CSF radiator, need opinion - Page 4 - Nissan Titan Forum
Old 11-28-2012, 11:33 AM   #46 (permalink)
gweasel77's Avatar
iTrader Score: 6 reviews
Re: CSF radiator, need opinion
Tight fit, how much more does the FT90 stick out over the stock TB
IDK? How much further it sticks out than the OEM TB?
I'll go get some measurements right now though!
I'll get distance from the LS7 TB to the CSF & from the MXP CAI Tube to the CSF.
2005 NISSAN TITAN SE KC
IRC VK56 TEAM MEMBER
performance:
UP/REV CUSTOM TUNED
4" Airaid MXP CAI w/ GW77 4" Ram-Air Mod / TB Bypass Mod / FT90 Kit / LS7 TB / '08 IM / CSF Race Rad. / Trans. Cooler / Nismo LT Header's / Berk Tech SS B-Pipes w/ Magnaflow Hi-Flows / 2.25"-3" Flowmaster Y-Pipe / Borla XR-1 Muffler / "Gatorback" Serp Belt / Relentless RPM Catch Can / Detriot TruTrac / ActiveTuning Grounding Kit / Burnout Mod / LP Mod / MT ET Street P295/45R/17 DR's / Mobil1 EP 5W30 / 75W140
exterior/suspension:
Ruff Racing R286 22"x9.5" Chromes w/ 305/45/22 Yokohama Parada Spec-X's / Slotted "cryo" Frozen Rotors / Hawk LTS Brake Pads / High Cap. Diff. Cover / Helwig RSB / Bilstein HD's / SpringTech 2" Drop Shackles / PRG camber bolts / Armada Air Dam / SolarGard Tint / Tow Hooks / Debadged
NEW PB: 1/4- 13.57 @ 98.51MPH w/ my BEST 60' EVER 1.88
New PB Dragtimes Page:http://www.dragtimes.com/Nissan-Tita...lip-25254.html
Need to install: PRG Street Traction Bars!!!
Next Mods: CAJUN PIPES!!!!
gweasel77 is offline   Reply With Quote
The Following User Says Thank You to gweasel77 For This Useful Post:
Chas @ TAP (11-28-2012)
Advertisement
Old 11-28-2012, 12:06 PM   #47 (permalink)
gweasel77's Avatar
So here's what i just found out!
Its kinda hard to hold a camera, a tape measure & take accurate measurements at the same time. LOL
From '08 IM Flange - CSF Rad = 9 3/8"
From LS7 TB Flange - CSF Rad = 6 15/16"
From MXP CAI Tube - CSF Rad = 1" (EXACTLY)
My pics were at an angle.
performance:
UP/REV CUSTOM TUNED
Old 11-28-2012, 02:48 PM   #48 (permalink)
pcg_k25's Avatar
iTrader Score: 1 reviews
Originally Posted by gweasel77 View Post
Just FYI, when i installed my CSF i didn't trim the shroud enough & got fan contact.
I ended up leaving the shroud out of the engine bay.
NO PROBLEMS SINCE! (still thinking about adding E-Fans???)
I wonder why your fan hit the shroud? Was hit centered? The reason I cut the shroud was to close the gap between the shroud and CSF. I'll post so pic's when I get home.
'04 CC SE BLIZ WHITE 2wd BigTow
FT90MM,UPREV TUNED, 4" ColdAir Intake, Coolant Bypass, TB Screen Removed, 10w40 RP, AT Grounding Kit, JBA Exhaust, TruTrac, Jet Tuned MAF, 170 Threm Mod, RB-4" RamAir Mod, 07 Intake, Doug Thorley Long Tube HEADERS, ST 2" Drop Shackles, LEVEL 10 Tran's & LEVEL 10 Torq Mod, Long Tru-Cool Trans Cooler, Hellwig traction springs, Factory 20's, Berky B-pipes, BellTech Lowering Structs, BellTech Shocks, Removed 3rd leaf, Blue LED's interior
Personal Best:
RACE TRIM = 60'-1.907 ; 1/8-8.809@78.13 ; 1/4-13.871@95.83
STREET TRIM = 60'-1.974 ; 1/8-8.899@77.05 ; 1/1-14.025@95.31
Next MOD:
08 Brake Upgrade,White Headlight Mod,
AUDIO:
Kenwood DDX712 with Kenwood KNA-G510 Navigation Module,Memphis Audio 12s in TECH12 box,Memphis Audio 16MDC-1000
pcg_k25 is offline   Reply With Quote
The Following User Says Thank You to pcg_k25 For This Useful Post:
Scan999 (12-02-2012)
Old 12-02-2012, 04:28 PM   #49 (permalink)
Scan999's Avatar
iTrader Score: 0 reviews
The crack in my radiator took a turn for the worse yesterday so I had to replace it. The job was pretty easy except it took me 5 hours. I guess I'm getting old. Don't see how you can do it without removing the fan. It made for a lot of room installing the wider CSF. I was able to trim the shroud and fit the fan back in before I installed the hoses. My Injen is laying up against the shroud but it doesn't seem to matter. I took a picture of the radiator that was disturbing and it wasn't the crack. It was the writing on the tank "Made in USA". I was hoping to see "Made in China" since the radiators crack so easily. Only 50% of this truck is made in North America. Figures that has to be one of the parts.
Hey Hector, sorry I couldn't wait but I do appreciate the offer to get together and help out.
05 LE CC 4x4 BT
Mods:
Injen Intake
Borla cat-back
Superchips
5100's all around (middle setting front)
08 coils
KMC XD SPY's
Cooper S/T Maxx
TrueTrac
CSF Radiator
bunch of other stuff thanks to this dam forum...
Scan999 is offline   Reply With Quote
The Following 2 Users Say Thank You to Scan999 For This Useful Post:
gweasel77 (12-02-2012), pcg_k25 (12-04-2012)
Old 12-02-2012, 04:34 PM   #50 (permalink)
gweasel77's Avatar
IDK? Its hard to explain...but yea it all went back together fine. Its was centered & everything.
I even trimmed the tabs off the shroud with a hack saw. I thought that all i had to do?
...but i should have cut some more plastic off all the way around it.
performance:
UP/REV CUSTOM TUNED
Old 12-02-2012, 04:40 PM   #51 (permalink)
No problems. I'm glad it went well. I'll be sure to pick your brain before I replace my radiator.
2006 Titan SE CC Black & Chrome
PP, BT, MATS, CHROME RUNNING BOARDS
Weathertech Liners, Visors, Bug Guard
Nissan Fog Light Kit & Under-Seat Storage
Rhino Bed Liner
Lund Trifold Bed Cover
Chrome Tail Gate Cover
Mag HyTec Diff Cover, PML Pan
Pro Comp Pro Runner Shocks
Shackle Update, Axle Vent Mod
Firestone Air Bags
DBA Rotors & Hawk Pads
Airaid MXP Intake System
Stillen All-Aluminum Radiator
Bully Dog GT Tuner with Blend Mount
Towing 2013 Jay Flight 26 RLS
Hector Bravo is offline   Reply With Quote
The Following User Says Thank You to Hector Bravo For This Useful Post:
Old 12-02-2012, 05:04 PM   #52 (permalink)
iTrader Score: 3 reviews
I had an issue with my csf 3328 last year when it arrived everything looked great. No damage and the install went fairly well. Of course once I filled it up and started the truck I found that one of the nuts that holds the internal tranny cooler had been over tightened or cross threaded at the mfg and it leaked coolant like a mf. AJUSA did take care of me but being in ga I was without my truck for almost a full week. They would not overnight the replacement one as they said that option wasn't available. That was a complete line of BS as when I contacted CSF directly they said they overnight them all the time. At that point I was at the mercy of AJUSA and just had to wait. AJUSA also informed me that my replacement rad was coming from their warehouse I believe it was in California but when I spoke to csf they said they had them in a warehouse on the east coast close to me. So in the end AJUSA said they were shipping it from their place and it fact was shipped from somewhere on the east coast per the shipping label. The new one was also in a completely different type of box. The reason it took a week to get it to me was that it was not shipped until 4 days after I was told it was going to be shipped.
Once the new one came in everything went smooth with the install except the junk rad cap that came with it leaked from the moment I started the truck. I called and complained again and they wanted me to swap the whole radiator out yet again. I of course said hell no and used the old one that I had bought at Nissan about a year prior. I still have the Nissan cap on there and everything has worked great.
In the end everything was more or less fine but I doubt I will do business with AJ again due to the shipping a replacement and the lack of care they seem to have for my issue. I realize that crap happens from time to time and it is what it is but it is the suppliers responsibility to take care of the customer and at least try to rectify the issue in a timely manor. If this was some other type of part that was not critical for drivability it wouldn't have mattered so much to me but the reality is that no matter what kind of part or accessory was purchased they should do everything that is reasonably possible to make it rite. It's not like I have to use my truck for work everyday, it's only a job requirement for me to have a full size pick up truck.
cayers1122 is offline   Reply With Quote
Old 12-03-2012, 10:13 AM   #53 (permalink)
gweasel77's Avatar
^^^Dang!^^^
Sorry to hear you had such a hard time with the CSF ordeal!
performance:
UP/REV CUSTOM TUNED
Mike @ TAP (12-03-2012)
Old 12-05-2012, 06:41 PM   #54 (permalink)
My radiator arrived today with no issues. I told my local UPS driver what was going on and he was cool enough to open it with me at the truck. Said if there is a scratch we will refuse the delivery. Might be worth trying to do the same when you get your radiator.
Yeah, my local driver is pretty fast... He usually drops the stuff in front of the door knocks twice and by the time I get out he is gone.
So I finally got the radiator (third one).
UPS guy came and picked up the damaged rad last friday. Supposedly they wanted to see the damage. Today I recieved my radiator and it looks ok. One of the siderails is bent a little but I'm not replacing this one. Will try to install it this weekend, if it's not too cold. LOL. My stock radiator may be on its way out. Or its just the clamps on transmission cooler hoses(hopefully). Had my bumper off for last few weeks since I resprayed it with bedliner, so it should be easier to get there.
CSF radiator, need opinion-csf-radiator-032-large-.jpg   CSF radiator, need opinion-csf-radiator-031-large-.jpg   CSF radiator, need opinion-csf-radiator-033-large-.jpg   CSF radiator, need opinion-csf-radiator-034-large-.jpg   CSF radiator, need opinion-csf-radiator-035-large-.jpg
eastend titan is offline   Reply With Quote
The Following 2 Users Say Thank You to eastend titan For This Useful Post:
gweasel77 (12-06-2012), Scan999 (12-06-2012)
Old 12-05-2012, 06:50 PM   #55 (permalink)
Scan999's Avatar
I can't believe you got another damaged radiator. Granted the packing isn't the greatest but dam for real...
The pic doesn't look too bad just the fact it is bent like that. Anyway other than it being freak'in cold out it should go smooth for you. Make sure you remove the fan. Makes life a whole lot easier.
05 LE CC 4x4 BT
Mods:
Injen Intake
Borla cat-back
Superchips
08 coils
KMC XD SPY's
Cooper S/T Maxx
TrueTrac
CSF Radiator
The Following User Says Thank You to Scan999 For This Useful Post:
Old 12-05-2012, 07:04 PM   #56 (permalink)
pcg_k25's Avatar
Thats the same radiator I returned to CSF! LMAO
Personal Best:
Next MOD:
AUDIO:
Old 12-06-2012, 03:58 AM   #57 (permalink)
gweasel77's Avatar
Seriously???
performance:
UP/REV CUSTOM TUNED
Old 12-06-2012, 11:27 AM   #58 (permalink)
pcg_k25's Avatar
Here is the pic's of the damage CSF that I sent back. Looks like the same one to me. Also a pic of wat I cut so the shroud would fit closer the the CSF.
CSF radiator, need opinion-damage-pic1.jpg   CSF radiator, need opinion-damage-pic2.jpg
Personal Best:
Next MOD:
AUDIO:
The Following 2 Users Say Thank You to pcg_k25 For This Useful Post:
Old 12-06-2012, 11:39 AM   #59 (permalink)
trevorkavanaugh's Avatar
Just ordered mine from Stillen 2 days ago.. Will take pictures of mine out of the box. Should be arriving today
trevorkavanaugh is offline   Reply With Quote
Old 12-06-2012, 12:27 PM   #60 (permalink)
Scan999's Avatar
Yours looks worse since the dent pentrates two rows and eastend_titan just the first. Interesting how both have damage in almost the exact same spot.
05 LE CC 4x4 BT
Mods:
Injen Intake
Borla cat-back
Superchips
08 coils
KMC XD SPY's
Cooper S/T Maxx
TrueTrac
CSF Radiator
eastend titan (12-06-2012), gweasel77 (12-06-2012)
Advertisement
trans fluid leak at radiator. radiator replacement Rob Titan Problems & Dealer Service 2 03-14-2011 10:01 AM
Question after Stillen Radiator intall or any radiator for that matter. leonag123 Titan Problems & Dealer Service 5 07-05-2009 04:03 PM
Tranny fluid in Radiator! NEW Radiator time :) adamdude04 Titan Problems & Dealer Service 26 03-26-2009 10:35 PM
SEO by vBSEO 3.3.2
