UpRev & JBA Long Tube's - Nissan Titan Forum
Old 11-02-2012, 02:37 PM   #1 (permalink)
Elk Hunter's Avatar
iTrader Score: 0 reviews
Didn't think this day would ever come, but my JBA Stainless Steel Long Tubes showed up today. Supposed to take the truck up the mountain to cut fire wood tomorrow, so I'm gonna try and tackle the job tonight.
I have a 1/2" impact gun and a 3/8" air ratchet to help me out along with all the basic sockets, ratchets, ratcheting wrenches, jack, jack stands etc... I'll be stopping at NAPA on the way home to pick up a couple (1/2" & 3/8") good quality universal joints as well.
Tips I've read so far on this site:
- Label all removed nuts & bolts
- New Factory Gasket
- 2x4 to jack the engine up
- Thread Locker on the header nuts
- Anti Seize on the 02 sensors
- PB Blaster 1-2 hours prior to install
- Start and heat the truck up a bit prior to install
- Is there anything I am missing?
UpRev will not be here till Monday unfortunately, how safe am I to drive the truck on stock tuning this weekend? I've read conflicting threads about this... some say I'll be fine if I take it easy... Some say 1 or 2 WOT runs won't hurt... Some say don't drive it at all ?????
Any advice, tips, tricks or verbal abuse will gladly be accepted.
Thanks in advance!
2004 Titan Crew Cab LE 4x4 Galaxy Black
UpRev by seymore4 @ Cajun
JBA Long Tube's from Mike @ TAP
Next up: MXP, Cajun b-pipes and ??
Elk Hunter is offline   Reply With Quote
The Following 3 Users Say Thank You to Elk Hunter For This Useful Post:
97lowazznissan (11-02-2012), Chas @ TAP (11-09-2012), gweasel77 (11-08-2012)
Advertisement
Old 11-02-2012, 03:06 PM   #2 (permalink)
Supporting Vendor
nightowl's Avatar
iTrader Score: 83 reviews
Re: UpRev & JBA Long Tube's
Congrats, I used the heck out of a 14mm ratcheting wrench and stubby 14mm ratcheting wrench. A 12" piece of 3/4 inch electrical conduit was a life saver used as a cheater pipe. Those nuts are tight as hell. I would have some extra nuts and studs ready in case you strip any. Be very careful with the sensors as they damage very easy. Have fun and take your time.
YOUR CRACKED MANIFOLD ONE STOP SHOP
-CUSTOM BPIPES
-JBA HEADERS
-JBA CATBACK
-AXLE VENT KITS
-2.5" CAJUN Y PIPES
-VIBRANT ULTRAQUIET RESONATORS
-CUSTOM TUNING "NO DYNO NEEDED"
http://www.cajunbpipes.com
UPREV INFO-CAJUNTUNING@GMAIL.COM
nightowl is online now   Reply With Quote
The Following User Says Thank You to nightowl For This Useful Post:
Elk Hunter (11-03-2012)
Old 11-02-2012, 06:44 PM   #3 (permalink)
TA CC TX's Avatar
iTrader Score: 2 reviews
There is good info Here,,,Stillen Header Install - 2004 4x4 Get a 14 mil open end
[SIGPIC][04 CC BT OFFROAD RB's UPREV TUNE Doug Thorley LT's/Cajun 2.5 catless B-Pipes/Cajun Y-pipe 2.5-3.0/Borla XR-1/Vibrent UQ resonator/Airaid MXP CAI/HM Ram AIR/+07 IM/TB-Mod/170* thermostat/HM grounding kit/ CSF Rad/ Long SR4588 Tranny Cooler/Bilstine H-D's front and back/2" Drop Shackles/Hellwig traction springs/Tru Track/AirLift air bags/MetalWorx Traction bars/ Wolo powerhouse air Horn!!!!!!
[RWHP 316.56-RWTQ 378.54 ]
IRCVK56 MEMBER
TA CC TX is offline   Reply With Quote
The Following 2 Users Say Thank You to TA CC TX For This Useful Post:
Coadygtr (11-08-2012), Elk Hunter (11-03-2012)
Old 11-02-2012, 07:14 PM   #4 (permalink)
BlackonWhite's Avatar
I drove with headers and no muffler for a while before I got tuned. I think you'll be fine.
Sold but not forgotten. 2004 Nissan Titan, LE 4x4 Offroad. Uprev/Danblp tune, Stillen long tubes, custom Magnaflow exhaust, S&B CAI, Tranny pressure mod, Burnout mod, JB's 10000k hid's low beams and fogs, Ultrabright high beams, 10" DD sub with custom built box, 1000w JL Audio amp, 5% tint all around, Tinted tails, Debadged.
BlackonWhite is offline   Reply With Quote
The Following User Says Thank You to BlackonWhite For This Useful Post:
Old 11-02-2012, 07:24 PM   #5 (permalink)
BAD 24/7's Avatar
iTrader Score: 6 reviews
You will be fine without a tune, I went over a year without a tune with my headers and had no problems at all.
2007 Nissan Titan SE Crew Cab Galaxy Black
HP: 347.6 TQ: 407.2
PERFORMANCE: Uprev l Stillen LT Headers l Berk B-Pipes l Custom True Dual Rear Exit Exhaust with Flowmaster Super 44's l Grounding Kit l Injen Intake w/ Hydro Shield l Airaid TBS
INTERIOR: Green LEDs l Legit Accessories Green LMU Kit l MTX Audio Thunderform Enclosure l Custom Seat Covers
SUSPENSION: Pro Comp Stage II Suspension with ProRunner Rears l PRG Extended Endlinks l PRG Drive Shaft Spacer l Stillen Front Sway Bar
BRAKES/WHEELS/TIRES: Stillen BBK l 35x12.50x18 Nitto Trail Grapplers l 18x9 Mamba M5's with Bullet Valve Stems
EXTERIOR: Billet Grille l Spyder Black Dual Halo Headlights l Black Altezza Tail Lights l Nissan Skid Plate l Short Bullet Antenna l Hornblaster's Shocker 240 Train Horn Kit l Stillen Diff Cover
TO BE INSTALLED: Legit Accessories Products l BT Mirrors l GlowShift Gauges
COMING SOON: CLASSIFIED l Green Halo Anzo Headlights
BAD 24/7 is offline   Reply With Quote
The Following User Says Thank You to BAD 24/7 For This Useful Post:
Old 11-02-2012, 08:42 PM   #6 (permalink)
TitanLegion's Avatar
iTrader Score: 1 reviews
i didn't think you needed to use new gaskets? I just used the OEM gasket when i replaced my manifolds
07 Majestic blue CC
Black halo's w/8000k hids and matching halo fogs. Interior, Underbody, Wheel well, Engine and bed glow kit(all blue). Smoked tails. Bedlined caps, crowl, whipper blades and mudflaps. 4" MPX CAI. Upreved tuned. JBA LT headers, Cajun catless b-pipes, Borla Muffler. Blue and Black interior, Kenwood DDX 419 HU. Kenwood 10" Subs, speakers and tweeters all around. 360 installed for a little R&R. Big Brake kit. hawk pads, drilled and slotted black rotors. Sittin on bedlined 265/70/18 Nitto terra grapplers.
Picking up where the factory left off.....
TitanLegion is offline   Reply With Quote
The Following User Says Thank You to TitanLegion For This Useful Post:
Old 11-03-2012, 03:55 AM   #7 (permalink)
Supporting Vendor
nightowl's Avatar
You were brave! No way I would risk a leak with that kinda labor involved.
-CUSTOM BPIPES
-JBA HEADERS
-JBA CATBACK
-AXLE VENT KITS
-2.5" CAJUN Y PIPES
Old 11-03-2012, 05:09 AM   #8 (permalink)
josh19k's Avatar
I reused my stock gaskets also...no leaks.
09 Silver Titan SE CC 2wd FFV
Mods: Uprev, LP mod, JBA LT Headers, Airaid MPX 4" CAI, RP Performance stage 2 e-fan, JBA catback (with Dynomax VT muffler swap and Vibrant UQ), Cajun 2.5" Catless B-pipes, Factory E-locker with 2.94 gears, Burnout mod, Rough Country Traction Bars, PRG adjustable shackles, OEM 20s powdercoated satin black, General Grabber UHP 275/55r20s, Power Stop Evolution rotors and pads, 2 10" Polk MM1040 subs in a custom box with a Rockford 300.1, 20% tint all around.
13.624@99.63, 1.923 60ft, 650 DA, 5000 lbs--->Slip--->Vid
josh19k is offline   Reply With Quote
The Following User Says Thank You to josh19k For This Useful Post:
Old 11-03-2012, 06:56 AM   #9 (permalink)
dubyam's Avatar
New gaskets are cheap insurance. Key thing to remember on a job like this - don't get in a position where you're going to be rushed. If I knew I needed the truck for a wood run, I'd hold off until after that to R&R the manifolds/headers.
dubyam is offline   Reply With Quote
The Following User Says Thank You to dubyam For This Useful Post:
Old 11-03-2012, 09:04 AM   #10 (permalink)
Elk Hunter's Avatar
Okay, so a buddy and I worked on it for an hour and 45 minutes last night... Passenger side almost off, all nuts off and mid pipe unbolted. Drivers side all nuts are broke loose, and mid pipe is off. We thought that we were making good time! Then found out that you HAVE to undo the motor mounts to get enough clearance to pull the manifolds out. We were hoping that we wouldn't have to jack the motor up. Anyhow, tried for about 30 minutes to get to the motor mount bolts.... How in the hell do you get to them?! By far, the 8 motor mount bolts are the most time consuming and hard part of this whole install?! Tips anyone? I'm not about to give up and drop the differential.
Old 11-03-2012, 09:09 AM   #11 (permalink)
Elk Hunter's Avatar
Nissan wanted $105 for a new set of gaskets. Eff that! Called JBA and they said the gaskets they supply are just fine. They assured me that they wouldn't include crappy gaskets in a kit they sold.
Hoping I don't regret it later, but the wife is already pist at how much I've spent. Couldn't justify another 100 to the stealership. Gonna use the new ones JBA sent.
The Following User Says Thank You to Elk Hunter For This Useful Post:
Chas @ TAP (11-20-2012)
Old 11-03-2012, 09:23 PM   #12 (permalink)
dubyam's Avatar
Wasn't saying you needed to shell out for new Nissan factory gaskets - was simply saying you should change to new gaskets (the JBA ones are "new" as well) you'll be fine. The thing you don't want to do is go in and do all this work, and leave old gasket material in there. Because as you've discovered, it's not as easy as unbolting and bolting, so tearing it down once is valuable, as opposed to twice. As long as you go back with new gaskets, and they're of good quality, I think you'll be fine.
Old 11-03-2012, 10:28 PM   #13 (permalink)
Elk Hunter's Avatar
9 1/2 hours total install time. Definitely the most frustrating project I've ever done. Motor mounts were the toughest and most time consuming for sure. Took the truck for a little drive, sounds and feels so much better! Didn't really get on it, don't wanna burn a valve running to lean. UpRev should be here Monday, can't wait to finally do a WOT run!
Thanks for the tips and advice everybody.
nightowl (11-04-2012)
Old 11-03-2012, 10:34 PM   #14 (permalink)
Elk Hunter's Avatar
14mm ratchet wrench saved the day thats for sure. I couldn't have done it without a few good universal joints and about 18 inches of extensions either. Broke 1 universal joint and 2 extensions. Overall, not to bad, just frustrating and time consuming. Can't wait for a set of catless Cajun b-pipes!
jrspeed (11-05-2012)
Old 11-04-2012, 06:04 PM   #15 (permalink)
Supporting Vendor
nightowl's Avatar
I will have a set ready for you. I paid about $65 for the oem flange gaskets. Its funny how some smaller Nissan dealerships will try to rape you on prices. Glad the install went well and now you can tackle anything on the Titan.
-CUSTOM BPIPES
-JBA HEADERS
-JBA CATBACK
-AXLE VENT KITS
-2.5" CAJUN Y PIPES
Elk Hunter (11-04-2012)
Advertisement
Trying to find Long tru Tranny cooler Long Tru Cool SR4588 Timmy Titan Parts & Accessories 4 07-18-2012 12:19 PM
Done - Uprev Austin installs DT Long Tubes, Berks, JBA and tune El Equis Titan Performance Modifications 47 05-26-2011 08:57 AM
Uprev Base Rom, how long is the wait? VinylImagez Titan Performance Modifications 9 02-25-2011 03:02 AM
How long does it take for UpRev to ship? JDos1 Titan General Discussion 6 01-03-2011 07:40 PM
Solution to the Titan gas mileage problem…(long).. (very long) lowlypawn Titan General Discussion 35 01-18-2005 10:03 PM
SEO by vBSEO 3.3.2
