Old 09-05-2004, 02:48 PM   #1 (permalink)
rawze's Avatar
syn oil =hp gains
i just saw on tv where they did a dyno on a camaro and got a 8hp increase by just running sythetic (oil, tranny, and rear). that was very interesting by cutting back the friction made so much difference. they were running purple something.
RICK : TITAN NO MORE
I like the sound when i push the pedal down!!
I GET BORED UNLESS IT'S FLOORED
TRADED FOR A LIMITED 4X4 1999 4RUNNER
SILVER KC SE 4x4
rf w/captains
chrome bed rails
air box mod w/kn drop in
jba exhaust
wade bug shield
side window ventvisors
billet lower grill
line x liner
factory step rails
AVS headlight accents
rawze is offline   Reply With Quote
Old 09-05-2004, 02:58 PM   #2 (permalink)
hey i saw that too! yeah i dont think it is true, unless the camaro is supposed to use the oil in some different way.
Born 4/16/04Titan CC LE 4x4 SilverEVERY PACKAGE ex. oem naviUtili-trackJBAHeaders
FlowMaster 40 CatbackSirius Satellite RadioCST 7" LiftK&N 77 IntakeHella Air Horns
Weld Racing Cheyenne RimsCarbon Fiber Dash KitXboxXterrain tiresloProfile Truxedo
Fox piggybacksSub BoxPowerBass Subs 10"Infinity ampInfinity tweets and speakers
Tsunami 1-Farad Capacitor For SpeakersKenwood KVT-715DVD Navigation/DVD System
bestitan is offline   Reply With Quote
Old 09-05-2004, 03:06 PM   #3 (permalink)
Send a message via AIM to 04TitanXECC Send a message via MSN to 04TitanXECC Send a message via Yahoo to 04TitanXECC
its true...i saw it too. But the only way you see gains is going from an over used oil thats crap to begin with, and then using something like that royal purple which is a synthetic. so it does work, but only after neglect.
04 Titan XE CC 2WD Born July 31 2004
Eclipse CD8454
JL12w7
MTX 81000D amp
glasspack true duals w/split rear exit
Ventshade bug deflector
***not any more***
2005 Chevy Silverado 2500HD LT SB CC
Duramax
every option polible
04TitanXECC is offline   Reply With Quote
Old 09-05-2004, 06:30 PM   #4 (permalink)
Steamguy's Avatar
Worst case versus best case
Originally Posted by rawze
<SNIP> cutting back the friction made so much difference. they were running purple something.
Rawze,
They were probably taking worst case (cheap oils past change, additives all depleted) to best case (flush, clean oil, drain and replace all) so that they could have the very absolute maximum difference.
However, it is possible. When the railroads were entrenched with 'sliding' bearings, Timken built a locomotive with all roller bearing technology. One publicity photo showed a number of 'secretaries' (boy would we get in trouble calling them that today) pulling the locomotive. Rolling frictions were reduced by that much.
By reducing the amount of horsepower it takes to overcome rolling (sliding) resistance, it is surprising how much you can gain. My old Dodge truck got a for-sure 1 MPG gain by switching to synthetic, so there is something to it.
Could they have cheated by injecting some 'magic stuff' like molybedinum disulfide? Sure.
Steamguy
Finally found an appropriate sig pic. It's good at least through August...
Old 09-05-2004, 06:49 PM   #5 (permalink)
I saw that to, What a load of CRAP!!!!!!!! What does that tell you about the oil that was in that engine!!! Maybe a slight inprovement,but NOT 8-10 H.P. I use Mobil-1 in every Engine I own, But not for the HP,For the protection
drags1998 is offline   Reply With Quote
Old 09-06-2004, 11:38 AM   #6 (permalink)
rholland's Avatar
My last truck was a 1996 Ford F150, I drove it for 8 years, 176,000 miles. the temp gauge had the word normal in the face of the gauge. The temp always ran on the "r" in normal. The last time I changed oil I change from Castrol GTX to Mobil 1. I imediately noticed that the temp was on the "n" and not the "r". That would be 5-10 degree temp drop from using the syn oil. If the lesser friction can lower the temp that much, there could be some hp gain.
rholland is offline   Reply With Quote
Old 09-06-2004, 12:22 PM   #7 (permalink)
there is always going to be something of a difference when changing lube's, whether its better or worse. but the point is is that the only way to see a 5% or so increase in HP or TQ is going from overdone lube's to fresh lube's.
Old 09-06-2004, 03:20 PM   #8 (permalink)
rawze's Avatar
i don't know if the lubes were shot at first or not but it still did 300 stock
SILVER KC SE 4x4
rf w/captains
chrome bed rails
jba exhaust
wade bug shield
billet lower grill
line x liner
factory step rails
Old 09-06-2004, 04:14 PM   #9 (permalink)
smoothTitan's Avatar
I am actually not a big fan of synthetic oil. i recently had a chevy 2500 hd. i ran pennzoil for about 25,000 miles then switched to mobil 1 with all the talk about how much better it was. within 5000 miles my cam was bad, and a hydraulic cam should hardly ever go out. the tech guy told me that synthetic was so slick that in some cases it is harmful to an engine. i guess that is why they say not to break an engine in with synthetic oil. so i quit using it, i have used pennzoil for 15 years and never had a problem, so the sying goes if its not broke dont fix it.
Galaxy Titan KC LE 4x4
Trenz billet
Painted bushwhackers
15% tint
prg front and rear kit
Old 09-06-2004, 04:43 PM   #10 (permalink)
LOL
Smoke 4x2 LE CC
Enkei K-6 20" Wheels
K&N Filtercharger
Flowmaster 50 Dual Exhaust
UpRev
Tru-Trac
PML Diff Cover
Honda CRF-450 in back!
todd92 is offline   Reply With Quote
Old 09-07-2004, 08:57 PM   #11 (permalink)
lol if you want, but all i know is that about a month ago i was going to switch to synthetic actually it was royal purple. my dads buddy runs late model dirt car, 406 c.i. pushing about 750- 800 hp. he is a motor guru. he knows about everything when it comes to engines, he told me not to run full synthetic, but instead a syntec blend. he gave me a bunch of reasons why. thing is i just didnt really understand what he was talking about, way over my head. he said that bearings and stuff didnt seat good with full synthetic.
so todd tell me where my buddy is wrong and ill go back and tell him.
Trenz billet
15% tint
Old 09-08-2004, 05:27 AM   #12 (permalink)
I refuse to get in to another oil debate. You know a motor/oil guru, he has told you what to do and you believe him. What more is there to say?
Smoke 4x2 LE CC
K&N Filtercharger
UpRev
Tru-Trac
PML Diff Cover
Old 09-09-2004, 10:00 PM   #13 (permalink)
You can actually dyno with higher results with lower weight oils. Try running Ow-30 oil. YOu will dyno a few hp more, but I'd personally take the power loss for more protection. Also, keep in mind your drivetrain oils. For example, on SE-R's, the trannies are notoriously weak. When you get big power, they like to blow up and one of the ways we've been able to postpone this is by using Redline Heavyweight Shockproof oil, which is like 150W. It takes like 45 minutes to put in 4 quarts of the stuff. It's like Pepto Bismol. This stuff robs easily 5-6 hp.
Terrin
92 SE-R
13.2@104
92SE-R is offline   Reply With Quote
Old 09-10-2004, 06:35 AM   #14 (permalink)
Ask your dad what makes synthetic more "slippery". Then ask him what makes synthetic oil "synthetic" and how that could possibly make it more "slippery".
Next, ask him what Energy Conserving I and II mean on an oil and if these are more "slippery" than a non EC oil.
Now, get two slipnslides. Put synth oil on one, and dino on another (same weights). Do 5 test slides per slipnslide and measure which one makes you go further.
Finally, ask him why Porche and other high performance cars come from the factory with synthetic in them.
The only reason to use dino for break in is because it's cheaper and you'll change more often.
bvstone1 is offline   Reply With Quote
Old 09-10-2004, 08:45 AM   #15 (permalink)
I've used Amsoil synthetic in diesel and gas trucks for years. It's JMO, but the mileage and HP gains are slight in gassers, yet 35,000 between oil changes and no sludge and varnish to dry out gaskets is my reason. Like the Tundra before it, I'm running Amsoil 0w-30 in this Titan with confidence it'll do the job.
'04 Titan KC LE 4x4
Amana White
OEM: Big Tow, Offroad, Utilitrak, Extender, Step rails, Mudflaps, Captains, XM Satellite Radio
MODS: ARE LSII Tonneau, Amsoil 0w-30
roadtoad is offline   Reply With Quote
