Old 08-14-2004, 10:22 AM   #31 (permalink)
HVACman's Avatar
Slurppie - have you tried getting the ECM codes and clearing them yourself? Were you successful? I tried and couldn't get the CEL to blink. Any thoughts?
Titan CC LE 4x4 Radiant Silver * Born 4/16/04 * Big Tow / Offroad Package * Kenwood DVD/NAV ent. system * Infinity 6000cs Component Speakers * Infinity 7540A Power Amp * SPL Sub Power Amp * 2 10" PowerBass Subs * Tsunami 1-Farad Capacitor * JBA Ceramic Coated Headers * Flowmaster 40 Series Catback System * Sirius Satelite Radio * K&N 77 Series FIPK Intake System * Airaid Throttle Body Spacer * Really Loud Air Horns * Weld Racing Cheyenne Rims * Carbon fiber dash kit * Black billet grille * Truxedo Tonneau Cover * CST 7" Lift * ProComp XTerrain 35/12.5/17 Tires * Procomp Traction Bars * Stainless Steel Brake Lines
Wherever you go, there you are
HVACman is offline   Reply With Quote
Old 08-14-2004, 10:52 AM   #32 (permalink)
Slurppie's Avatar
Send a message via AIM to Slurppie Send a message via MSN to Slurppie
I haven't played with it on the Titan but I did it on my Altima. It took a few tries to get the timing right but it worked except I accidently ended up clearing the problem code out before I got to the dealership.
Sold 9/14/07
Slurppie is offline   Reply With Quote
Old 08-14-2004, 06:33 PM   #33 (permalink)
1100 miles no problems. 1 mpg improvement, lovin it
dandy is offline   Reply With Quote
Old 08-15-2004, 09:06 PM   #34 (permalink)
Well i put my K&N charger back on this morning and left the neg term unhooked for a good 10 hours, she started up fine and seems ok the real test is in the morning seems all the problems i have had have been in the early AM, no idea why. I went over it with a fine tooth comb looking for possible leaks and anything loose. looks good so far. I really dont want to have to scrap the charger yet it just runs to well with it to give up yet.
Lunatic
TITAN CC LE
6" fabtech lift
18" rims 35" Toyo A/T
4x4 offroad package
big tow package
K&N Air Charger
Lunatic is offline   Reply With Quote
Old 08-15-2004, 09:09 PM   #35 (permalink)
cool, keep us updated.
JetTech is offline   Reply With Quote
Old 08-16-2004, 11:43 AM   #36 (permalink)
Hey Jet i have a question. If by chance the filter was over oiled from the factory (i dont think it was) and it did goo up the MAF. Me switching to the stock Air box wouldnt matter a bit because he MAF was still gummed up?? Im thinking more adn more that my problem was the computer not doing somthing correctly.
This is just my line of thinking but i really dont know this is my first Air charger.
Lunatic
TITAN CC LE
6" fabtech lift
4x4 offroad package
big tow package
K&N Air Charger
Old 08-16-2004, 02:33 PM   #37 (permalink)
You're absolutely correct in your logic because I was thinking the same thing. As soon as you reinstalled the factory intake and all was ok, that just ruled out any MAFS problem. That's why I'm leaning more towards a leak between the MAFS and the throttle body. Make sure everything is tight. A little trick that is commonly used is to take a propane tank (small one), turn just the propane on and hold it around suspected vacuum leaks, the engine will rev higher. Works great if you have one available to you...
Old 08-16-2004, 02:54 PM   #38 (permalink)
Slurppie's Avatar
If the truck is having problems at idle, wonder if the Idle Air learning feature would be of any use?
Sold 9/14/07
Old 08-16-2004, 03:54 PM   #39 (permalink)
Im going to let it ride for a few days and let the outside Temp get a little higher then tighten everything up again. might try your propane trick after that.
Thanks for all your help on this. Im still wanting to get a Dual exhaust like Sammy's or the banks havnt made up my mind yet, but i want to get this figure out first.
Thanks again this forum has been a great source of info, I have been members on several boards and this one is BY FAR the most Civel and mature.
If ya ever come through Missouri give me a yell I would gladly by a fellow Titan owner a beer.
Lunatic
TITAN CC LE
6" fabtech lift
4x4 offroad package
big tow package
K&N Air Charger
Old 08-16-2004, 05:49 PM   #40 (permalink)
Slurppie's Avatar
I see an emergency road trip in the near future!
Sold 9/14/07
Old 08-16-2004, 09:22 PM   #41 (permalink)
pciley's Avatar
Is it OK to clean the MAFs off with.. say.. parts wash or something? Obviously its removed and unplugged when the cleaning takes place
KC XE Smoke
Old 08-17-2004, 07:22 AM   #42 (permalink)
Slurppie's Avatar
I've heard of people using some type of electical parts cleaner. Just make sure it doesn't leave any type of residue.
Sold 9/14/07
Old 08-17-2004, 09:14 AM   #43 (permalink)
JMC
JMC's Avatar
Anyone have dyno results from these "open" air intakes? The hole that feeds air to the engine in the airbox (via fender) is awefully small. It seems like anything would be an inprovement. Is the only downfall of the Volant the fitting? I kind of like having the filter in a box and a cold air snorkle (less noise). I had a K&N on my old Cherokee that had the 4.7 V8 and saw an improvement in mileage I just couldnt get over the sound.....Sounded like an old Chevy pickup with a 305 and the breather flipped.
JMC is offline   Reply With Quote
Old 08-17-2004, 09:23 AM   #44 (permalink)
I had several dyno runs accomplished with the stock setup and the Volant. Just click on my truck pics link and scroll down, you'll see the dyno sheet
Old 08-17-2004, 09:39 AM   #45 (permalink)
JMC
JMC's Avatar
Wow, great info Jet! Do you have the Bose system in your truck? Did adjusting the reception help? I have the Bose in my Armada but I havent noticed the reception fading in and out yet.....but then again most of the time I am listening to a CD. Do you know if there is a way to turn up the output of the sub? What about a list of all the so called "hidden" menus in the Nav system? Seen any of these?
