Old 06-27-2004, 09:34 PM   #1 (permalink)
radar hardwire
1. Remove overhead console. Five screws then pull down carefully - snaps in.
2. Locate tape wraped wire running side to side , ( see photo ).
3. Splice in wires from radar cord. I also cut the coiled part of the cord off and used the red and black wires in photo.
4. Run the wire under headliner and out at windshield.
5. Remove telescoping channel that runs from headliner to mirror mount, (see
photo), by sliding upper portion down over lower portion. Snap tabs at
mirror mount I think but I didn't remove when writing this.
6. Make sure you have enough cord from channel to radar unit and place radar detector onto windshield. Make sure that you can see it's display around the mirror from your driving position and that sunvisor and extender will open. Also make sure your not pointing the detector into black grid in windshield and hiding your signal.
7. Re-assemble
Now everytime you open your door you will hear detector come on,if it's like my Cobra you'll hear system ready as you get in.
DRIVE CAREFULLY!!!!!
radar-hardwire-oh1.jpg  radar-hardwire-oh2.jpg  radar-hardwire-oh3.jpg  radar-hardwire-oh4.jpg  radar-hardwire-oh5.jpg
Old 06-27-2004, 09:56 PM   #2 (permalink)
Send a message via AIM to Keven
Excellent information, greg ... many thanks! Someone else suggested this to me when I was inquiring about hardwiring my V1. I decided it best (being I'm blonde at this stuff) that I take it in and let a pro do it for me. He wired directly to the fusebox and just ran the wire up the A pillar and under the headliner. It's a pretty clean install and makes use of the V1's inline fuse.
Thanks again! I learned much here.
Keven
2004 Titan Crew Cab LE 2WD
Deepwater Blue/Graphite-Titanium
NavSystem and stuff
Vortec Dual Exhaust
Keven is offline   Reply With Quote
Old 06-27-2004, 10:09 PM   #3 (permalink)
The thing I like about this is it shuts off with the auto power down of the truck so I never have to turn it off.
Old 06-28-2004, 07:07 AM   #4 (permalink)
I did the same thing. My radar detector turns on when the car starts and shuts off when the car is turned off(Passport 8500). By going to the fusebox, you can have whatever you want. Whatever way you want to go should be fine. It took me about 15 minutes to run the wire as mentioned above.
2004 Deepwater 4x4 SE CC, Born on 03/22/2004 2:34pm, Popular w/bench, OffRoad, Big Tow(VDC), Utilitrack, Sliding Bed Extender, Splash Guards, Mats, Step Rails, Hood Protector, K&N Air Filter
Dude is offline   Reply With Quote
Old 06-28-2004, 11:46 AM   #5 (permalink)
My RX65 uses that stupid "smart cord" like a telephone wire. I am pretty sure I can find the right wires to use and just use normal phone plug and wire, but I'd hate to mess it up. And the cig. plug also has controls and lights on it... I don't mind the chord so much..
BTW, the POP sensor works VERY good on this unit.
bvstone1 is offline   Reply With Quote
Old 06-28-2004, 05:45 PM   #6 (permalink)
FLfinfan's Avatar
Good info, thanks!
FLfinfan is offline   Reply With Quote
Old 06-29-2004, 05:13 AM   #7 (permalink)
love1u0's Avatar
Send a message via MSN to love1u0
This post would be good in the FAQ/Howto Area.
2004 Smoke SE CC 4x4
Off Road
Big Tow
Custom 3" exhaust system
1 Flowmaster 40 series
2008 Xterra Off Road
love1u0 is offline   Reply With Quote
Old 06-29-2004, 05:41 AM   #8 (permalink)
So does mine. The cord merges into standard wires after about the first foot(from the telephone wire to the regular 2 wires). I simply cut off the cigarette lighter plug and connected the ground, and then connected the hot wire to the fuse box.
Old 06-29-2004, 09:41 AM   #9 (permalink)
The funny thing is, you can buy a hardwire kit for $30. IT's just standard phone wire. I even tested the plug. I opened up the cig plug to find which wires are ground and 12v.. pretty easy to do. Maybe I can move the LEDs and mute button from the cig plug to somewhere else on the dash, or maybe a switch blank. That would be pretty cool.
Old 06-29-2004, 03:27 PM   #10 (permalink)
I just did this and the wires I found that you said to use were always 12v... didn't do anything with the doors. Are you sure your detector doesn't just autopower off after a certain time (sensing voltage drop, ie car not running).
I tested first, but used them anyway. May move them and just rund the power lines to the fuse block.
Old 07-01-2004, 12:14 PM   #11 (permalink)
ZIPPY's Avatar
How are you guys hooking into the fuse box? I have my wire ran that far but don't want to screw it up now.
ZIPPY is offline   Reply With Quote
Old 07-01-2004, 01:23 PM   #12 (permalink)
I simply wrap the hot wire around 1 end of the fuse I choose to use and push it back into the fuse box. I usually wrap it around twice. I ran the ground to one of the bolts in the door if I remember correctly. I always connect to a fuse that is not hot unless the key is turned on. This way my detector turns off when the car turns off and turns on when the car turns on.
May not be the best way, but I have been doing it this way for about 15 years and never once blown a fuse or had a problem of any kind with my electrical system.
Old 07-04-2004, 06:45 PM   #13 (permalink)
Wrap a 12+ wire around a fuse blade? Ummm, try some insulated connectors before you actually have a problem!
Swankmonkey Racing
syntrix is offline   Reply With Quote
Old 07-05-2004, 02:14 PM   #14 (permalink)
pciley's Avatar
12+?? the wires inside the cord on my radar detector can't be heavier than 18 guage. Looks like what's INSIDE the phone line if you cut it open. Really tiny wires. Would fit fine on a fuse blade, but still wouldn't do it.
Just splice into an ignition-hot wire. Use the probe on your multitester to find one. The easiest is the cigarette lighter outlet that is NOT always hot. The passenger side 12v outlet is only powered when the ignition is on.
I also ran from under the dash, up the pillar, under the front of the headliner, and down the mirror channel. Looks/works great. Probably takes no longer than 20 minutes if you have NO idea what you are doing.
KC XE Smoke
Old 07-08-2004, 09:38 AM   #15 (permalink)
mine did the same thing
miniracer26 is offline   Reply With Quote
