Old 04-14-2004, 09:42 PM   #1 (permalink)
dd564's Avatar
Firing Order
Anyone know what the firing order is on the 5.6L?
2004 Titan 4x4 - SE Crew Cab - Galaxy Black
Tow Package
Utility Bed
dd564 is offline   Reply With Quote
Old 04-14-2004, 10:15 PM   #2 (permalink)
Sammy Sandbag's Avatar
Use the forum search feature. I did the leg work for you, just cause I'm nice.
Cylinder arrangement: V-8
Displacement: cm3 (cu in) 5,552 (338.80)
Bore and stroke: mm (in) 98 x 92 (3.86 x 3.62)
Valve arrangement: DOHC
Firing order: 1-8-7-3-6-5-4-2
Number of piston rings: Compression-2 Oil-1
Number of main bearings: 5
Compression ratio: 9.8
Compression pressure kPa (kg/cm2 , psi)/ rpm
-Standard 1,520 (15.5, 220) 200
-Minimum 1,324 (13.5, 192) 200
Differential limit between cylinders 98 (1.0, 14) 300
Exhaust valve open duration: 232 degrees
Intake valve open duration: 230 degrees
Intake valve open/Exhaust valve open overlap: 5 degrees
NGK Spark plugs Double Platinum tipped –
Standard Heat range: PLFR5A-11
Hot type: PLFR4A-11
Cold type: PLFR6A-11
Gap (nominal) 1.1 mm (0.043 in)
-Counsel Yourself
Old 04-15-2004, 07:18 AM   #3 (permalink)
dd564's Avatar
Thanks for the nice answer!
Tow Package
Utility Bed
Old 04-25-2004, 01:56 PM   #4 (permalink)
It's always the Army guy's that are the nice ones
FIELD ARTILLERY
KING OF BATTLE
NHTitan is offline   Reply With Quote
Old 04-25-2004, 02:06 PM   #5 (permalink)
FIELD ARTILLERY
KING OF BATTLE
Damn Gun Bunnies!
Army Aviation
Above the Best!
-Counsel Yourself
