UPREV Help, Rom questions - Nissan Titan Forum
Old 04-17-2012, 08:32 PM   #1 (permalink)
MilenkoGT's Avatar
iTrader Score: 5 reviews
Send a message via AIM to MilenkoGT
Hey guys,
I finally got my UPREV Cipher Cable today and here is what Jared@uprev told me before I ordered my Cable since I had Relentless RPM do an ECU Reflash/dynotune.
Here is what jared stated and is what my cable has...
"Just buy a Cipher cable through our online store. After you make the order, send an email to Hope@uprev.com and tell her that you need the cable to be licensed for Osiris, but with no flash license on the cable since your license is already on your ECU.
When you get the cable you will be able to use Cipher to data log and Osiris to reflash since you already have a flash license on your ECU. "
Ok, what does this mean, and how can I tell if UPREV did this or not?
Also, how do I get my ROM off my Titan's ECU in order to send it to DANBLP (BEN) for him to Tune my titan with my datalogs.
AND...can someone provide an Updated version of what parameters are needed to datalog, the Uprev User Guide has them listed but my listed parameters on Cipher are worded differently.
Btw I did the Wideband conversion and my ECU is licensed to my cable etc...I can only do the following on the Cipher main screen under "Tools":
-Connect to Vehicle
-Retrieve and Clear Trouble Codes
-Monitor and Record ECU Parameters
-BCM Functions
-Monitor and Record ABS parameters
-Clear learned fuel settings
-Adjust Ethanol Mixture Ratio
The above tools are the only ones I can use. The rest aren't able for me to select.
Btw, I downloaded the Osiris uploader and all updates from UPREV's website and my cable was recognized "ECU is Ready" for me to load custom ROM tunes. However the "Flash ECU" and "DUMP Ecu" buttons weren't able to select, I guess b/c I didn't have a tune loaded into the top box for flashing.
So gurus, what do I need to do from here to get tunes from Danblp or Randy...
Thank you guys, and I have been searching, and have read the Cipher and most of the OSIRIS manual (which is kinda confusing).
2008.5 Titan SE CC FFV
'Smoke'
Uprev/Danblp Tune**Custom 4in CAI w/ ram air & TB Bypass Mod,**RP-PERF Stg.2 E-FANs**170 T-Stat**DTLT's-No Cats-CAJUN 2.5in B-pipes, Apexi resonators, Flowmaster Y-pipe 2.5in to 3in to (Japan made) APEXi N1**PML Trans Pan**Transgo shift kit**Long SR4588 Trans Cooler**TruTrac w/ 3.36 gears**NFABWORKS Traction Bars**20x10 KMC XD Rockstars**305/50/20 Cooper Zeon LTZ**R1 Concepts Slotted Rotors w/ Fleet Perf. Pads**Legit Acc. HIDs 5000k with LED Reverse Package**Custom Mesh Grill Mod
Coming Soon FT90 Kit w/ LS7 TB! One of the Last!
Dyno results (5/22/13) for above mods: 330rwhp/386rwtq in 87*f heat and with 102K miles!!!
MilenkoGT is online now   Reply With Quote
Advertisement
Old 04-17-2012, 09:14 PM   #2 (permalink)
Supporting Vendor
seymore4's Avatar
iTrader Score: 27 reviews
Re: UPREV Help, Rom questions
Load cable manager and plug the cable into your computer, check if osiris standard is enabled. That is what you need to flash the ecu. You can't download the tuned rom file from your ecu, you will have to get a copy of it from the tuner, he can email it to you.
seymore4 is offline   Reply With Quote
Old 04-17-2012, 09:15 PM   #3 (permalink)
ostaF's Avatar
iTrader Score: 2 reviews
I had to deal with this since I was originally dyno tuned so here goes...
If cipher and osiris is reading your ECU w/ no error messages then I believe it was setup licensed for osiris.
You can't get your ROM thru Osiris, you must have Relentless email you your original ROM.
About the parameters, I was missing AFR 1 & 2 in the parameter list so I emailed Jared and he asked what ECU# I have. I think I retrieved this info thru cipher or my ROM file, I can't remember. Soon after he asked me to run the uprev software update and after that AFR 1 & 2 where listed in the parameters. The parameters aren't a match word for word between cipher and the instructions but it's close, you'll figure it out.
ostaF is offline   Reply With Quote
Old 04-17-2012, 09:18 PM   #4 (permalink)
OFELIPE's Avatar
iTrader Score: 3 reviews
You can find your ECU part numer though cipher.
StarvinMarvinWhore™
~ UPREV Tuned ~ JBA Headers ~ Banks Exhaust ~ Volant CAI ~
~ DDM 6k HID's Lows and Fogs ~
~ 2 American Bass XFL 10's ~ Soundstream Rubicon 2500D Mono Block ~ 2/0g Wiring ~ 4g Grounding Kit ~ Custom FF Ported Box ~
~ SD_Titan 2in Seat Lift ~
~ Spring Tech Lowering Shackles ~ Blacked-Out Foose Spank 6 22's ~ 305/40/22 Nitto 420's ~
~ SD_Titan Headlight Mod ~ Grill Mod ~ JB LED Reverse Lights ~
OFELIPE is offline   Reply With Quote
Old 04-17-2012, 09:30 PM   #5 (permalink)
Sftail1990's Avatar
iTrader Score: 4 reviews
There should be enough guys out here with a ROM that is compatible for yours I would imagine. I have an 06 so that wouldn't work for you and VVT, you need to find someone that has that ROM with that p/n out there, a base ROM that is. When you connect with the cable it will run through and tell you what your p/n is I think, have to plug mine up tomorrow and see for sure.
2006 Titan SE CC Granite, ,Uprev Tuned , JWT S7/S2 cams, 07 manifold, FT90mm, 170 Thermostat, AirRaid MXP 4", Long TruCool Trans Cooler, Big Tow, Stillen BBK w/stainless lines all around, 20" KMC Brodie 671 wheels, Active Tuning Kit, Axle Vent Mod, Mag-Hytec rear diff cover ,True Trac, Armada front spoiler,and Cowl painted. Nismo stripe kit. Katzkins leather interior. Nismo Headers (temporarily removed), PRT 304 SS High Flow catless B-pipes, PRT all 304 SS Custom Y 2.5" to 3" w/Borla and dual 2.5" side exits w/Resonated tips, Stillen front sway bar w/PRG end links, StillTime 35mm bushings w/billet mounts, PRG mini lift, Bilstein 5100's, PML trans pan w/guage set in Lo-tek pod. All Amsoil fluids, of course, I am a dealer.
1/4 Best 14.318 @94.53 in 1408 DA FST
Previous 14.485 @ 93.17 in 2497 DA in FST
1/8 Best 9.138 @75.28 in 1004 DA in FST.
Previous 9.157 @74.60 in 1886 DA in FST.
60 ft Best 2.039 in 1886 DA in FST.
Previous 2.054 in 2497 DA FST
Great parts list by BBF, had to post it also.
https://spreadsheets.google.com/pub?...FJrLAteCAHEBFA
Sftail1990 is offline   Reply With Quote
Old 04-17-2012, 09:43 PM   #6 (permalink)
ostaF's Avatar
Has this been confirmed? Jared said the ROMs are encrypted. Maybe there's a difference in the ROMs if you're e-tuned vs dyno tuned.
Old 04-18-2012, 02:45 AM   #7 (permalink)
MilenkoGT's Avatar
Thanks guys, Im going to call relentless Rpm tomorrow and see if I can get ahold of my ROM. By the way I don't have cruise control since I went from 2.93s to the Big Tow 3.36 gears... I mean it works until 55mph after that, it stops working until I shut the truck on and off again. BTW this doesn't affect Uprev Map switching. Just wondering if you guys knew the fix for the cruise control issue.
'Smoke'
Old 04-18-2012, 02:59 AM   #8 (permalink)
deerslayer's Avatar
iTrader Score: 11 reviews
What did you do with the 2.93s?
2006 4X4.........THE FASTEST 4X4
Performance Mods:
4" Spectre CAI With Ram Air
07 Intake Manifold
Doug Thorley LT Headers
2.5" Catless Cajuns
2.5"/3" Flowmaster Y Collector
3" SI/SO Hooker Aerochamber Muffler
Uprev Tuned, Southern Style
170* Nissan Thermostat
IAT Resistor Mod
60' 1.86
1/8 8.66 @ 78.5 MPH
1/4 13.66 @ 97.6 MPH
deerslayer is offline   Reply With Quote
Old 04-18-2012, 07:28 AM   #9 (permalink)
RB's Titan's Avatar
YOU need a 3.36 ROM.....to get cruise control back bro. Did that one on many trucks after doing the original 2.94-3.36 gear swap. Be sure to get your ECU number year and factory options listed when requesting a new ROM from UpRev if you bought from UpRev.
Once you have a firm idea of the software and ROM editor you can pull data off the flashed ROM manually (if not locked)....MAjor PITA but it can be done just in case you cant get the ROM from Relentless. Easiest and most professional way is to get the original flash...but its really of more of the fuel mapping your most concerned with since you will need to have that 2.94 ROM mapped to a 3.36.
Randy
IRC CREW CHIEF - International Racing Club VK56
MODS: PGM 90mm Throttle Body, Custom PGM Throttle Body Spacer, RB Custom Ram Air, RB 170 Thermostat, Volant G1 CAI, Stillen Headers, RB Custom B-Pipe w/Cats in line, Custom Banks Exhaust, Father of Titan UpRev Tunes, JWT Cams, Detroit TruTrac LSD, N20, lol First to 100MPH NA 1/4mile, 1.80 60ft on street tires.
Link to 13.90 @ 100MPH NA street trim video:
http://s93.photobucket.com/albums/l8...390MyTitan.mp4
RB's Titan is offline   Reply With Quote
The Following User Says Thank You to RB's Titan For This Useful Post:
MilenkoGT (04-18-2012)
Old 04-18-2012, 12:15 PM   #10 (permalink)
MilenkoGT's Avatar
I sold the 2.93 rear axle assembly (complete), it wasn't a gear change, it was a whole rear end swap to an 05 that had tru trac installed. At that time 2 years ago I thought my 08 and newer titans wouldn't accept tru trac without an earlier rear end installed.
I'm going to try and get my ROM from Relentless first, i mean i've lived without cruise control ever since i had the rear end swapped (over 2 years ago), so its really not that big of a deal to have it... I just want to be able to reflash my truck with datalogs thru RB or Danblp lol, I need a ECONOMY map sooo bad and my other maps need the line pressure mod revised (Danblp has one I want) and my performance maps need a big revision.
'Smoke'
Old 04-18-2012, 12:28 PM   #11 (permalink)
VinylImagez's Avatar
iTrader Score: 0 reviews
Send a message via MSN to VinylImagez Send a message via Yahoo to VinylImagez
I told you
"LA CALDERA"
Titan LE 06'
Performance Mods
Nismo Headers
Airaid MXP CAI
Uprev-Custom Tune By DanBlp
Jim Wolf S7/S2 Cams
True Dual Exhaust with Bullets
Stillen B pipes (there off my truck, I got the CAJUN'S on Now)
CSF Racing Radiator
FT90mm (ex-relentless rpm 90mm user)
Tranny Line Pressure Mod
Heavily Modified 08' Intake manifold, with a 90MM neck to accept 90mm LS7 DBW TB, internal runners were shorten, ported and polished,Home Made Mod aka PBMIM (uninstalled)
Truetrac/stock gears
Stillen Supercharger/uprev tuned, 725cc Injector Dynamics, 255 Walbro Fuel Pump, 27"x7'x3.5' Heat Exchanger, Jabsco Pump, 5.6 Gallon Icebox (still working the bugs out)
RC Traction Bars
Laser Interceptor Dual Front Sensors
Interior
Q-56 Cluster, Autometer Boost Guage
Exterior
Stock Wheels/285/60/18 Primewell PZ900
Hoosier Drag Slicks For The Track
VinylImagez is online now   Reply With Quote
Old 04-18-2012, 12:42 PM   #12 (permalink)
MilenkoGT's Avatar
Alright, well I just talked to Chris the tuner at Relentless RPM and he is sending me my ROM in a few minutes. Finally!
Btw, can someone give me a quick rundown of what parameters I need to log? Hopefully we can make this thread a sticky, b/c i'm sure a lot of Uprev new users will benefit from reading these above posts.
'Smoke'
Old 04-18-2012, 01:15 PM   #13 (permalink)
MilenkoGT's Avatar
Thank you Gil, I took your word for it! lol I just had to make sure I understood what UPREV did to my cable and if they did it or not. Regarding the statement Jared@uprev said before sending my cable.
'Smoke'
Old 04-18-2012, 01:28 PM   #14 (permalink)
MilenkoGT's Avatar
K well I received my ROM, can't open it of course since I don't have ROM editor, but I sent it to DanBlp. Randy (RB) I was wondering if I could send it to you to look it over for me?
You could PM your email or my email is Milenkogt@yahoo.com
Thanks,
'Smoke'
Old 04-18-2012, 09:27 PM   #15 (permalink)
Supporting Vendor
seymore4's Avatar
You should upgrade that cable to tuner
Advertisement
Uprev Questions jchaffintitan Titan General Discussion 0 01-27-2012 07:17 PM
Uprev questions centiStokes Titan Performance Modifications 1 11-26-2011 07:52 AM
Uprev Questions CL 8 2WD Titan Performance Modifications 3 12-12-2007 08:04 PM
Questions regarding UpRev PiercerNC Titan Performance Modifications 13 11-02-2007 07:13 PM
SEO by vBSEO 3.3.2
