UpRev for Dummies? - Page 31 - Nissan Titan Forum
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 02-13-2013, 03:24 PM   #451 (permalink)
Supporting Vendor
seymore4's Avatar
iTrader Score: 27 reviews
Re: UpRev for Dummies?
Originally Posted by retnavycwo View Post
Well, if I'm reading my Cipher logs right (yes I managed to get a set done w/o cipher locking up) 0-60, with/at WOT, it looks like AFR is reading around 12.67 to 11.47...start to end of WOT) based on AFR WB-B1 and B2. Does that sound about right? Throttle position is 4.11, and if I rem reading it here in the thread that's measured in volts indicating WOT at 4 volts plus?
That sounds about right
seymore4 is offline   Reply With Quote
Advertisement
Old 02-13-2013, 04:45 PM   #452 (permalink)
retnavycwo's Avatar
iTrader Score: 0 reviews
Thanks. That's running on the base ROM, so I'm figuring after the tweaking by Uprev on the next tune I should be pretty dialed in. But then, I've added resonated exhaust tips (prob no change from that) and will have swapped out the catless PRTs with catted ones. So, new data logs planned before sending them in for tweaking. Finally, one thing that's become more noticeable is the loss at the low end, but that seems normal, again, from what I've read here.
Addicted to mods
06 Silver CC XE Haze Grey & Underway
Uprev w/Danblp tune, MXP CAI, JBA LTs, 2.5 PRT High Flow Catted B-Pipes, Flowmaster Y pipe, 22" Magnaflow, TB Bypass, 2" front level, 1.5" rear blocks, Bilstein 5100 (rear), Tru-cool SR4588 tranny cooler, PML Deep Tranny Pan, Mag-Hytec Rear Diff Cover, ARIES Bullbar and side rails, Undercover Hard Tonneau, Weathertech mats, "Gatorback" Serp Belt
Parts on hand, next installs: 170* T-Stat, , and Bilstein 5100s (front).
Wish list: True Trac, JWT S2/S7 Cams, transgo shift kit, CSF or Koyorad all aluminum radiator, rad dual e fans, new wheels & tires...and anything else that makes it look better or go faster!
retnavycwo is offline   Reply With Quote
Old 02-23-2013, 05:29 AM   #453 (permalink)
GalaxyPro4X11's Avatar
UpRev for Dummies?
Last night I was screwing around in the snow an hit the rev limiter between the 1-2 shift an sure enough, went into limp mode.
Should I be ditching uprev for now
Sent from AutoGuide.com App
GalaxyPro4X11 is offline   Reply With Quote
Old 02-23-2013, 06:56 AM   #454 (permalink)
RB's Titan's Avatar
iTrader Score: 4 reviews
The base ROM is not tuned to "a truck" or your truck yet. If you have free etunes use them to get dialed in. Usually the best way to etune is to have all supporting mods done and on the vehicle for 300miles or more.
Randy
etune@uprev.com
International Racing Club VK56
MODS: PGM 90mm Throttle Body, Custom PGM Throttle Body Spacer, RB Custom Ram Air, RB 170 Thermostat, Volant G1 CAI, Stillen Headers, RB Custom B-Pipe w/Cats in line, Custom Banks Exhaust, Father of Titan UpRev Tunes, JWT Cams, Detroit TruTrac LSD, N20, lol First to 100MPH NA 1/4mile, 1.80 60ft on street tires.
Link to 13.90 @ 100MPH NA street trim video:
http://s93.photobucket.com/albums/l8...390MyTitan.mp4
RB's Titan is offline   Reply With Quote
The Following 2 Users Say Thank You to RB's Titan For This Useful Post:
gweasel77 (02-23-2013), NIS_TITAN06 (02-24-2013)
Old 02-23-2013, 06:57 AM   #455 (permalink)
RB's Titan's Avatar
I wouldnt...but I'd get a etune update and note the problem.
Randy
etune@uprev.com
Old 02-23-2013, 09:03 AM   #456 (permalink)
Supporting Vendor
seymore4's Avatar
+1 there's a fix for it now, I just spoke with Hans recently
The Following User Says Thank You to seymore4 For This Useful Post:
GalaxyPro4X11 (02-23-2013)
Old 02-25-2013, 12:07 PM   #457 (permalink)
Originally Posted by gweasel77 View Post
You will get used to it. Actually i rarely switch maps anyways... It stays in 93 Map 99.9% on the time!
When using a 93 tune, is it necessary to use 93 0ctane fuel?
fatpinfield is offline   Reply With Quote
Old 02-25-2013, 12:16 PM   #458 (permalink)
Originally Posted by 06HemiRam View Post
Glad they have the newer ones getting better mileage.
That was a good one!
Old 02-25-2013, 12:37 PM   #459 (permalink)
Originally Posted by tcoche View Post
you have to ask for it. They can change it on your current ROM. However, they may make you buy an Etune to add the mod. Unless, this certain someone chimes in and may offer their assistance. I don't want to volunteer this person to do it for you, know what I mean?
My question falls along the same lines. Do you have to ask them to remove the WOT restriction and do a timing advance, or are either of those standard elements of the tunes?
Old 02-25-2013, 12:40 PM   #460 (permalink)
Yea it pulls it from the Lamda sensor. The MAF is part of the fueling calculations though.
Lamda Lamda Lamda!
The Following User Says Thank You to fatpinfield For This Useful Post:
tempdon (02-26-2013)
Old 02-25-2013, 12:59 PM   #461 (permalink)
gweasel77's Avatar
iTrader Score: 6 reviews
Lightbulb Re: UpRev for Dummies?
YES!
It is VERY important that you don't run any fuel with less octane than what your Map is setup for!!!
This could cause detonation, which is NOT good!
For example: My 91oct & 93oct Maps are pretty much identical, but my 93 oct Map has higher ign timing values to get the most performance possible out of my Tune!
2005 NISSAN TITAN SE KC
IRC VK56 TEAM MEMBER
performance:
UP/REV CUSTOM TUNED
4" Airaid MXP CAI w/ GW77 4" Ram-Air Mod / TB Bypass Mod / FT90 Kit / LS7 TB / '08 IM / CSF Race Rad. / Trans. Cooler / Nismo LT Header's / Berk Tech SS B-Pipes w/ Magnaflow Hi-Flows / 2.25"-3" Flowmaster Y-Pipe / Borla XR-1 Muffler / "Gatorback" Serp Belt / Relentless RPM Catch Can / Detriot TruTrac / ActiveTuning Grounding Kit / Burnout Mod / LP Mod / MT ET Street P295/45R/17 DR's / Mobil1 EP 5W30 / 75W140
exterior/suspension:
Ruff Racing R286 22"x9.5" Chromes w/ 305/45/22 Yokohama Parada Spec-X's / Slotted "cryo" Frozen Rotors / Hawk LTS Brake Pads / High Cap. Diff. Cover / Helwig RSB / Bilstein HD's / SpringTech 2" Drop Shackles / PRG camber bolts / Armada Air Dam / SolarGard Tint / Tow Hooks / Debadged
NEW PB: 1/4- 13.57 @ 98.51MPH w/ my BEST 60' EVER 1.88
New PB Dragtimes Page:http://www.dragtimes.com/Nissan-Tita...lip-25254.html
Need to install: PRG Street Traction Bars!!!
Next Mods: CAJUN PIPES!!!!
gweasel77 is offline   Reply With Quote
The Following 2 Users Say Thank You to gweasel77 For This Useful Post:
fatpinfield (02-25-2013), linycctitan (02-27-2013)
Old 02-25-2013, 02:04 PM   #462 (permalink)
YES!
Is there really that big of a boost from 87 to 93? Or do you use the high octane primarily at the track? Gas is expensive enough and I've got a lead foot.
The Following 2 Users Say Thank You to fatpinfield For This Useful Post:
97lowazznissan (02-25-2013), gweasel77 (06-13-2013)
Old 02-25-2013, 02:26 PM   #463 (permalink)
TA CC TX's Avatar
iTrader Score: 2 reviews
I think so,,, I got my first tune on all maps 87 tune ,,,After first e-tune I could feel diff,after second and third tune ( me telling them to f the 87 and a all out tune) it was a Whole lot more buttdyno results!
[SIGPIC][04 CC BT OFFROAD RB's UPREV TUNE Doug Thorley LT's/Cajun 2.5 catless B-Pipes/Cajun Y-pipe 2.5-3.0/Borla XR-1/Vibrent UQ resonator/Airaid MXP CAI/HM Ram AIR/+07 IM/TB-Mod/170* thermostat/HM grounding kit/ CSF Rad/ Long SR4588 Tranny Cooler/Bilstine H-D's front and back/2" Drop Shackles/Hellwig traction springs/Tru Track/AirLift air bags/MetalWorx Traction bars/ Wolo powerhouse air Horn!!!!!!
[RWHP 316.56-RWTQ 378.54 ]
IRCVK56 MEMBER
TA CC TX is offline   Reply With Quote
The Following 2 Users Say Thank You to TA CC TX For This Useful Post:
fatpinfield (02-25-2013), gweasel77 (06-13-2013)
Old 02-25-2013, 07:07 PM   #464 (permalink)
Solidus's Avatar
iTrader Score: 3 reviews
I have an 06 4x4 Big Tow with an AFE stage 2, true dual setup into Magnaflow magnapacks with dual side exit in front of the axle. In the garage I have a box with OBX headers , JWT S2 cams with a set of catted PRT b-pipes on the way. I pretty much know I need to get UPREV. My question is how to best go about it. There's a tuner locally I have'nt been in contact with yet but I'm wondering if I should buy from UPREV and use the provided tunes or buy from the tuner and have it all done there or risk having a brain cramp logging and emailing. I've got a chunk of change sitting in the box and I want to do it in the simplest way possible. Not trying to be the fastest but I want at a minimum a 13sec truck. What's the route I need to be headed in?
06' LE 4x4 CC BT:
Performance:
JWT S2 Cams, 07' Intake Manifold, OBX Longtubes,PRT Catted b-pipes, Borla XR-1 16", Vibrant UQ,4" Resonated tip, Truetrac,Mag Hytec Diff cover, Uprev, AIRAID MXP,
Suspension:
DR Coilovers, Deaver Springs , Billsteins 5100's, RC Traction Bars, PRG 1" Blocks
Looks:
Bedlined Front Bumper , Rear Bumper , Mirrors , Sidesteps. OEM Bedlined 20's , Bushwhacker Bedlined Flares
On Deck: Transgo Shift kit, Ram Air Hood , PML Trans Pan, External Trans Cooler, Nightowl 2.5 Y BE DONE BY AUGUST
Solidus is online now   Reply With Quote
Old 02-25-2013, 07:52 PM   #465 (permalink)
Supporting Vendor
seymore4's Avatar
If you're doing cams I would highly recommend getting a dyno tune, it would be beneficial for you to have the cable as well tho so you can monitor engine parameters, check and clear codes, etc. So basically buy a used Osiris standard with no etunes and go to the local guy for tuning
Advertisement
Uploading for Dummies terryu1 Titan Pictures & Media Post 854 06-03-2013 03:11 PM
Custom B Pipes?? (For Dummies) bestatchess Titan Performance Modifications 11 10-25-2009 02:38 PM
dealership dummies make08faster Titan Parts & Accessories 2 01-19-2009 10:32 AM
Internet Forums for Dummies AgTitan06 Off-Topic Discussion 1 03-29-2007 10:11 PM
Burning Mp3's for Dummies Bayou Titan Off-Topic Discussion 2 12-31-2004 09:38 PM
SEO by vBSEO 3.3.2
