Here is a little instruction manual I put together for the PrerunnerGreg leveling kit. It has pictures of my install to go along with it. You gotta have acrobat viewer. If you don't have it then just go download it...it's free. If this is a big problem then I can post it as a word document. INSTALLING_PRERUNNER_GREG_LEVELING_KIT.pdf
NICE WORK! I can't wait to receive mine so I can start workink on it. Thanks.
04 LE CC 4x4 w/o Off-Road, Big Tow. Built 12/05/03. Drop in K&N Air Filter, XM Sat. Radio, Clear Headlamp/Fog Light Protector, 2.5" Pre-Runner Lift, SS Brake Lines, 20" Centerline Stingrays III, 305/55-R20 Toyo Open Country A/T, Billet Grill, Truxedo Lo-Profile. Air Lift Kit Rear.
Thanks for doing this. My kit should be on the way and hopefully installed next weekend.
_________________________________________
2004 Titan SE KC 4X4 - Pearl White
Born on 7/14/2004
Purchased on 8/28/04
SE Off Road Package
SE Utility Bed Package
Rockford Fosgate with Power Captain
What is the torque requirement on the ball joint nuts? Anybody know? Got my kit. Will be on soon, but need this info.
Never mind. I found it in a friends service manual, on page FSU-5. 58 ft-lb on the ball joint nut and 99 ft-lb on the lower shock bolt. It also has all the alignment specs on FSU-19.
Can anyone recommend a GOOD shock replacement for light off-road use? I have the Crown brake lines sitting in the garage, will get the spacers, thought it would be a good thing to get better shocks and do it all at once. Make a Saturday out of it, ya know...
Found some nice Bilsteins, but they have a piggy-back resorvoir that won't fit inside the coil spring. Maybe something with a remote resorvoir and some adjustability? Multi-rate springs are an option though that's probably more $$ than I want to spend at this time.
