Nissan 5.6L Titan and Armada owners are now able to experience the economy and performance of the just released Nissan Power Pup.
The Nissan
Power Pup is the latest addition to join Bully Dog's All Star line up. With two performance settings above stock the Nissan Power Pup is loaded with following options:
Adjust speed limiter
Adjust rev limiter
Adjust engine timing +/- 2 degrees
Disable/Enable Wide Open Throttle Governor
Adjust Idle Up Feature
Peak to peak rear wheel horsepower and torque numbers with the Nissan Power Pup are as follows:
Stock HP: 235.2 Torque: 287.9
High Octane Tune: HP: 258.5 Torque: 336.9
Improvement of 23.3 HP and 49 ft lb of torque!
Vehicle Applications:
- Nissan Titan 5.6L '05-'07
- Nissan Armada 5.6L '05-'07
heres the chart for the Triple GT.
