4bt cummins for my titan - Nissan Titan Forum
post #1 of 28 (permalink) Old 03-23-2012, 07:51 PM Thread Starter
skong66's Avatar
iTrader Score: 0 reviews
Got my 4bt now does anyone know of someone who makes adapters for the tranny? None of the popular companies offer one ,maybe someone out there has a cnc and can make one ,be nice to get this thing in and get 35-40 mpgs.
skong66 is offline
The Following User Says Thank You to skong66 For This Useful Post:
hitandrun176 (06-03-2012)
Advertisement
post #2 of 28 (permalink) Old 03-23-2012, 10:32 PM
yamahatitan's Avatar
iTrader Score: 2 reviews
Send a message via MSN to yamahatitan
Re: 4bt cummins for my titan
Don't use the jatco tranny!
Here is an article for you.
Cummins Diesel Engine Swap - Cummins 4BT - Diesel Power Magazine
Transmission Options
You'll be a step ahead if you figure out what transmission you'll be using. Dodge overdrive transmissions such as the 47RH, 47RE, and 48RE are a good choice, but they're heavy. If you're building a smaller vehicle, adapters are available for TH400s, 727 Torqueflites, and Powerglides, as well as manual transmissions. These transmissions are physically smaller, lighter, and have been proven to withstand up to 800 horsepower if built correctly. Keep in mind that your engine will only spin up to 3,000-4,000 rpm, so if you decide do go with a non-overdrive transmission, you may be gearing-limited. Do some research and find out which transmission makes the most sense for you.
Read more: Cummins Diesel Engine Swap - Cummins 4BT - Diesel Power Magazine
2006 Nissan Titan CC LE 4x4 Offroad Package.
Mods.
Stillen Supercharger, Stiegemeier blower porting, intake manifold porting, 90mm snout, FT90, 550cc injectors, Walbro 255, Uprev tuned w/line pressure, Airaid MXP 4" Intake, Banks Exhaust, Stillen long tube headers with Cajun 2.5" catless b-pipes, vibrant UQ, Stillen CSF 2 core radiator, Bully Dog BDGT to monitor.
Pro-Comp 6" lift, Radflo 2.5" External Reservoir Coilovers, PRG Custom billet spacer, PRG Upper Control arms, C-30 Deaver, Prg Shackles, Prg Drive Shaft Spacer, Prg Offroad Traction Bars, Toyo Open Country A/T 325-65/18 on XD Monster 18"
Stillen Cross drilled and Slotted Sport rotors in front and rear with Stillen Metal Matrix brake pads.
Billet Upper and Lower Grill, 55 w. 6000K HID's in low-beams, 35w. 6000K HID's in fog lights, Glo-Shift Trans temp, Water temp, and Oil Pressure gauges in A-Piller, 5% Tint on all rear windows and 15% on front windows.
459.4hp and 447.3 lbs.
SOLD but never forgotten...
yamahatitan is offline
post #3 of 28 (permalink) Old 03-23-2012, 10:42 PM
ImThAtGuY's Avatar
How much that cost you ?
Sent from my Desire HD
ImThAtGuY is offline
post #4 of 28 (permalink) Old 03-23-2012, 10:58 PM
Find an old bread truck and pull one out. It would be so much work though might be better off just settling with an older 03-07 5.9l and do exhaust and intake and get 20 mpg out of a full size 4 door without doing big tires of course.
Mods.
post #5 of 28 (permalink) Old 03-23-2012, 11:03 PM
That1Person's Avatar
iTrader Score: 3 reviews
Pretty sure Allison makes a tranny for Cummins. That would be my first choice. Make sure you keep us posted on your conversion, I would love to see how it goes!
06' CC 2wd
Remote Start
Spider head+tail lights
Leer 700 Bed Cover
PD'd Wheels, Fender Flares, Nerf Bars, Front Bumper, Grille, Hood & Badges
K&N Drop In + AirBox Mod
Nismo headers
UpRev by Cajun
That1Person is offline
post #6 of 28 (permalink) Old 03-24-2012, 12:18 PM Thread Starter
skong66's Avatar
Think you guys misunderstood I'm keeping my drive train looking for a tranny adapter ,the 4bt will be pushing only 250 up but about 450 lbs torque so the stock stuff will hold ,I already have a 2004 dodge with built cummins so I'm not looking to make this one a hot rod just tired of spending a c- note everyday to fill my t up ,oh the engine was about 2k
skong66 is offline
post #7 of 28 (permalink) Old 03-24-2012, 12:21 PM Thread Starter
skong66's Avatar
The 4bt should get 35-40 mpg with set up I have ,my dodge get 23 if I keep my foot out of it 25-26 the more you do to a cummins the better the mpg gets
skong66 is offline
post #8 of 28 (permalink) Old 06-03-2012, 08:41 AM
purmscl's Avatar
Has this gone anywhere? I'm working on putting an OM617 into a TJ Wrangler, and when that's done I will probably be pretty tired of waiting on a factory light duty diesel. A 4bt seems like it would be perfect for the Titan.
"The satisfactions of manifesting oneself concretely in the world through manual competence have been known to make a man quiet and easy. They seem to relieve him of the felt need to offer chattering interpretations of himself to vindicate his worth. He can simply point: the building stands, the car runs, the lights are on. His well-founded pride is far from the gratuitous "self-esteem" that educators would impart to students, as though by magic."
Matthew B. Crawford, Shop Class as Soulcraft
purmscl is offline
post #9 of 28 (permalink) Old 06-03-2012, 10:28 AM
Banned
The bigger 5.9 had the AT545 behind it. The AT545 is a 4 speed transmission, with a deep first gear, 1:1 4th gear and converter lockup in every gear from 2-4. The AT545 is a rugged transmission that is hydraulically controlled and used in school buses. 5.9 and 3.9 4bt use the same transmissions and adapters. The 4BT and AT545 would be practically indestructable.
http://www.globaltranny.com/trannys/545.htm
06HemiRam is offline
post #10 of 28 (permalink) Old 06-03-2012, 10:36 AM
Try destroked.com.
Fotno is offline
post #11 of 28 (permalink) Old 06-04-2012, 07:26 AM Thread Starter
skong66's Avatar
Nope, cant find any tranny adapters tryin to keep stock drive train anybody got any ideas?
skong66 is offline
post #12 of 28 (permalink) Old 06-04-2012, 08:12 AM
vilim12's Avatar
iTrader Score: 5 reviews
The weakest part of our drivetrain is the tranny, why would you wasn't to keep it?
2008 Nissan Titan Pro-4x CC LWB Smoke
MODS LIST BELOW
vilim12 is offline
post #13 of 28 (permalink) Old 06-04-2012, 09:34 AM
lookzcustoms's Avatar
iTrader Score: 1 reviews
wow thats a sweet idea, please post some pix of the build
i'm very interested how this is going to workout for u
as for the adapter u should try a cnc shop to make an adapter for u
http://www.advanceadapters.com/
http://www.transmissionadapters.com/
2006 CC Offroad, Uprev(tuned by seymore4), Injen intake, JBA headers, Cajun B-pipes, Stillen Rad, RC traction bars, Bully Dog GT, PRG UCA, PRG steering heim joints, 2" PRG Leveling kit, 5100 Bilsteins(middle setting), PRG shackles, front & rear Brake Performace Premium Dimpled and Slotted Brake Rotors & Calipers, Nismojunky grounding kit, BlackedOut Rims, 1.5" Bora Spacers, still need to install , PRG engine mounts, tranny mount, LCA bushings, cam bolts, steel brake lines, spacers
specs and pics
lookzcustoms is offline
post #14 of 28 (permalink) Old 06-05-2012, 04:35 AM Thread Starter
skong66's Avatar
As far as the weakest ive got 200+k on mine no probs just gonna freshin every thing up the drive train is fine for the a 4bt as long as you keep it close to stock idrive this one 200miles a day so not going crazy with the build
skong66 is offline
post #15 of 28 (permalink) Old 06-05-2012, 05:10 AM
titanss's Avatar
There is a member here that has done this swap, not sure what Trans he used.
titanss is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
More than one Cummins Titan??? vilim12 Titan General Discussion 31 09-14-2011 08:24 PM
Titan VS Cummins 2nd post deerslayer War Stories 21 04-17-2010 10:09 AM
Titan VS Cummins deerslayer War Stories 9 04-10-2010 05:21 PM
Titan vs. Cummins Shane06fl War Stories 24 08-25-2009 12:16 PM
WTT 03 Ram 2500 Cummins to Titan ed1976 Buy/Sell 12 12-08-2008 01:45 PM
You may post new threads
You may post replies
