I am working on a dual intake manifold design because I had an extra throttle body assembly sitting around. I already wired it up to make sure both work together, but I am working on this design. It has equal length runners. The sides are set up by odd and even sides with a center intake for more equal flow. I also designed it to be sort enough to not hit the oil filler neck. The base would be wider for fuel injectors, but this is what I've got so far. Let me know if anyone has ideas.
The Following 2 Users Say Thank You to adal89 For This Useful Post:
i can see the potential in it, as my previous 370z had dual intakes...
the only thing i could see that's not really an issue but more of an engineering challenge is the positioning of the intakes in proportion to the engine bay. i.e. the battery would have to be relocated in order to have a mirrored passenger side intake. Or an alternate designed dual intake format would have to be conceived.
Thanks for the quick reply. I am actually putting this in my 07 frontier that I put the vk in so I forgot about your battery placement. Would it be able to run mirrored intakes if the neck was shortened?
relocate TB flanges, need a custom cai, 1 piece for 1 MAf, I was going to try this modifying a stock IM and adding 2 TB's
"LA CALDERA"
Titan LE 06'
Performance Mods
Nismo Headers
Airaid MXP CAI
Uprev-Custom Tune By DanBlp
Jim Wolf S7/S2 Cams
True Dual Exhaust with Bullets
Stillen B pipes (there off my truck, I got the CAJUN'S on Now)
CSF Racing Radiator
FT90mm (ex-relentless rpm 90mm user)
Tranny Line Pressure Mod
Heavily Modified 08' Intake manifold, with a 90MM neck to accept 90mm LS7 DBW TB, internal runners were shorten, ported and polished,Home Made Mod aka PBMIM (uninstalled)
Truetrac/stock gears
Stillen Supercharger/uprev tuned, 725cc Injector Dynamics, 255 Walbro Fuel Pump, 27"x7'x3.5' Heat Exchanger, Jabsco Pump, 5.6 Gallon Icebox (still working the bugs out)
RC Traction Bars
Laser Interceptor Dual Front Sensors
Interior
Q-56 Cluster, Autometer Boost Guage
Exterior
Stock Wheels/285/60/18 Primewell PZ900
Hoosier Drag Slicks For The Track
did you get the 2 throttle bodies to work in sync?
"LA CALDERA"
Titan LE 06'
Performance Mods
Nismo Headers
Airaid MXP CAI
Jim Wolf S7/S2 Cams
CSF Racing Radiator
RC Traction Bars
Interior
Exterior
Titan ss thank you for your input on the clearance. I was thinking the same thing, but as I said I'm not looking at a Titan engine compartment so I couldn't be sure.
Vinyl I thought of that too, but a main purpose of me doing this project is to get more equal airflow as opposed to stock and front mounted tb's would be no different. Thank you for bringing up the MAF because I forgot to mention this. I am running uprev so I will most likely just reprogram the ECM to read the sensor input doubled from stock and still only have to run 1 MAF. About the tb's ya they run in sync. It was actually way easier to get that workin than I thought it would be.
are you running a Titan ECU or is it a stand alone?
"LA CALDERA"
Titan LE 06'
Performance Mods
Nismo Headers
Airaid MXP CAI
Jim Wolf S7/S2 Cams
CSF Racing Radiator
RC Traction Bars
Interior
Exterior
To get equal airflow on front mounted TB's you would have to taper the plenums to the back cylinders on each bank.
__________________ '04 CC SE BLIZ WHITE 2wd BigTow FT90MM,UPREV TUNED, 4" ColdAir Intake, Coolant Bypass, TB Screen Removed, 10w40 RP, AT Grounding Kit, JBA Exhaust, TruTrac, Jet Tuned MAF, 170 Threm Mod, RB-4" RamAir Mod, 07 Intake, Doug Thorley Long Tube HEADERS, ST 2" Drop Shackles, LEVEL 10 Tran's & LEVEL 10 Torq Mod, Long Tru-Cool Trans Cooler, Hellwig traction springs, Factory 20's, Berky B-pipes, BellTech Lowering Structs, BellTech Shocks, Removed 3rd leaf, Blue LED's interior Personal Best: RACE TRIM = 60'-1.907 ; 1/8-8.809@78.13 ; 1/4-13.871@95.83 STREET TRIM = 60'-1.974 ; 1/8-8.899@77.05 ; 1/1-14.025@95.31 Next MOD:
08 Brake Upgrade,White Headlight Mod, AUDIO:
Kenwood DDX712 with Kenwood KNA-G510 Navigation Module,Memphis Audio 12s in TECH12 box,Memphis Audio 16MDC-1000
The Following User Says Thank You to pcg_k25 For This Useful Post:
Titan ECM. I did consider the tapering, but in all honesty it is just one more piece of engineering that I don't want to deal with. Also I do plan to put on dual turbos eventually and the side location makes it more accessible for that routing since I am going to put the inter cooler for each on the outside just above the wheel wells since I am fiberglassing a hood with vents for it. Long project, but the manifold is the first step.
