitrack, BDPP premium tune, Injen CAI, PRG level kit, 33'' Cooper STT tires, UnderCover tonneau, KC Highlighter long range lights front, PIAA reverse lights rear, RF stereo + Tech12 box with 12" BMF sub and 500 watt RF amp, Whelen 150 dB electronic horn, Grover 1510 Stuttertone air horns with 5 gallon tank and Viair 400C compressor.
http://www.youtube.com/watch?v=gubPviSUToo
Rolex is offline   Reply With Quote
Old 10-14-2009, 03:43 PM   #12 (permalink)
Just posted a thread on my install. Mounted the compressor and air tank (2 gallons) under the rear bench. Wanted to keep it out of the Colorado elements.
Link: Train horn install with pics - Kept my Spare!
2006 Crew
2.5 in drop, AFE cai, TBS, 20's, Thorley LT's, Magnaflow cat back, UpRev, train horn
Old 10-17-2009, 07:56 AM   #13 (permalink)
doesn't those air compressor makes too much noise?where do u guys get ur stuff at?compressor,tank,etc...or do they come in kits
06 TITAN XE
SB INTAKE SYSTEM
6.5 inch ECLIPSE AVN30D W/NAVI
REAR VIEW CAMERA
2 7INCH HEADREST MONITORS
2 WAY PAGING ALARM W/2MILE RANGE
BIG TOW POWER HEATED MIRRORS
THROTTLE BODY SPACER
MBS PREDATOR WHEELS
22" MAGNAFLOW MUFFLER 2 1/2 IN/OUT
ISR-ILLEGAL SPEED RACING
PATRIOTS
EAC-ISR is offline   Reply With Quote
Old 10-17-2009, 09:07 PM   #14 (permalink)
Rolex's Avatar
I would think having any compressor inside the cab would be uber annoying. Many compressors are loud enough you wouldn't be able to talk over the the noise.
Old 10-19-2009, 08:48 AM   #15 (permalink)
Like I said in the install thread, it's not that bad. It only kicks on for 20-30 seconds. It's moderatly inconvienient - not so loud that you can't talk over it, but it is moderate. Again though, it only kicks on when I use it so I'm ready for it. If I'm using it for on-board air, I'm outside the truck and don't care. If I use the horn, I'm swearing at the clown that just deserved the blast or laughing at my buddies so it's no biggie then either. No disrespect to those that blast the random couple walking the street, but thats not my thing.
You can buy individual pieces or the entire kit from the folks at HornBlasters.com. Good group - very helpful and a great product.
2006 Crew
WTB Rear Air Compressor Rumplecat Buy/Sell 0 01-07-2009 09:51 PM
Air conditioner, compressor, drier. HELP!! blackblade Titan Engine, Transmission & Drivetrain 2 03-26-2008 08:22 PM
air compressor helomech Titan General Discussion 8 07-03-2007 08:29 PM
Hide Air Bag Compressor deebie47 Titan Towing & Hauling 4 06-12-2007 05:40 PM
Air Tools and Compressor Khamburg Off-Topic Discussion 9 02-26-2005 05:45 AM
