TitanTalk.com is the premier Nissan Titan Forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 07-30-2010, 02:08 PM   #1 (permalink)
dubleedgeblade's Avatar
Headers made my truck slower!?!?!?!?
Alright I have been dealing with this for a while because I have been swamped at work. Around Thanksgiving I installed a BD PP (set to regular tune w/ 2* advance and wot mod), injen intake, and added new magnaflow cats and magnaflow 18" muffler to stock pipes. So the truck was bad a** and I was really happy with the feel and response! Christmas rolls around and my girl gets me DT shorties installed, my truck now sounds sick. However I feel a lull in power off the line and it just doesn't feel rightand it seems like it takes longer to shift. Am I over reacting here or is this something that other people have dealt with. Is the air to fuel ratio out of wack or what?? I thought maybe new gears or an upgrade to Uprev tune would help. I have too many mods to my truck to not be happy with it!!! Any and all suggestions would be greatly appreciated....
Thanks
Ricky
RICK DADDY
Exterior Mods:
18" SE wheels
325/60-18 Nitto Terra Grapplers
2" Rough Country Leveling Kit
Performance Mods:
18" Magnaflow w/ stock pipes
Doug Thorley Headers
Injen Intake
Bully Dog Power Pup
Interior Mods:
500.2 Kicker amp
2 - 6x9 Kickers
2 - 6.5 Kickers
500.1 Kicker amp
2 - 12" Kickers
Pioneer Head Unit
dubleedgeblade is offline   Reply With Quote
Advertisement
Old 07-30-2010, 02:15 PM   #2 (permalink)
Re: Headers made my truck slower!?!?!?!?
Try resetting the ECM.
--David
2005 Deep Water Kingcab 4x2 XE
Volant CAI
NCD 2.5" Leveling kit
More to come...
wguy00 is offline   Reply With Quote
Old 07-30-2010, 02:19 PM   #3 (permalink)
O-FiveCC's Avatar
All you really need is an Uprev tune. Headers make a huge difference on this truck, you should notice a lot more performance. Your AFR is probably way off and you need a good custom tune
Trans-Go reprogramming kit, AEM Brute Force, JBA w/ 22" Mag, no cats, 07 intake, Tru-Trac
Nismo SS gauges, DDM HIDs (headlights and fogs, 8k), 9" TV, tinted tails, headlight mod, Graphite OEM 20's wrapped in Yokohama Parada Spec-X's, Graphite engine pieces, Armaden LED's all over, 2" Springtech shackles, Armada airdam
O-FiveCC is offline   Reply With Quote
The Following User Says Thank You to O-FiveCC For This Useful Post:
Misfit (07-30-2010)
Old 07-30-2010, 05:29 PM   #4 (permalink)
deerslayer's Avatar
The headers moved your power band higher up in the rpm's. You should feels more power after 3500 rpm's. If it's slower off the line I'd say it's not much. Your AFR if anything would be a little leaner but that wouldn't make it slower IMO.
Sell the PP and get a BDGT to be sure, or just go get a dyno with AFR numbers before you spend over $500 on a custom tune.
06' SE KC (4X4 Track Edition), FFV, Big Tow
IRC VK56 Southwest Ohio
PERFORMANCE MODS:
BDGT 93+4* AFR Low 12's
No Cats
2.5" B-Pipes
Flowmaster Y
3" SI/SO Bullet
S&B CAI With Ram Air Mod
Burnout Mod
14.271 @ 93.50 mph before gutted cats & 2.5" B-Pipes in a 83 DA
14.47 @ 93.77 after I gutted the cats and 2.5" b-pipes in a 3100 DA
"The Bullsh!t stops when the 3rd yellow drops!"
Exhaust cutouts:http://s145.photobucket.com/albums/r...austcutout.flv
Titan VS modded 5.0:http://s145.photobucket.com/albums/r...tamodded50.flv
Bullet:http://s145.photobucket.com/albums/r...letmuffler.mp4
deerslayer is offline   Reply With Quote
Old 07-30-2010, 05:49 PM   #5 (permalink)
you have almost the exact same setup as me... and i noticed the same exact thing. well after a while i realized what dearslayer means, its more power higher up. Also, my spark plugs were filthy, i changed them when i installed nitrous and then i noticed a HUGE difference so it might be a good idea to check your plugs. anyway im getting uprev on mon il see if it was worth it.
titantriper06 is offline   Reply With Quote
Old 07-30-2010, 06:35 PM   #6 (permalink)
O-FiveCC's Avatar
When I installed headers, my power from 0 mph felt like it doubled. For me, I had a large increase in power from 0 all the way up, not sure if the Nismo's where just that much better or what.....You shouldn't be losing power down low with stock b-pipes, and stock exhaust pipes.
Old 07-30-2010, 09:07 PM   #7 (permalink)
firelife25's Avatar
what all do you have done to your truck? never see you post on here...do you race your t? if so why not come to the race meets we have?whats your 1/4 mile times
SOCAL VK56 CREW CHIEF
IRC VK56 PIT CREW CHIEF
2008 XE CC LWB
firelife25 is offline   Reply With Quote
Old 07-30-2010, 10:02 PM   #8 (permalink)
DanBlp's Avatar
What is your O2 sensor situation with the shorties? What are your WOT AFRs?
Shorties are tailored to bottom end so you should not be losing power off the line post install. Without answers to the questions above, I would guess that post header install, you mixtures are jacked up; most likely due to O2 sensor placement and/or connection and/or functionality and/or existence in your system. Being an 07', your rear O2 sensors are very critical.
2006 Titan
Performance Mods
Uprev, JWT S7/S2 Cams, DT LT Headers, Stillen B-pipes, Modified Nismo CB w/(2) Aero Chambers, Volant Power Core with Ram, TrueTrac, 08' Manifold, TransGo Shift Kit, Stillen Radiator, Stillin Grounding Kit (free with radiator...)
Suspension and Handling Mods
Nismo 20x9.5s w/ 305/50VR20 Yokohama Parada Spec-Xs, Springtech Drop Leafs + (2) leafs from a Deaver C-10, 07 4x4 coils, Belltech Street Performance +/-2" in Front and Belltech Street Performance lowering shocks in the Rear, Hellwig rear sway bar, 08 front calipers, 14" CD Front Rotors, EPC greens F&R
Audio/Video Mods
M&D OVHD DVD, Infinity Kappas in doors, Kicker 10's w/ Fosgate P300, Bel RX-75 Pro Plus detector and jammer
Cosmetic
Armada air damn, Bak tri-fold bed cover, ATS Flares, DDM HID Lows & Fogs
Up Next
Nav Head Unit
____________________________________
"History does not long entrust the
care of freedom to the weak or the
timid."
Dwight D. Eisenhower
DanBlp is online now   Reply With Quote
Old 07-30-2010, 10:28 PM   #9 (permalink)
im all about racing my truck, in fact just 15 mins ago i did my last run at qualcom stadium, its not much an 1/8 mile but its all i can get. right now i got nitrous injen cai, jba headers and uprev arrives on mon. and i do have a thread asking if anyone wants to race with me at qualcom. theres no 1/4 near sd.
Old 07-30-2010, 10:41 PM   #10 (permalink)
DINSTAAR's Avatar
I had the same problem when I installed my DTLTs. Along with the header install I put in walker direct bpipes also so I have no cats or resos. Anyway, with no BDGT tune my AFR was all jacked up...I had NO power. With the BDGT my AFR was good but by the time I got it installed, I already had uprev on the way. Now with only the base tune using 89 oct...uprev blows BDGT out of the water. I still haven't got to do my 0-60 runs since they fixed my base tune so really...I'm untuned still. The GT will do it's job, but with uprev...all I can do when I gun it is smile and make sure I say on the road.
P.S. I did lose bottom end but what I picked up above 3k makes up for it and more.
DINSTAAR is offline   Reply With Quote
Old 07-30-2010, 10:42 PM   #11 (permalink)
pd298's Avatar
Sounds like driver error to me!! lol jk
2007 Silver SE 4x4 Crew Cab
Dual Flowmaster 40 series, AEM Brute Force, 5% Tint all the way around, PRG Mini Lift 2"/1.5", 33x12.50x20 Toyo MT's, Eagle Alloy 20's, 2* advance, Hella 500ff's, BullyDog Triple Dog GT, RE SE 10's, Tech12volt ported FF box, kicker kx1200.1 amp.
pd298 is offline   Reply With Quote
Old 07-31-2010, 12:32 AM   #12 (permalink)
import2nr's Avatar
Send a message via AIM to import2nr Send a message via Yahoo to import2nr
You need a tune .. Afr's are probably out of whack.
Best dyno #'s to date on 87 map 06/17/10 (@ Murillomotorsports w/ Pulstar Iridium plugs and Aero STX603 muffler being the only difference from the last Uprev dyno) 284hp & 376tq
***Uprev Dyno Tuned 87 octane on 04-10-2010 @ 273.75hp & 346.19tq***
***Dynod before headers & B-pipes 93 octane on 02-14-2009 @ 272hp 334tq***
*2004 Galaxy Black SE CC*
*Rockford Fosgate Punch 200 a4*
*One 10" Kicker Comp down firing*
*Omega MAX-E Remote Start/Alarm with pager remote*
*Volant PowerCore CAI / Ram Air Scoop*
*AIRE TBS*
Uprev Dyno Tuned
*Doug Thorley LT Tri Y's*
*Stillen B-pipes with Magnaflow cats*
*Exhaust-Gibson Y-Pipe with Flowmaster resonator going into Aero Turbine STX603 to stock pipes after muffler*
*Hoppy EasyLift Tailgate Lift Torsion Bar*
*Black Alteza style tail lights*
*Lund S.S. bug deflector*
*NCD 2" Leveling Kit W/ Bump Stops*
*Ikon shocks with 1" block in the rear and Bilstein 5100's in the front ( adjusted to middle notch)*
*Nitto Terra Grapplers LT285/65R18E1*
*Chrome Range Rover Fender Vents*
import2nr is offline   Reply With Quote
Old 07-31-2010, 06:24 AM   #13 (permalink)
DanBlp's Avatar
DINSTAAR, you are on the right path. You will be pleasantly surprised to find out that when UpRev gets your tune right, then your truck has about 2 weeks to learn it (depending on driving style and distance), your bottom end should come back. Though your LTs are more tailored to mid and top end, you really shouldn't loose bottom end once everything is dialed back in.
Old 07-31-2010, 01:32 PM   #14 (permalink)
b2sdad's Avatar
great info guys! cant wait for my uprev!
b2sdad is offline   Reply With Quote
Old 08-01-2010, 05:55 PM   #15 (permalink)
See this is why I like this site, you ask a question and you get intelligent feed back. Lots of useful info! Looking back I would have been happier leaving the headers off, IMO. I am sure I will change my mind after I upgrade to Uprev!! I do feel strong in higher rpms but s*** if i can't smoke em off the line, whats the point???? Like I said thanks guys ... much help!
RICK DADDY
Exterior Mods:
18" SE wheels
Performance Mods:
Injen Intake
Bully Dog Power Pup
Interior Mods:
500.2 Kicker amp
2 - 6x9 Kickers
2 - 6.5 Kickers
500.1 Kicker amp
2 - 12" Kickers
Pioneer Head Unit
My truck and I made up JoeyCrack Titan General Discussion 15 02-27-2010 05:19 AM
my truck made famous by google...kinda phrainq Titan General Discussion 11 10-10-2007 01:23 PM
My Titan Has Made Me a Truck Snob HairyBee Titan General Discussion 19 11-17-2006 08:32 PM
Did Exhaust Make My Truck Slower mikus motorsports Titan Performance Modifications 15 11-07-2006 04:19 PM
Who made the Switch from another truck to a TITAN? HyperSportRacing Titan General Discussion 40 11-10-2005 08:14 AM
