Radar Hardwire (my version)
So I wanted to hardwire my bel rx65 and after reading the other posts, decided to make a project of it.
Instead of a normal 2 wire power/ground plug, my det uses a "smart plug" that is essentially a 4 wire telephone plug. 2 wires for power/ground, and two more than control the functions on the cigarret plug. 1 led for power, 1 led for "warning", and one for mute/volume control.
I gutted the lighter plug and inside was a small circuit board. I popped out a blank from below the left of the steering wheel and gutted it to this out fit.. with a button and the two leds mounted on the circuit board.
I ran a 4 way phone wire (that plugs into the detector) from the circuit board up to the headliner and another 2 way phone wire (that is the power/ground).
I spliced the 2 wire into the wires noted in a previous post. To my surprise, they were always hot. Maybe I found the wrong ones... I most likely will update that.
The 4 way wire I spliced into another black 4 way plug and routed it behind the mirror to the detector.
It ended up working out great. Posting pics of the project:
