Old 08-12-2004, 03:39 PM   #1 (permalink)
mkirt's Avatar
Talking Add Another Satisfied Magnaflow Dual Customer
Just picked up my truck- oops, I mean mama's truck (sorry dear) from the exhaust shop. It sounds exactly like I hoped it would. It is quiet at idle, but has a nice growl when accelerating then quiets back down when cruising at steady speed. Hard to keep my foot off the accelerator!
I went with the 5X11 aluminized dual in dual out with 2.25" pipes and magnaflow rolled edge tips 3.5" X 18". The tips are angled down and out at 45 degrees behind the wheels. Looks sweet! Total cost with tax $464.00 which is not as cheap as some but they did a nice job.
I will need to have the tips lowered just a bit since I just discovered I can't open the storage compartment on the driver side more than 3/4th- guess my guy didn't know what it was (it was his first Titan).
By the way, kudos to all who posted installation setups around the spare- I took all the pictures to my shop and they said it was a big help.
mkirt is offline   Reply With Quote
Old 08-12-2004, 04:43 PM   #2 (permalink)
smoketitan's Avatar
good deal glad you like your I dig mine--any pics??
Old 08-12-2004, 04:50 PM   #3 (permalink)
mkirt's Avatar
Smoketitan,
My set up is just like yours (except my rolled edge tips are angled down and dont show as much). You and Sammy provided most of my information. I was not able to take pics at the shop (forgot the camera), but I will take a couple of pics this weekend (when she is all cleaned up).
I did not go with an X Pipe since the magnaflow has the internal one- are you still satisfied without and have you developed any drone? My guy says that sound (not drone) will get a little louder as it breaks in.
Old 08-13-2004, 10:16 AM   #4 (permalink)
smoketitan's Avatar
no drone here at all-- --thats the reason I went to the larger 5x11, you have a drone????
and I happy without the x. I kinda wish I had spent the extra cash to get rolled tips
Old 08-13-2004, 10:38 AM   #5 (permalink)
mkirt's Avatar
No drone at all. I was just curious to see if you had developed one at all since you've had your system for a little while. I guess the larger case is the key.
Question, has your sound changed as the ECU has adjusted?
Old 08-13-2004, 01:58 PM   #6 (permalink)
smoketitan's Avatar
no sound change--same growl---that is weird what your installer said. oh i reset my ecu the same night by disconnecting the battery. how your low end??
Old 08-13-2004, 02:54 PM   #7 (permalink)
mkirt's Avatar
I am stock other than the exhaust. It does seem to have lost a little punch from a dead stop, although it could be because I have been stepping on the pedal harder to hear the growl! If I read the message boards correctly, stepping on the gas all at once causes more of a delay than pushing 1/2 way then increasing pressure. I am a novice aftermarket guy, so can't say definitely one way or another.
I did go with the 2.25" pipe to try to avoid losing low end torque. We'll see what happens as the computer adjusts. Did it make a huge difference disconnecting the battery?
Old 08-15-2004, 09:45 PM   #8 (permalink)
I really like mine as well. Sounds like you went similar to mine. I love the sound. You can see the pics in the pics thread under My Canteen Green Machine.
Jewelhunter
'04 XE CC Canteen Green - Born 11-03
Rhino Bedliner
Step Rails
Splash Gaurds
K&N Hi Flow Panel
Dual Exhaust - Magna Flow Mufflers
18" LE 6 Spoke Wheels
Jewelhunter is offline   Reply With Quote
