While they are not entirely accurate, they are GREAT for measuring 'increases" in power and better 1/4 miles times. If you do say... 4 or 5 runs average them and then do the same amount of runs after each mod has broken in to the computer, you will get a good idea of what has happened to your power output.
Jet, I'm looking for something that plugs the truck into my laptop via a serial cable (parallel or USB is also OK) and comes with software... that can do everything an OBDII scanner can do, AND erase SES lights, codes, etc.
If it can graph RPM, fuel and air curves, etc. and plug into a wide-band O2 that would be great too. Another user has something that connects to a laptop that was able to tell him the TIMING at a given RPM.. he was measuring the effects of different octanes of fuel. Not sure if its the same device, but something similiar.
Ebay search was useless.. any ideas or past experience?
I am finding all sorts of standalone hand-helds, but they have no graphing capabilities and do nothing for analyzing power, fuel, rpms, air etc.
KC XE Smoke
