Catalytic Converter? - Nissan Titan Forum
post #1 of 41 (permalink) Old 05-31-2010, 01:19 AM Thread Starter
iTrader Score: 0 reviews
Am i able to run 2 cats instead of 2 pre cats and 2 after (i have a 2wd) and have no sel, and where can i buy either replacement stock cats or cats that bolt to the headers and exhaust.
badt is offline
Advertisement
post #2 of 41 (permalink) Old 05-31-2010, 02:32 AM
Roll-Tide's Avatar
Re: Catalytic Converter?
2004-2006 4wd = 4 cats, you can remove (or gut) the two rear cats with no issues...just different sound and slight power increase
2004-2006 2wd = 2 cats below the manifolds, and 2 resonators in place of where the ^above rear cats are on the 4wd...you can remove the resonators, but i'm not sure how much that may change anything really
2007+ all have 4 cats, and you can remove (or gut) the two rears with no issues like the 4wd above...same results too
removing the front cats on any model with almost definitely throw a check engine light...but there are ways around that. others will chime in, deerslayer comes to mind...he just gutted his front cats and had some good results from it. myself, i have only removed the rears and had them replaced with pipe....noticeable sound difference, MAYBE a power increase...can't really tell.
2008 Titan Crew Cab SE 2wd -- traded for --> 2011 Frontier Crew Cab SV 2wd (Hypertech Max Energy)
Roll-Tide is offline
post #3 of 41 (permalink) Old 05-31-2010, 05:55 AM
O-FiveCC's Avatar
iTrader Score: 13 reviews
Search Walker Direct Fit b-pipes, you can replace your OEM b-pipe with cats in them with these Walker B-pipes that do not have cats. It will run you about $90 for the b-pipes
Sold2005 Crew Cab...13.735 at 99.15 NA and 13.338 at 103 100 shot
O-FiveCC is offline
post #4 of 41 (permalink) Old 05-31-2010, 09:09 AM Thread Starter
thank yall both this really helps!
badt is offline
post #5 of 41 (permalink) Old 05-31-2010, 10:49 AM
deerslayer's Avatar
iTrader Score: 11 reviews
I have no proof in a timeslip yet but gutting the fronts gave me more power. I can spin the tires from 25mph now. Before gutting them I couldn't. Did a 60-100 the other day and it pulled like a mofo the whole time. I'll go to the track soon and find out how much I gained.
2006 4X4 SE, 3.36 GEARS (GODZILLA TITAN)
Performance Mods:
4" PROTO4 CAI
07 Intake Manifold
Doug Thorley LT's
2.5"/3" Y Pipe Exhaust
E85 Uprev Tuned
170* Nissan Thermostat
Flex A Lite 4500 CFM Efan
IAT Resistor Mod
Throttle Body Bypass
Street Belt (Short Belt)
60' 1.85
1/8 8.65 @ 78.7 MPH
1/4 13.63 @ 97.8 MPH
deerslayer is offline
post #6 of 41 (permalink) Old 10-10-2011, 09:10 PM
Any updates on gutting the front cats? Does it bring up any codes or does it create any performance problems?
my5150life is offline
post #7 of 41 (permalink) Old 10-10-2011, 09:19 PM
CVTitan05's Avatar
iTrader Score: 5 reviews
What about in Cali? Can you remove the rear cats and pass smog easily? If so, why even have 2 more cats?
2005 Titan KC XE 2wd. Dirt King Mid Travel SOLD
2008 Titan CC XE 2WD. 2" Leveling kit.
2005 Titan CC SE 4x4 10" Lift.
CVTitan05 is offline
post #8 of 41 (permalink) Old 10-11-2011, 06:00 AM
iTrader Score: 4 reviews
I thought the peoples republic of Cali forbids messin' with the cats and backs it up with a visual inspection.
bestatchess is offline
The Following User Says Thank You to bestatchess For This Useful Post:
DRTYAZN (02-17-2012)
post #9 of 41 (permalink) Old 10-12-2011, 09:42 AM
Roll-Tide,
So just to be sure, you removed the rear cats on your titan and replaced them with pipes right? And you had no SES light or codes come up right? I want to gut my rear cats on my 4x4 but before I do it I want to be sure that there are people out there that have done this without any issues...
post #10 of 41 (permalink) Old 10-12-2011, 09:49 AM
You are right, but if you have the rear cats gutted they can't tell unless they remove the pipe and do a visual inspection of the inside and that just doesn't happen. The front cats, don't mess with those...
post #11 of 41 (permalink) Old 10-12-2011, 10:24 AM
OFELIPE's Avatar
iTrader Score: 3 reviews
also, in cali you cand find pleny of smog shops that will pass you no matter what if you pay a little extra. thought id throw that out there
StarvinMarvinWhore™
Tiny 2010 Jeep Wrangler Unlimited Rubicon
Natural Green
OFELIPE is offline
post #12 of 41 (permalink) Old 10-12-2011, 06:21 PM
Are there any threads/vids/pics on how to gut the rear cats?
If there's anybody that can screw a simple job up, it's me!
2011 PRO-4X CC FFV
Airaid MXP Intake
Flowmaster 50 Series SUV
3° Timing Advance
SakoHunter is offline
post #13 of 41 (permalink) Old 10-12-2011, 07:02 PM
OFELIPE's Avatar
google and the search bar are your friend!
StarvinMarvinWhore™
Natural Green
OFELIPE is offline
post #14 of 41 (permalink) Old 10-13-2011, 09:22 AM
Supporting Vendor
nightowl's Avatar
Garage
iTrader Score: 139 reviews
Or you can save your stock pipes and I can build you some pipes to delete the secondary cats. If you ever need to go back stock you can. Just wanted to run that by you.
YOUR CRACKED MANIFOLD ONE STOP SHOP
-CUSTOM BPIPES
-JBA HEADERS
-JBA CATBACK
-AXLE VENT KITS
-2.5" CAJUN Y PIPES
-VIBRANT ULTRAQUIET RESONATORS
-CUSTOM TUNING "NO DYNO NEEDED"
UPREV INFO-
nightowl is offline
post #15 of 41 (permalink) Old 10-15-2011, 05:10 AM
I have a 06 2wd I am about to do the exhaust. In all my previous trucks I have used flowmaster always been really happy with the sound but when I do the titan I want the sound and the power. Can I still stay with flowmaster? And what can I do with my cats to gain power as well?
Sent from my DROIDX using AutoGuide App
B06titan is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
catalytic converter issue jbracefan1977 Titan Performance Modifications 3 03-24-2010 12:39 PM
Catalytic Converter BlownTitan Titan Performance Modifications 38 03-06-2009 09:15 PM
Catalytic Converter Question Mars South Western Forum 17 09-12-2007 06:58 AM
Catalytic Converter Titan5683 Titan Engine, Transmission & Drivetrain 20 05-02-2007 09:28 AM
Catalytic Converter PrinceKheldar27 Titan Performance Modifications 1 03-13-2006 05:08 PM
You may post new threads
You may post replies
