Old 08-09-2004, 08:58 PM   #16 (permalink)
TallTexan's Avatar
To be fair, If you go to www.mobil1.com they will tell you that it is o.k. to use strait from the factory. I am 56 years old and am too old to change a good thing. I have never had a problem with an engine and I use synthetics but only after break in. Right or wrong, thats my story and I am sticking to it. They are selling oil and I am trying to protect my engine. I will just play it safe.
Old 08-09-2004, 09:30 PM   #17 (permalink)
the idea that they cause leaks is just an myth or wives-tale.
Sythetics flow better - period. They do not cause leaks, but it is possible for them to flow through gaps that dino oil clogged in.
But I'm also not over-compulsive. I would leave the factory oil in for 3000 miles, checking weekly the levels (because that's what I always do) then change to Mobil 1 / Amsoil / Royal Purple (I prefer Mobil 1, but those 3 are the best, and I consider them interchangable) with a new filter (Mobil 1, Amsoil, Purolator).
This is also a great time to add an auxilary cooler, and a dual filter and remote-mount setup. These increase capacity, which increases cooling and oil life, and the dual-filter (with bypass microfilter) increase filtration dramatically.
Old 08-09-2004, 09:35 PM   #18 (permalink)
GETSOMZ28's Avatar
Potroast, did you add an aux cooler and/or dual remote filter? If so, can you post pics??
Scott
Old 08-09-2004, 09:48 PM   #19 (permalink)
I do not own a Titan. I am actually looking at purchasing one, however.
I own a Toyota Tacoma and a Volvo 850 that I have installed remote oil filters in. I do not have pictures on me, but I can take some. This is the kit that I used in both. It allows me to run a larger filter, and a second "micro" filter, as well : http://www.amsoil.com/products/bf.html
Summit Racing and Jegs will have similar products for less. I paid $50 for the amsoil one, but that was through a hook-up. The generic kits average around $50 for everything you need, except the filters, which run between $2 and $15 depending on what you get. I run a Mobil 1 filter (for a Mustang V8) and an Amsoil filter (micro-filter bypass) on my Tacoma (3.4L V6). So it's pretty easy to see how I'm getting a better filter (Mustang V8) along with a bypass microfilter, and increased capacity. Not to mention swaping filters is so easy now -- I don't even have to go under the truck!
Old 08-10-2004, 07:16 AM   #20 (permalink)
An oil cooler is closely associated with the Titan's oil filter. See Service Manual LU-10. Be sure to take this into account in connection with any remote filter arrangements.
Old 08-10-2004, 07:22 AM   #21 (permalink)
GETSOMZ28's Avatar
Yeah, the oil filter screws into the oil cooler.
Thanks Potroast, interesting product.
Scott
Old 08-10-2004, 07:54 AM   #22 (permalink)
mjw357's Avatar
Originally Posted by braun04
The only bad thing know about synthetics is that the corvetts come with M1 from the factory and they have a history of the rings not setting in to the pistons and it blowing white smoke on start up all good other than that. Thanks for the info my titan will turn 1000m tues. I will change to Castro Syntc first cahnce i get.
Getting the piston rings to seat properly has more to do with how you drive the first few hundred miles than the motor oil you use, as long as you aren't throwing teflon or something in there.
I changed my oil myself this past weekend, used the Nissan filter and Mobil-1 5W-30 oil. I am not sure why everyone is using such different weights? I am just using what's listed in the manual.
Something a little scary, this was my trucks second oil change, the first was provided by the dealer, no charge. Well, I pull the drain plug and go to change the copper washer, and the old one had black paint around the edges from where the oil pan was painted at the factory. So, they either didn't change the washer or didn't change the oil! Maybe they suctioned it out through the filler? The area under the filter looked very clean as well, not a drop of oil anywhere.
Old 08-10-2004, 08:16 AM   #23 (permalink)
GETSOMZ28's Avatar
People choose different weights, because the same weight varies by brands. M1 is know to be on the thin side of 30 weight oil, and that is why some choose to use 40 weight instead.
Scott
Old 08-10-2004, 09:52 AM   #24 (permalink)
thin or not, it's still a 30w oil. I use 5w30 in my trucks... But it has been recommended that I try 0w30 amsoil.
Old 08-10-2004, 10:08 AM   #25 (permalink)
No thats just a typical loose GM engine and even blue smoke on a new GM isn't a problem according to everyone that I tried to get an answer from on my last, and I do mean "LAST" GMC. I believe it's within GM specs to have a piston hanging out the side if the block.
Old 08-10-2004, 10:16 AM   #26 (permalink)
Don't they have a song about those GM pistons? Something like this:
I pulled my harpoon out of my dirty red bandanna,
I was playing soft while Bobby sang the blues.
The Chevy's pistons slapping time, I was holding Bobby's hand in mine,
We sang every song that driver knew.
Old 08-10-2004, 10:23 AM   #27 (permalink)
Laughing too hard frickiing hard to type!
Old 08-11-2004, 09:23 PM   #28 (permalink)
pciley's Avatar
Must be a country western tune. Those dudes will write a song about anything...
KC XE Smoke
Old 08-11-2004, 09:39 PM   #29 (permalink)
i don't get it.
Old 08-11-2004, 09:50 PM   #30 (permalink)
IMADOGMAN's Avatar
Must be before your time pciley...Song is called "Me and Bobby McGee" by Janis Joplin...
http://www.officialjanis.com/albums_pearl2.html
Real lyrics...."Windshield wipers slapping time...
IMADOGMAN
2004 NISSAN TITAN KC SE
4x4 Offroad (E-locker)
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
