UpRev & JBA Long Tube's - Page 4 - Nissan Titan Forum
Old 11-20-2012, 03:55 PM   #46 (permalink)
Elk Hunter's Avatar
iTrader Score: 0 reviews
Re: UpRev & JBA Long Tube's
Originally Posted by 06HemiRam View Post
That will definately take away some of the power, probably run 2-3 tenths of a second quicker at sea level.
I cannot see it in the datalog from the print screens, but what does the timing advance look like? Are you in the high 20s and low 30s?
Also worth mentioning, it seems like the air fuel ratio enrichment delay is still in place. It holding a lean air/fuel mixture until it is most of the way through 1st gear.
A few screen shots, didn't wanna do 8 more so I just did the start, shift point and end of the run.
2004 Titan Crew Cab LE 4x4 Galaxy Black
UpRev by seymore4 @ Cajun
JBA Long Tube's from Mike @ TAP
Next up: MXP, Cajun b-pipes and ??
Elk Hunter is offline   Reply With Quote
Advertisement
Old 11-20-2012, 03:57 PM   #47 (permalink)
iTrader Score: 1 reviews
Timing seems like it could be a little higher, maybe 2-4* in places, but that is something that is going to have to be played with.
2012 CCSB SV Sport
Hypertech/Split Second PSC1-003 tuned
Minor Bolt-ons and Free mods
296 RWHP/388 RWTQ on Mustang dyno
8.924 @ 77.31 on 2.007 60' in 166 DA
13.987 @ 96.20 on 2.007 60' in 166 DA
06HemiRam is offline   Reply With Quote
The Following User Says Thank You to 06HemiRam For This Useful Post:
Elk Hunter (11-20-2012)
Old 11-20-2012, 03:57 PM   #48 (permalink)
Elk Hunter's Avatar
I almost wish my 2012 would stay unlocked longer, I am locked up in OD by 40-45 mph.
I'd love it to lockup in 5th at about 55 MPH. 40-45 seems way low
Old 11-20-2012, 03:59 PM   #49 (permalink)
Elk Hunter's Avatar
Off to log some more now that I have 91 Octane! Full tank tonight, but no passenger. Should equal out as far as weight. Hoping to see a 7.1-7.2 with 91.
Any tips on launching in 4WD, or should I not mess with it because I don't have the burn out mod? I guess I could try it and see how much timing it pulls.....
Old 11-20-2012, 04:00 PM   #50 (permalink)
jrspeed's Avatar
Send a message via Yahoo to jrspeed
Originally Posted by Elk Hunter View Post
Mine feels like it holds in gear longer! I have to be at like 67-68 ish for the converter to lock in 5th. Annoying cuz my average speed is 55-60, so I have to speed up and then slow down. Then again I only drove 2 weeks in stock form... Can't remember it much haha!
I'm going to have to do a video of it it's, because the shift from 1-2 has a delay but you can feel when it gets into gear.. I know that in my first two years of having the truck I had a intermediate harsh shifting problem.. They had to reflash theTCU in order to fix it. The shifts at that time was hard Enough to shake the rear view mirror during normal driving..
Sent from my iPhone using AutoGuide.com App
jrspeed is offline   Reply With Quote
Old 11-20-2012, 04:01 PM   #51 (permalink)
Yep, it pulls down to 900-1000 rpm @ 40 mph under light load, the engine pulls the load just fine, although it runs a little rough.
2012 CCSB SV Sport
Old 11-20-2012, 04:03 PM   #52 (permalink)
jrspeed's Avatar
My wife's 09 is like that also I guess that how they get better gas mileage...😐
Old 11-20-2012, 04:03 PM   #53 (permalink)
I would two foot it from idle, but time it so that as soon as you roll on the gas, you are coming off the brake as you reach 1,000-1,500 rpm. Don't spend any length of time power braking it as it will pull timing and throttle.
2012 CCSB SV Sport
Old 11-20-2012, 04:08 PM   #54 (permalink)
Various bits of extensions 1" to 3" in 1/2" and 3/4" socket size will help a lot in getting the headers on and off. Also, it will help prevent slipping and rounding a nut!
gyots08 is offline   Reply With Quote
Advertisement
Trying to find Long tru Tranny cooler Long Tru Cool SR4588 Timmy Titan Parts & Accessories 4 07-18-2012 12:19 PM
Done - Uprev Austin installs DT Long Tubes, Berks, JBA and tune El Equis Titan Performance Modifications 47 05-26-2011 08:57 AM
Uprev Base Rom, how long is the wait? VinylImagez Titan Performance Modifications 9 02-25-2011 03:02 AM
How long does it take for UpRev to ship? JDos1 Titan General Discussion 6 01-03-2011 07:40 PM
Solution to the Titan gas mileage problem…(long).. (very long) lowlypawn Titan General Discussion 35 01-18-2005 10:03 PM
SEO by vBSEO 3.3.2
