emissions leak - Nissan Titan Forum
post #1 of 9 (permalink) Old 02-18-2011, 10:25 PM Thread Starter
iTrader Score: 0 reviews
emissions leak
Today my SES light came on so I stopped by the local advance auto to get the code checked. They told me it was a leak in the emissions somewhere. What is the best way to check the system to find the leak so I can fix my problem?
Thanks
NCTitan1123 is offline
Advertisement
post #2 of 9 (permalink) Old 02-19-2011, 12:54 AM
Re: emissions leak
Do you hear a ticking noise when your truck is running. I had the same problem with my truck last week. I took it in and it turned out that my exhaust manifolds were cracked. They have have an extended emissions warranty of 8yrs / 80,000 miles. I would just take it to the dealership and have them check it out if you are still under the warranty, or you can just start and one end of the exhaust while the truck is running, and put your hand about an inch from the tubing and see if you feel air do this for the entire exhaust.
Swagg26 is offline
post #3 of 9 (permalink) Old 02-19-2011, 01:00 AM
iTrader Score: 4 reviews
Re: emissions leak
What was the exact code?
bestatchess is offline
post #4 of 9 (permalink) Old 02-19-2011, 06:16 AM
NBhunter80's Avatar
Re: emissions leak
If your ses light comes on again, you can find out what the code is by performing a simple procedure by yourself. Here's a link to the thread explaining how to read the code and reset your ses light.
http://www.titantalk.com/forums/tita...ses-light.html
I have used this many times to clear the pesky evap valve code p0455. It sounds like they might be referring to the evap canister leak code. It is common for the valve to get gunked up, especially if it freezes and thaws alot and lets dirty water melt down into the valve, throwing the code. Usually you can just clear the code and all is well, but if it gets bad and you can no longer put gas in your truck then you might have to clean it out or replace it. Use the search and I'm sure you will find lots of threads about this issue.
2005 Titan LE King Cab 4x4 Offroad Big Tow FFV.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, LT315/70r17 Kelly Safari TSR tires on OEM OR 7-spoke 17" rims, Rough Country 3" lift, 1" rear block, Bilsteins 5100s front and rear, 2011 Pro4x rear end, Axle vent mod, 2 degree timing advance, NGK Iridium spark plugs, Stock Airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top D34 battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
2012 Nissan Rogue SV AWD - Wife's ride
NBhunter80 is offline
post #5 of 9 (permalink) Old 02-19-2011, 06:46 AM
sampsonator's Avatar
Re: emissions leak
IF it's the same code I've been gettin it's probably a p04##. The nomenclature bully dog tells me for my specific code is something to the effect of "Evap emission control (large leak)" which is a p0455. Try tightening or replacing your gascap.
05 4x4 CC LE
BDGT
Banks Monster exhaust
Airaid CAI
2° Timing advance (courtesy of gweasel)
Billet grill with custom emblem
Tinted Brake Lights
Headlight Mod
Armada Air Dam
2 JL 10W0 powered by kenwood 1k
"If you can't dodge it; you're too slow."
"Rice hunt this."
sampsonator is offline
post #6 of 9 (permalink) Old 02-20-2011, 09:05 PM Thread Starter
Re: emissions leak
Appreciate the replies. I haven't heard a ticking when i start it up and it was the p0445. I'll try clearing the code and see what happens. Also where is the Evap canister to clean it?
Thanks
post #7 of 9 (permalink) Old 02-20-2011, 09:14 PM
post #8 of 9 (permalink) Old 02-20-2011, 09:31 PM
caneman88's Avatar
iTrader Score: 1 reviews
Re: emissions leak
Got this in the mail a couple weeks ago from Nissan
2007 Texas Titan UpRev Tuned- 22" Magnaflow - Nismo Intake-Stillen Big Brake System
caneman88 is offline
post #9 of 9 (permalink) Old 02-20-2011, 09:37 PM Thread Starter
Re: emissions leak
Thanks, im going to try to figure it out sometime tomorrow then
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Evaporative Emission System leak Detected, (Large leak) jessestylex Titan General Discussion 11 07-13-2011 07:42 PM
Emissions warranty help brentburgess171 Titan General Discussion 2 04-16-2010 06:22 PM
emissions risingsun Titan Performance Modifications 8 11-17-2008 02:00 PM
Emissions leak djmars20 Titan Problems & Dealer Service 5 09-07-2008 09:56 PM
Emissions?? Jesterman Titan General Discussion 4 02-02-2005 10:24 AM
You may post new threads
You may post replies
