well, just installed the jba kit today, overall happy with kit and relatively easy to install. have one complaint, on the passenger side where it connects to the stock cat, the pipe wasn't quite long enough and at a bad angle. i had to really wank on it to suck it up to the collecter. subsequently, i have a small exhaust leak coming out of the collecter, i was planning on getting everything welded anyway so not a big deal, but still not happy. other than that system is good and sounds great, can't tell power yet because don't want to get on it till fix exhaust leak, it is before the o2 sensor and could throw off a/f mixture. keep updated after i get welded.
P.S. the stock exhaust is not too bad, except for the y-pipe, nissan put some thought into system, i wouldn't go to an aftermarket exhaust if looking for performance unless doing other mods to compliment. if want better sound, i'd reccomend the JBA, sounds good and certainly won't hurt power.
CC LE Smoke
JBA Cat Back Exhaust
K&N CAI
10" Fosgate He2
-Emerson
