01-02-2013, 02:12 PM
#1 (permalink )
iTrader Score: 1 reviews
Anyone done a "kill switch"
On occasion I have to leave my truck parked overnight in sorta a sketchy part of town and I have a "club" steering wheel lock but I would also like a hidden kill switch too. Hopefully one under the dash.
Anyone done this to their truck?
Advertisement
01-02-2013, 02:16 PM
#2 (permalink )
iTrader Score: 16 reviews
Look up the burnout mod. With the switch on, it won't allow you to shift out of park. Just hide the switch.
That's what I do anyways.
Sent from my iPhone using AutoGuide.com App
MeatBeaterWhore™
TwinTwit #1
"The Big O"
GO DUCKS!
The Following User Says Thank You to StormTroopin For This Useful Post:
01-02-2013, 02:27 PM
#3 (permalink )
iTrader Score: 2 reviews
Re: Anyone done a "kill switch"
I have an uprev map that wont let the truck start.
09 Silver Titan SE CC 2wd FFV
Mods: Uprev, LP mod, JBA LT Headers, Airaid MPX 4" CAI, RP Performance stage 2 e-fan, JBA catback (with Dynomax VT muffler swap and Vibrant UQ), Cajun 2.5" Catless B-pipes, Factory E-locker with 2.94 gears, Burnout mod, Rough Country Traction Bars, PRG adjustable shackles, 2 10" Polk MM1040 subs in a custom box with a Rockford 300.1, 20% tint all around.
13.624@99.63, 1.923 60ft, 650 DA, 5000 lbs--->
Slip --->
Vid
The Following 2 Users Say Thank You to josh19k For This Useful Post:
01-02-2013, 02:31 PM
#4 (permalink )
iTrader Score: 24 reviews
Originally Posted by
josh19k
X2 ^^^
01-02-2013, 02:33 PM
#5 (permalink )
iTrader Score: 10 reviews
^^^ x3
I can switch outta park with burnout mod off or on.
2010 Nissan Titan 4x4 SE CrewCab
Heavy Metal Chrome Edition
The Following User Says Thank You to goree For This Useful Post:
01-02-2013, 02:34 PM
#6 (permalink )
josh19k
If he has uprev, that's also a good idea
MeatBeaterWhore™
TwinTwit #1
"The Big O"
GO DUCKS!
01-02-2013, 02:35 PM
#7 (permalink )
If he doesn't, I guess it would be a pretty expensive kill switch. Lol!
01-02-2013, 07:43 PM
#8 (permalink )
Use a relay to cut your main ign wire. Hidden switch to throw the relay.
Posted from my Titan.
01-02-2013, 07:44 PM
#9 (permalink )
Bring a backpack, take the battery out and take it with you. Problem solved. That'll be $20. Lmao!
01-03-2013, 10:57 AM
#10 (permalink )
jbowles
and get mugged for the backpack 2 blocks down from the Titan.
The Following User Says Thank You to baseballfanz For This Useful Post:
01-03-2013, 12:02 PM
#11 (permalink )
iTrader Score: 6 reviews
I also have the "kill switch" / Burnout Mod.
Works Great!!!!!
On a side note someone tried breaking in your our Apt. a few days ago!!!! I took pics of the pry marks they left on my front door!
We think its some young hoodrats from the neighborhood.
I'm ready for their arses this time if they try it again!!!!
We left the house for at the most 10 mins...
2005 NISSAN TITAN SE KC
IRC VK56 TEAM MEMBER
performance:
UP/REV CUSTOM TUNED
4" Airaid MXP CAI w/ GW77 4" Ram-Air Mod / TB Bypass Mod / FT90 Kit / LS7 TB / '08 IM / CSF Race Rad. / Trans. Cooler / Nism
o LT Header's / Berk Tech SS B-Pipes w/ Magnaflow Hi-Flows / 2.25"-3" Flowmaster Y-Pipe / Borla XR-1 Muffler / "Gatorback" Serp Belt / Relentless RPM Catch Can / Detriot TruTrac / ActiveTuning Grounding Kit / Burnout Mod / LP Mod / MT ET Street P295/45R/17 DR's / Mobil1 EP 5W30 / 75W140
exterior/suspension:
Ruff Racing R286 22"x9.5" Chromes w/ 305/45/22 Yokohama Parada Spec-X's / Slotted "cryo" Frozen Rotors / Hawk LTS Brake Pads / High Cap. Diff. Cover / Helwig RSB / Bilstein HD's / SpringTech 2" Drop Shackles / PRG camber bolts / Armada Air Dam / SolarGard Tint / Tow Hooks / Debadged
NEW PB: 1/4- 13.57 @ 98.51MPH w/ my BEST 60' EVER 1.88
New PB Dragtimes Page :
http://www.dragtimes.com/Nissan-Tita...lip-25254.html
Need to install: PRG Street Traction Bars!!!
Next Mods:
CAJUN PIPES!!!!
01-03-2013, 12:49 PM
#12 (permalink )
iTrader Score: 3 reviews
Depends on where you did your burnout mod at.
If done at the pedal, thatll disable from shifting out of park. If done at the ECU the truck will act normal
2008 Nissan Titan Pro-4x CC LWB Smoke
UNDER CONSTRUCTION
The Following User Says Thank You to vilim12 For This Useful Post:
01-03-2013, 12:56 PM
#13 (permalink )
Ahhh, that would explain it. Mine was done at the ECU.
01-06-2013, 09:10 AM
#14 (permalink )
iTrader Score: 0 reviews
here is an easy way to do it with no switches
all you need is a relay and a volt meter.
cut the starter wire in half. connect the starter side to 87 and the ignition switch side to 30.
ground #85
#86 goes to a positive switch like the parking lights, brake lights ect..
you can also switch it around for a ground switch instead of positive by
86 to ignition wire
85 to a ground activated switch
30 to starter side of starter wire
87 to ignition side of the starter wire
01-07-2013, 01:27 PM
#15 (permalink )
An even easier way with no switches or relays or voltmeters is to remove the ECM and/or IGN fuses and substitute them with ones that are burned out.
It's easy to pop a new fuse. Get two insulated leads and attach them quickly to a 12 volt battery and they'll pop. A potential thief would have to actually diagnose why it's not starting and check the fuses at the fuse box on the passenger side. Something they probably wouldn't want to do due to the time contraints they have if you know what I mean.
Of course, this is just a quickie method to get you by until you're able to put a well-hidden kill switch in it.
'05 Titan XE
K11 Smoke
18" LE wheels/tires-Leer 700 tonneau cover and some other stuff.....
Want: Color matched rear bumper- '07 exhaust and 18" Magnaflow muffler swap-Volant CAI......
Advertisement
Display Modes
Rate This Thread
Linear Mode
AutoGuide.com
Truck
European
Import
Domestic
Manufacturer
Visit AutoGuide.com today.
For advertising information, on the AutoGuide.com network please request a media kit or email us: sales@autoguide.com
