What to buy first? A Bully or an intake? - Page 3 - Nissan Titan Forum
Old 11-12-2012, 09:42 AM   #31 (permalink)
Supporting Vendor
iTrader Score: 1 reviews
Re: What to buy first? A Bully or an intake?
Hope i can shed some light into your questions.... BDGT is one of the BEST, Bang for your buck!!! click here: Bully Dog INSTALL
Yes you can find some used BullyDog Power Pups but you have to make sure you have the updated software and it is unmarried to the truck. If the unit locks up. You have to send into Bullydog and pay to unlock it which could be up to $150 or hear "We don't support the PP anymore. Support is great from Bullydog BTW. Advantage of the BDGT is that if you have any problems, get them on the phone and tell them, in most cases if you have problems they can help solve the issue by sending you a file via email in which you can update yourself within minutes.
AirAid intakes is another MOD we recommend too. AirAid intakes is another MOD we recommend too. We HAVE the BEST pricing compared to any of our competitors we can't advertise the price so PM us.
Buying from Amazon or Ebay is a good alternative. But why not support a "Supporting Vendor" and is a part that we have installed on OUR truck, It's been tested, tutorials with installation and if you EVER have a problem you can simply pick up the phone and call us. TAP Auto Parts has an Easy 30 day return policy. When was the last time you had to call Ebay or Amazon and gotten a live person?? Lol Although, our site is a work in progress we hope that it will be up shortly. We thank you for your patience and look forward in working with you!! Call, Email, or PM us!!!
Want to place an order??
TAPAutoParts.com
CALL US
Total Auto Performance - Las Vegas, NV
702-979-1577 | 888-244-6166
Mike@TAPAutoParts.com
Follow Us!
Mike @ TAP is offline   Reply With Quote
Advertisement
Old 11-12-2012, 10:24 AM   #32 (permalink)
Notenoughmodz's Avatar
iTrader Score: 9 reviews
You can plug it into a 10 or 15amp fuse. You'd be ok with either the stereo or cigarette lighter
Sent from my iPhone using Autoguide.com App
2007 KC SE
14.1@97mph *unofficial*
Performance mods
AEM Bruteforce CAI, Dual dynomax bullet exhaust, BDGT
Interior/Exterior
5% tint, Armada air dam, Bilstein 5100s, 8000k Hids, LED smoked 3rd brake light, LED smoked Tail lights, JB's Blue interior, Super reverse/liscense LEDs. Kicker 6x9/6.5 door speakers, Pioneer in-dash touchscreen, husky floor mats
Ballin on a Budget
Notenoughmodz is offline   Reply With Quote
Old 11-12-2012, 10:35 AM   #33 (permalink)
Tights24's Avatar
iTrader Score: 2 reviews
One thing you may not realize about powering the thing up. The extra cable to mount into your fuse box is just so you don't have to get power from the OBD port that you are plugged into. I personally found no reason to wire it up to the fuse box. There is a switch on the side of the OBD connector to use "external" power or use power from the plug itself. Bottom line, wiring into the fuse box doesn't prevent you from having to plug it into the OBD port, so I would just use power from there.
The only nice thing about powering it from an external source is if it's wired into an ignition fuse, it will be off when the truck is off as long as the switch is set properly. I never left it plugged into the port when I wasn't in my truck, so I never experienced potential battery drain anyway. Does that make sense?
2005 LE CC 4wd - sadly she's gone
Magnaflow Catback
Best 1/4 mile time so far - 15.10 @ 88.86 (Second track appearance)
New ride - 2007 GMC Yukon SLT Black on black fully loaded and bone stock. 15.9 @89mph w/2.54 60ft.
Tights24 is offline   Reply With Quote
The Following User Says Thank You to Tights24 For This Useful Post:
osiris10012 (11-12-2012)
Old 11-12-2012, 01:25 PM   #34 (permalink)
osiris10012's Avatar
Here is a picture of an add a circuit. It has 2 fuse sockets, 1 is for the source you're using and the other is connected to the wire for the added device. You would use the original fuse from the socket and whatever would be good for your added device(I think I just used a small 5 amp just to be safe, because I would rather in pop the fuse than overload the circuit. It has never popped.). They are really neat and are way safer than the old school jamming a wire in a fuse. I used one of the cigarette lighter fuses that shuts off with the ignition in my wifes car. I just plugged in a usb charger in the cigarette lighters until I found one that wasn't on with with the key off. I have never installed a bdgt so all that info will be up to you. It sounds like tight24 has a really good explanation of the power use. I know when I get mine I will probably use the add a circuit so it turns on and off with the ignition, but thats me.
2006 Radiant Silver 4x4 CC LE
Performance: 2011 Stock Exhaust and K&N Drop In Filter
Suspension: NCD 2" Leveling kit and PRG cam bolts
Wheels: Fuel Boost 18x9" with 20mm offset wrapped with 275/70-18 Toyo Open Country AT2's
Misc: Full Interior/Exterior LED's Plus Super Reverse 2.0 Lights From LegitLED'S, TonnoPro TriFold Tonneau Cover
osiris10012 is offline   Reply With Quote
Old 11-12-2012, 03:54 PM   #35 (permalink)
Supporting Vendor
Thats a great idea too. I've had mine in for 6 months. No problem so far.
TAPAutoParts.com
CALL US
Follow Us!
Old 11-12-2012, 04:08 PM   #36 (permalink)
jtrick's Avatar
iTrader Score: 5 reviews
Originally Posted by Shogunles View Post
Sorry I misunderstood you. TYou do not have power seats so you used the fuse circuit because there isn't one in there. What amp fuse is it?
Correct I used exactly what was posted in the pic. No cutting and splicing needed. Im not totally sure but I think it was a 5 amp. I bought a kit of different amperages so I could tap into any circuit. Good luck.
Sent from a tuned Titan
2008 Crew Cab 2WD
2.5" Front, 1.5" Rear Lift
Billstein 5100's on Middle Perch
PRG Extended Endlinks
2" Wheel Adapters
BDGT Tuned with RAM Mount
Airraid MXP CAI
Flowmaster Exhaust
275/70R/18 Nitto Terra Grapplers
Bedlined Everything
Legit 8k High and Low HIDS
Legit Blue interior LED package
20% Tinted Front Windows
jtrick is offline   Reply With Quote
Old 11-13-2012, 03:31 PM   #37 (permalink)
Shogunles's Avatar
iTrader Score: 3 reviews
Thanks for the info Mike. I wish I got your post sooner. I had already ordered it. And I just received today. When I am ready to buy the Airaid I will give you a call. Being new to this site, I did not realize that there were Supporting Vendors. I will call you in the future for future purchases. Thank you.
Shogunles is online now   Reply With Quote
The Following 2 Users Say Thank You to Shogunles For This Useful Post:
Chas @ TAP (11-13-2012), Mike @ TAP (11-13-2012)
Old 11-13-2012, 03:37 PM   #38 (permalink)
Shogunles's Avatar
Thanks for the install info guys.
I just received my Bully today. All I can say is wow. I got it updated and installed in the T via OBD Port. I wish there were more detailed instructions. If I had known this, I would have bought from Tap Auto to acess their Techs.
Anyway, 2 questions I have about the settings.
I bought this primarily for increased gains for towing. Which download settings would be conducive to towing?
Also want to increase fuel economy while towing and regular driving.
What settings would be used in this case?
The Following User Says Thank You to Shogunles For This Useful Post:
Old 11-13-2012, 04:14 PM   #39 (permalink)
Supporting Vendor
nightowl's Avatar
iTrader Score: 79 reviews
Just run the 87 tune and advance the timing 2*. Wot off. That will hunt.....
YOUR CRACKED MANIFOLD ONE STOP SHOP
-CUSTOM BPIPES
-JBA HEADERS
-JBA CATBACK
-AXLE VENT KITS
-2.5" CAJUN Y PIPES
-VIBRANT ULTRAQUIET RESONATORS
-CUSTOM TUNING "NO DYNO NEEDED"
http://www.cajunbpipes.com
UPREV INFO-CAJUNTUNING@GMAIL.COM
nightowl is online now   Reply With Quote
The Following 2 Users Say Thank You to nightowl For This Useful Post:
Old 11-13-2012, 07:44 PM   #40 (permalink)
Shogunles's Avatar
When you say WOT Off, do you mean take the WOT Restriction Off? That always confuses me. What will this do for my fuel economy?
Also it is possible to do a 4* advance if the Bully is connectes, correct? Will this increase my gains even more?
Old 11-13-2012, 07:46 PM   #41 (permalink)
Shogunles's Avatar
Thanks for the picture. I actually bought a fuse tap with the Bully. However, it is the wrong size. The fuses in the passenger compartment are much smaller. Do the make a smaller fuse tap? Or is there a way to use this tap with the passenger fuse panel?
Old 11-13-2012, 07:51 PM   #42 (permalink)
They make the add a circuits in the mini's too
Sent from my DROID X2 using AutoGuide.Com Free App
Old 11-13-2012, 07:54 PM   #43 (permalink)
I noticed zero diffence in mileage with WOT restriction removed or in place. My foot stays on the floor one way or another as I get up to speed. If anything with the restriction removed I get better mileage because I can only stay in it under 10 seconds without having other concerns. By 10s I am at 80-85 mph.
2012 CCSB SV Sport
Hypertech/Split Second PSC1-003 tuned
Minor Bolt-ons and Free mods
296 RWHP/388 RWTQ on Mustang dyno
8.924 @ 77.31 on 2.007 60' in 166 DA
13.987 @ 96.20 on 2.007 60' in 166 DA
06HemiRam is offline   Reply With Quote
Old 11-14-2012, 06:01 AM   #44 (permalink)
Shogunles's Avatar
I would assume with the WOT governor on you would get better mileage.
Do you tow?
What do you have your throttle set at?
What gas tune do you use?
And there is an option to set Economy percentage, what is this for?
I wish they gave clear cut explainations for each option. Especially for a novice like me.
Old 11-14-2012, 06:54 AM   #45 (permalink)
Here you go this should help answer some of your questions:
Information Sheet:
http://bullydog.com/documents/40410%...heet%205.4.pdf
Install:
http://bullydog.com/documents/40410-99%20V3.pdf
Advertisement
titan parts, bully dog intake, factory nav parts, 08 cloth interior ..etc... RSMOTH Buy/Sell 146 03-21-2013 12:24 AM
Ordered the ebay Bully Truck Air Intake Kit djc1977 Titan Parts & Accessories 21 04-01-2012 10:07 PM
aFe Stage 2 intake & Bully Dog GT Tuner fadingfastsd Titan Performance Modifications 9 09-12-2010 10:44 AM
volant intake and bully dog programmer!! byrd 42 Buy/Sell 22 10-02-2009 08:03 PM
SEO by vBSEO 3.3.2
