fuel line hose ok for transmission????? - Nissan Titan Forum
post #1 of 44 (permalink) Old 04-05-2011, 09:39 AM Thread Starter
al120hp's Avatar
iTrader Score: 0 reviews
I want to replace my leaking transmission line. I went to pepboys I purchased 10ft of Dayco fuel line 5/16. Is fuel line ok to use???? is there any difference between fuel line and transmission line.
Thanks
Al
al120hp is offline
Advertisement
post #2 of 44 (permalink) Old 04-05-2011, 09:41 AM
gweasel77's Avatar
Garage
iTrader Score: 6 reviews
Re: fuel line hose ok for transmission?????
Fuel line is fine! That's what i used on mine.
2005 NISSAN TITAN SE KC
IRCVK56/TEAMVK56 Crew Chief
performance:
UP/REV (RB's TUNED)
4" Airaid MXP CAI w/ GW77 4" Ram-Air Mod / TB Bypass Mod / FT90 Kit / LS7 TB / '08 IM / CSF 2 Core Rad w/ Fumoto QuikValve / Nismo 170*F T-Stat / TruCool SR4588 / Nismo LT Header's / BerkTech B-Pipes w/ MF Hi-Flows / FlowMaster Y-Pipe / BORLA XR1 / Relentless RPM Gen2 Catch Can / Detriot TruTrac LSD / Grounding Kit / Burnout Mod / IAT "Reaper Mod" / LP Mod / MT ET Street P295/45R/17 DR's / Mobil1 Full Syn 5W30
exterior/suspension:
Ruff Racing R286 22"x9.5" Chrome w/ 305/45/22 Toyo Proxes ST2's / Slotted "Cryo" Frozen Rotors / Hawk LTS Pads / Gatorback Poly-V Serp Belt / Stillen Diff. Cover / PRG Street Bars / Helwig RSB / Bilstein 5100's & HD's / MOOG Springs / SpringTech Drop Shackles / PRG camber bolts / SolarGard Tint / CF Mirrors & Door Handles / Custom CF wrapped Interior / Morimoto XB 6K HID's / Full LED Retrofit (Interior & Exterior) / LED Cube Fogs / Diode Dynamics Tails, TRS Switchback Turn Signals / Morimoto XB Reverse
NEW PB 2014: 1/4- 13.55 @ 98.5MPH
Next Mods: CAJUN 2.5"-3" Y-Pipe Kit
gweasel77 is offline
post #3 of 44 (permalink) Old 04-07-2011, 05:41 PM Thread Starter
al120hp's Avatar
I just replaced the transmission lines today and the hose worked fine. I used fuel injector line clamps. Also replaced the sparkplugs.
Got everything done in under 90 minutes.
Al
al120hp is offline
post #4 of 44 (permalink) Old 04-08-2011, 11:02 AM
Izzysplace's Avatar
Garage
iTrader Score: 10 reviews
Keep an eye on that hose I have read here ans elsewhere that Fuel line will not stand up to tranny fluid for long. I don't know if that's a fact or not but and ounce of caution is worth the cost of a new transmission!
Izzysplace is offline
post #5 of 44 (permalink) Old 04-09-2011, 10:05 AM
gweasel77's Avatar
Garage
I wasn't aware that there was specific line used for the trans fluid???
performance:
UP/REV (RB's TUNED)
post #6 of 44 (permalink) Old 04-09-2011, 11:27 AM
EDDIE FONZARELI's Avatar
iTrader Score: 14 reviews
they are different but cost just about the same
2005 CC BIG TOW PACKAGE / PC STAGE 2 KIT / 3" BODY / PRG UCA / DIRT KING ALUMINUM TIE RODS / DIRT KING HEAVY DUTY SHACKLES / NFABWORKS HEAVY DUTY TRACTION BARS / GO RHINO STEP BARS / 37" TOYO M/T / 20X14 FUEL OFFROAD HOSTAGES / 08+ FRONT END STYLING / EGR USA FENDER FLARES / TRUTRAC / 4:11 GEARS / AEM BRUTE FORCE INTAKE / TAP AUTO'S CUSTOM Y-PIPE / BORLA XR1 w/RESO TIP / A.R.E LEER LS11 BED LID / AIRLIFT / PAINTED INTERIOR / L.S.A.L. / LED GLOW KIT / KENWOOD / CUSTOM SINGLE SUNDOWN SA 15" SUB IN A SEALED ENCLOSURE / COLOR MATCHED HEADLIGHT MOD
coming soon: New color, new wheel package & new interior
EDDIE FONZARELI is offline
post #7 of 44 (permalink) Old 06-12-2011, 12:31 PM
mcginkleschmidt's Avatar
This thread discusses the merits of fuel line hose, fuel injection hose and transmission line cooler hose. As I am looking to change out my radiator, radiator hoses and transmission line cooler hoses, I've been researching the specification of the above-mentioned hoses. It seems there is a wide specification difference and pressure rating between the three hoses and I thought other Titan owners might like to see the spec comparisons that I obtained from the Dayco website that deals with the automotive hoses. Based on my reading, I would be very cautious about using fuel line hose. Automotive hose specifications can be found here: Passenger Car and Light Trucks Parts - by Dayco
fuel line hose ok for transmission?????-fuel-line-hose.jpg   fuel line hose ok for transmission?????-fuel-injection-hose.jpg   fuel line hose ok for transmission?????-transmission-cooler-hose.jpg
mcginkleschmidt is offline
The Following 5 Users Say Thank You to mcginkleschmidt For This Useful Post:
BBtruck (06-12-2011), bestatchess (06-12-2011), gweasel77 (06-13-2011), HRTKD (06-12-2011), TitanBlue (06-13-2011)
post #8 of 44 (permalink) Old 06-12-2011, 01:09 PM
iTrader Score: 4 reviews
I bought 25' of Goodyear transmission cooler hose and it is pretty thick wall stuff w/ reinforcement, spec is also 250 psi working and 1,000 psi burst (like Dayco). Goodyear fuel line is also lower rated for pressure at 50/250 working/burst.
Cooper Standard Automotive apparently made some defective Nissan hoses. I guess it can get exciting if the hose bursts and sprays ATF on the exhaust manifold.
Defect Investigations Results | Safercar.gov | NHTSA
bestatchess is offline
post #9 of 44 (permalink) Old 06-12-2011, 01:13 PM
Double Tap's Avatar
Fuel line hose isn't up to the pressures normally associated with automatic transmissions. Use the proper stuff. If that thing splits or blows loose and hoses down any portion of your exhaust system hot enough to ignite it, your truck could end up burned to the ground. I've seen it happen more times than I care to think about at the drag strip. This isn't an area you want to cut corners in.
New Hotness: 2011 Ford SVT Raptor (Tuxedo Black, Loaded)
Old Hotness: 2011 Titan Pro-4X Crew (Smoke grey, Leather, etc.)
Men fight for liberty and win it with hard knocks. Their children, brought up easy, let it slip away again,
poor fools. And their grandchildren are once more slaves. ~D.H. Lawrence, Classical American Literature, 1922
Double Tap is offline
post #10 of 44 (permalink) Old 06-12-2011, 08:43 PM
HRTKD's Avatar
Garage
iTrader Score: 2 reviews
mcginkleschmidt, great post! I would not have expected the transmission line to have a higher PSI rating than fuel line. Glad I read this thread as I'll be changing out the cooler lines on my Ranger soon.
«ClearBra, Leer 100XQ, MM SI9500 Winch, 18" Magnaflow, Berk b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned, CSF radiator, e-fans, JBA LT headers»
«SAW Coilovers and rear shocks, PRG upper control arms and shackles, Hellwig rear sway bar»
2017 Ford F-350 CCLB 6.7l Lariat - The Towing Beast
Jim aka Bionic Whore™
HRTKD is offline
post #11 of 44 (permalink) Old 06-13-2011, 11:45 AM
None of the local AutoZone and Advance Auto Parts had the Dayco brand of transmission oil cooler hose in stock but one of the close Autozone stores had the Goodyear 5/16" transmission oil cooler hose in stock, AutoZone Part #50281, Goodyear Part #65211. This stuff was unbelievably cheap at $1.19/ft., so I bought a seven foot length of hose to make sure I don't run short. The Goodyear hose is thick-walled hose so I may need the buy the next size up from 5/16" fuel injection hose clamps to accommodate the extra hose thickness. The Goodyear Oil Cooler Hose spec sheet is attached below.
After giving the Autozone counter person both the AutoZone and Goodyear part numbers, he cut and brought out a piece of generic fuel line hose that I promptly rejected. I found that as a buyer you need to be very specific when buying transmission oil cooler hose. Otherwise, you may well end up with the wrong hose if you are not mindful of what you are getting.
The Following 2 Users Say Thank You to mcginkleschmidt For This Useful Post:
gweasel77 (07-22-2011), TitanBlue (06-13-2011)
post #12 of 44 (permalink) Old 06-13-2011, 04:14 PM
gweasel77's Avatar
Garage
Yea, that's the same thing that happened to me @ Autozone, but i didn't know any better. The guy gave my Goodyear 5/16" fuel line & that's what i used... When i get a CSF radiator im going to replace all the hoses again anyway.
performance:
UP/REV (RB's TUNED)
post #13 of 44 (permalink) Old 06-13-2011, 04:26 PM
TitanBlue's Avatar
iTrader Score: 3 reviews
I went to a store recently, looking for a Flasher, and the guy tried to sell me a Relay because it looked the same! Be careful out there.
Consider purchasing a 25' Box, you may save an awful lot, and have some to share or sell cheap! Look for a place like a Federated Store, that sells and delivers to repair shops. They will sell the boxes, that Auto Zone etc. does not.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG End Links, Street Traction Bars & Shackles, UpRev Osiris Tuner 93 Performance Tuned, 18" SE Rims, Functional Hood Scoop ...
TitanBlue is offline
The Following User Says Thank You to TitanBlue For This Useful Post:
post #14 of 44 (permalink) Old 06-13-2011, 05:09 PM
RobKar's Avatar
iTrader Score: 27 reviews
I replaced all the transmission lines and all the radiator lines this weekend. Pepboys only had the fuel line so I purchased some ... OOPS ... I was able to find the correct stuff at a different parts house. Its thicker and will hold up better to the detergents in the tyranny fluid.
BY The way ... there is a radiator line under the fan clutch that was the worst of all the hoses that I removed ... Do not for get that one.
Number 7 in this picture .. Part number: 140567S001
AKA TrollopInTraining™ AKA chinawhore™
2005 BT CC LE
200,000 Miles 4/27/2015
423TQ & 324HP 2/2/2013
The early bird might get the worm, but the second mouse gets the cheese.
RobKar is offline
The Following User Says Thank You to RobKar For This Useful Post:
gweasel77 (06-15-2011)
post #15 of 44 (permalink) Old 07-22-2011, 01:38 AM
Ive used fuel hose for many years for tranny cooler lines.....never a problem. I would buy the heavier duty hose if u can find it, but i wouldnt consider it critical to have. Does anybody know the pressure in the tranny cooler lines? I did a flush on my other car recently, left the line open to drain fluid out, and the pressure in these lines are not that high. The fuel line hose is almost comparable to what the factory uses for tranny cooler hose
titan14 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Transmission cooler hose failure BIG D O LEE Titan Problems & Dealer Service 102 07-06-2016 06:42 PM
transmission hose leak question al120hp Titan Performance Modifications 1 04-01-2011 07:27 PM
transmission fluid cooler hose burst Draco42 Titan Engine, Transmission & Drivetrain 16 01-27-2011 06:51 AM
Transmission Cooler Hose 106jae Titan Parts & Accessories 5 04-23-2009 08:21 AM
Transmission hose leaking whiteLE Titan Problems & Dealer Service 7 02-09-2009 10:41 AM
You may post new threads
You may post replies
