Old 04-15-2004, 10:05 AM   #1 (permalink)
1BadTitan's Avatar
Custom Airbox???
Has anyone ever taken their stock airbox and used a holesaw to cut maybe 3 or 4 two inch holes in the back of it to gain airflow. I'm wondering about doing that and having my K&N filter, if it would show any type of gain. I know some honda guys do it, and it's done all the time on atv's. I'm not comparing our titans to hondas or atv's, but shouldn't the results be the same? And no, it's not any type of "rigging". I've seen it done alot, just wonder what it might do for the titan.
1BadTitan
BASICS: Black LE KingCab 4x4-Off Road Pkg-Utility Track Bed-Big Tow Pkg
EXTERIOR: 10,000K HID Headlight Conversion-AVS Bugflector II-Wade In Channel Rain Gaurds-Smoke Headlight Reflectors-Shaved Emblems-Painted Red Calipers-Smoke Taillights-Stainless Nerf Bars-Shorty Billet Antenna-20% Tint-5" Exhaust Tip-DIY Custom 3rd Brake Light-Tailgate Assist-Custom Home Made Hitch Cover
INTERIOR: Shortened Shifter-Nismo Pedals-Dynamat Everywhere-Factory Cointray-Carbon Fiber Accents
ROLLERS: Stock OR 17's With Nitto Terra Grapplers 295/70/17
ENGINE & PERFORMANCE: PRG Lift Kit-Nismo Billet Oil Cap-Platinum Terminals-Fram AirHog Filter-Slotted Cross Drilled Rotors
I.C.E.: Eclipse AVN2454-JL Audio TR650 6 1/2 Coaxials-JL Audio TR650 6 1/2 Components-Hardwired Radar Detecter-Add On Remote Start-MICRO Alarm
Other Rides: 05 Suzuki GSXR-03 Suzuki Quadracer LTZ-400
Old 04-15-2004, 12:32 PM   #2 (permalink)
Sammy Sandbag's Avatar
I did it on my Blazer by cutting about 5 holes in the bottom of the airbox using a drill press. The butt dyno couldn't tell a difference, but it might have added a tad more power. Of course, the blazer had a lousy mass air flow sensor and a bad intake through the gap between the head lights and turn signals. You might achieve better results with the Titan. The good thing about doing this mod is if you lose power, you can simply take some aluminum duct tape and seal off the holes.
-Counsel Yourself
Old 04-16-2004, 03:59 AM   #3 (permalink)
if you cut the holes on the grill side of the airbox and remove that flap of material to outboard of the windshield washer tank to let in more cold air from the grill, you might get a little more punch out of it....juma
Old 04-16-2004, 04:15 AM   #4 (permalink)
1BadTitan's Avatar
I did it last night at work. I installed the K&N and used a 2" holesaw to drill 4 holes in the bottom of the airbox. I also let the ecu reset. No one will believe this but it really works. Only downside is, its loud when you get into it. It almost sounds like there is exhaust already on it. It pulls harder through 1st and 2nd. The rest doesn't feel any different.
1BadTitan
Old 04-20-2004, 08:24 PM   #5 (permalink)
I finally got around to the ol' Sandbag mod too. I figured why not, if it doesn't work, I can still seal it up or even upgrade to a "real" CAI. Well I drilled several 1 7/8"s holes on the front side of the box. The butt dyno sez it moves out quicker, slightly but noticible. I'm still debating on whether or not to just cut the entire airbox from the round tube and install a K&N conical filter on it. It would be about a $50 mod versus $300. I just need to figure out what size inlet to get. The OD of the tube apears to be ~3", but that's just measuring with a tape measure from the box side. Does anyone have an outside caliper they can check the size with?
-Counsel Yourself
Old 04-20-2004, 08:56 PM   #6 (permalink)
If you wish to check out how others have gone about this here is a good site for the 4Runner. Further testing has provided some interesting findings regarding K&N & a few other after market induction products, still the information is specific to the 4Runner.
http://www.gadgetonline.com/airinduction.htm
KC/LE 4x2
Galaxy Black/Titanium
No-Tow/No-Offroad
G.Banks&Trux.cover
PRG. 2.5"F 1"R.
305/55/20 Nitto's TG
20x9MB Motoring Razor's Chrome
Optimist is offline   Reply With Quote
Old 04-21-2004, 02:02 AM   #7 (permalink)
measure the circumference and divide by 3.14 to get the diameter. a K&N will compress a bit if its a little bigger. juma
Old 04-21-2004, 04:53 AM   #8 (permalink)
I thought about doing that, but I'd really like to get as accurate a measurement as possible. K&N has a wide selection of inlet sizes, so I'd want to get it as close as possible. I also have to devise a way of supporting the filter to keep it from flopping around. I could fab up a heat shield, but I'm not all too convinced that they provide anything other than a support for the filter.
-Counsel Yourself
Old 04-21-2004, 11:16 AM   #9 (permalink)
Yes, I thought that the whole air box - filter arrangement was way too restrictive. So I took a piece of 12" PVC sewer pipe, connected it to the air pipe with a big funnel, then sawed a big hole in the hood and ran the sewer pipe out through the hood. Works great, nice sound. Sucks in a few birds now and then, but the 1" mesh screen I put in there catches them.
Then I got to thinking about the way too restrictive stock exhaust. I took a torch and cut off the pipe just under the driver's seat, and connected it to some flexible 8" galvanized and then cut a big hole in the floor and ran it up into the cab. If the fumes get too thick, I have to open the sunroof, but the sound is awesome!!!!
Old 04-21-2004, 11:24 AM   #10 (permalink)
OMG, you are way too funny. I think I just swallowed my tonsils!!!
Hampton Roads, VA
HDVa is offline   Reply With Quote
Old 04-03-2006, 01:30 AM   #11 (permalink)
TurboDieselTitan's Avatar
Location: Mission Viejo/RSM/Pomona (south orange county)
Re: Custom Airbox???
ahhahahahahhahahaha
TurboDieselTitan is offline   Reply With Quote
